Results 1 to 7 of 7
    June 2018
    Poland
    99
    Problem with icons
    Everything was fine until now. Some of the icons doesn't load. I tried to upload them again but it doesn't work. Client bandwith are set to -1 so propably that's server problem.
    January 2017
    Switzerland
    451
    Try to use this in your serversettings under Transfer.
    June 2018
    Poland
    99
    Server transfer settings are also set to -1 and icons doesnt't load.
    January 2017
    Switzerland
    451
    Are there any error codes or something like that to give us some more informations?
    June 2018
    Poland
    99
    For example: icon for server group r has not been located.
    August 2018
    My client is showing this in the logs:
    15/08/18 18:47:18 Info Failed to read image C:\Users\chris\AppData\Roaming\TS3Client\cache/MlEzR21IVDRmYlVhMUprSEZENGtBZXoyZCtVPQ==/icons/icon_4183616268: Unable to read image data
    15/08/18 18:47:19 Info Failed to read image C:\Users\chris\AppData\Roaming\TS3Client\cache/MlEzR21IVDRmYlVhMUprSEZENGtBZXoyZCtVPQ==/icons/icon_1106273852
    15/08/18 18:47:19 Info Failed to read image C:\Users\chris\AppData\Roaming\TS3Client\cache/MlEzR21IVDRmYlVhMUprSEZENGtBZXoyZCtVPQ==/icons/icon_1447029675
    15/08/18 18:47:19 Info Failed to read image C:\Users\chris\AppData\Roaming\TS3Client\cache/MlEzR21IVDRmYlVhMUprSEZENGtBZXoyZCtVPQ==/icons/icon_911185530
    15/08/18 18:47:19 Info Failed to read image C:\Users\chris\AppData\Roaming\TS3Client\cache/MlEzR21IVDRmYlVhMUprSEZENGtBZXoyZCtVPQ==/icons/icon_3779924146
    15/08/18 18:47:19 Info Failed to read image C:\Users\chris\AppData\Roaming\TS3Client\cache/MlEzR21IVDRmYlVhMUprSEZENGtBZXoyZCtVPQ==/icons/icon_2892640043
    15/08/18 18:47:19 Info Failed to read image C:\Users\chris\AppData\Roaming\TS3Client\cache/MlEzR21IVDRmYlVhMUprSEZENGtBZXoyZCtVPQ==/icons/icon_4183616268: Unable to read image data
    15/08/18 18:47:20 Info Failed to read image C:\Users\chris\AppData\Roaming\TS3Client\cache/MlEzR21IVDRmYlVhMUprSEZENGtBZXoyZCtVPQ==/icons/icon_3636691836
    15/08/18 18:47:21 Info Failed to read image C:\Users\chris\AppData\Roaming\TS3Client\cache/MlEzR21IVDRmYlVhMUprSEZENGtBZXoyZCtVPQ==/icons/icon_911185530
    15/08/18 18:47:22 Info Failed to read image C:\Users\chris\AppData\Roaming\TS3Client\cache/MlEzR21IVDRmYlVhMUprSEZENGtBZXoyZCtVPQ==/icons/icon_3636691836
    15/08/18 18:47:23 Info Failed to read image C:\Users\chris\AppData\Roaming\TS3Client\cache/MlEzR21IVDRmYlVhMUprSEZENGtBZXoyZCtVPQ==/icons/icon_911185530
    15/08/18 18:47:23 Info Failed to read image C:\Users\chris\AppData\Roaming\TS3Client\cache/MlEzR21IVDRmYlVhMUprSEZENGtBZXoyZCtVPQ==/icons/icon_3636691836
    15/08/18 18:47:25 Info Failed to read image C:\Users\chris\AppData\Roaming\TS3Client\cache/MlEzR21IVDRmYlVhMUprSEZENGtBZXoyZCtVPQ==/icons/icon_3636691836
    15/08/18 18:47:27 Info Failed to read image C:\Users\chris\AppData\Roaming\TS3Client\cache/MlEzR21IVDRmYlVhMUprSEZENGtBZXoyZCtVPQ==/icons/icon_3636691836
    15/08/18 18:47:31 Info Failed to read image C:\Users\chris\AppData\Roaming\TS3Client\cache/MlEzR21IVDRmYlVhMUprSEZENGtBZXoyZCtVPQ==/icons/icon_3636691836
    15/08/18 18:47:33 Info Failed to read image C:\Users\chris\AppData\Roaming\TS3Client\cache/MlEzR21IVDRmYlVhMUprSEZENGtBZXoyZCtVPQ==/icons/icon_3636691836
    I'm getting the same things: Server group icons are not showing. I tried clearing the cache; same issue.
    June 2018
    Poland
    99
    I talked to my server hoster about this problem and now everything works fine. I don't know if that was a bug or something.
  1. Problem with icons
    By carlos159632 in forum Client Support
    Last Post: May 8th, 2017, 09:58 AM
  2. Help - Problem with icons
    By itteam in forum Client Support
    Last Post: August 23rd, 2014, 02:44 AM
  3. Problem icons
    By Halo123 in forum Client Support
    Last Post: August 29th, 2013, 03:58 AM
  4. Forum Icons problem
    By Jordi in forum General Questions
    Last Post: April 2nd, 2012, 05:54 PM
  5. Uploading Problem (Icons)
    By Gabriel_5991 in forum Permission System
    Last Post: July 27th, 2011, 08:19 AM
