Page 1 of 2 12 LastLast
Results 1 to 15 of 29
    August 2018
    3.2.0/3.2.1 doesn't work with Task_force_radio
    Today I got on my computer and opened teamspeak, and saw a notifcation for a TS update, being my naive little self I accepted the update. So to procede with my day I got into a modded game of Arma III. Everything worked out fine and I went along playing until I get a message telling me that TS crashed, appartently the addon I use and everyone in my unit uses called task_force_radio doesn't work with the new update and caused it to crash. I really wish you would test these things out before you release any official updates in the future. (the problem happened repetedly btw)
    Last edited by dante696; August 17th, 2018 at 11:20 PM. Reason: moved to right forum
    August 2018
    TS3 Not Responding
    So, I use TeamSpeak quite a lot throughout the day, and I have numerous plugins installed (Including TFAR and some others) and just recently installed a theme for TeamSpeak. I also use a PTT instead of voice activation. Yet, throughout the day, my TeamSpeak will stop responding while I'm talking and I'll have to close it via task manager, and when I relaunch it, I'll have to wait for my old instance/account/whatever on the server to time out before I can change my name back to what it was. Please help!
    6,080
    These are third party addons, we cannot test if third party addons will continue to work. That is the responsibility of each individual addon author to make sure their stuff works with the new release.
    They can grab the beta version and check it, make any necessary adjustments to their addons and hopefully have it ready before the client goes stable. That way there is minimal impact to their users and most of them wouldn't notice. Well that is if they update their stuff...
    January 2017
    same here since the latest update all was running well .. but now it randomly hangs then locks up
    January 2017
    Switzerland
    444
    Send the client log so we'll collect some more informations.
    (windows) You can find your clientlogs here, send the latest log:
    %APPDATA%\Roaming\TS3Client\logs
    June 2018
    17
    Have you changed something on your or something?
    BEcause teamspeak will freeze and not crash
    June 2018
    17
    also not everybody has that problem on few with the new version
    August 2018
    I didn't change anthing with the addon, it froze, I call it a crash because I end the task and restart it
    November 2016
    6
    Teamspeak Client Crashed seit neuster Version
    Hallo,
    ich und ein paar Kollegen haben seit der letzten Version das Problem das Teamspeak einfach mal crashed.
    Hierbei ist es egal ob man am Zocken oder am nichts tun ist.
    Dies macht sich erst nur bemerkbar indem kein Ton mehr kommt bzw in Gesprächen der Ton einfach abbricht.
    Nachdem man dann den TS anklickt meldet windows das die Anwendung nichtmehr reagiert.
    Ich hoffe sie können diesen Fehler schnell beheben, da dies gerade bei wichtigen Matches echt anstregend und störend ist.
    MfG Tobi
    June 2018
    17
    that was a question to @Chris ^^
    August 2018
    Teamspeak 3 Not responding randomly
    Since the last 2 updates, TS3 was running fine. After the latest update, it Will connect to a server ill start talking and then randomly either after a few minutes or seconds in the server the whole program stops responding. I'm on my latest Windows 10 update, and the latest Teamspeak 3 update.
    Attached Files Attached Files
    January 2017
    Switzerland
    444
    Bitte sende deinen Client-Log hier damit wir weitere Informationen sammeln können.
    Falls dein Betriebssystem Windows ist, dann schau mal hier vorbei:
    (Und nimm bitte den letzten gespeicherten Log vom Fehler)
    %AppData%/Roaming/TS3Client/logs
    August 2018
    Teamspeak crash: With logs
    Teamspeak Version: 3.2.1
    Issue: After spending some time, me and some of my friends have been having some issues after have the latest update. After some time, the teamspeak just crashes.
    Link to My log: https://pastebin.com/5G3SLBk5
    Side note: I'm contacting my friends to send me their logs of when they crashed and i'm doing more tests to have more logs of this event. There are no logs in the crashdumps.
    18,301
    Quote Originally Posted by SuperDudeplayer View Post
    Link to My log: https://pastebin.com/5G3SLBk5.
    Please deactivate the Taskforce radio plugin. This should solve the crash.
    Then contact the add-on author.
    Quote Originally Posted by Implified View Post
    Same as answered above. But in your case you have much more custom plugins running that could cause that.
    Deactivate them if Taskforce plugin is not the reason.
    June 2018
    17
    I mean there must be something on your side @dante if you havent changed something on the api.
    Taskforce Radio is not the only voice plugin with crashed, also ACRE has problems
  1. [Resolved] NPL doesn't work?
    By ItsJustBjarn in forum Linux / FreeBSD
    Last Post: August 30th, 2013, 10:25 AM
  2. Mic doesn't work-Help
    By fallz2772 in forum Windows
    Last Post: January 5th, 2012, 08:27 PM
  3. TTS doesn't work
    By haru_arc in forum Bug Reports [EN/DE]
    Last Post: January 3rd, 2011, 12:24 AM
  4. Mic doesn't work
    By berillions in forum Linux
    Last Post: August 11th, 2010, 09:31 PM
