Hey all! I found a way to fix the low sound in TS for android. You have to go the settings and first disable AGC. This option uses automatic voice gain control which decreases the volume so disable that. Then, select Hands Free option which allows you to use loudspeaker for sound output which increases the sound. After that select voice volume and increase the volume by 1.0 decibels. I hope this helped. Have a nice day all!
