Results 1 to 3 of 3
    17,377
    [Beta Channel] TeamSpeak 3 Client 3.2.2
    Today we released a beta client 3.2.2.
    This beta should be used from all users with an active Task force radio plugin.
    Client 3.2.0 & 3.2.1 did freeze at some points and this beta should fix the issue. Sorry for that!
    === Client Release 3.2.2 23 Aug 2018
    ! Fixed client freeze when plugins are using voice callbacks.
    ! Cancel myTeamSpeak ID validation if there is no encryption key present.
    To enable the Beta channel, simply go to Tools -> Options -> Application and select "Beta" from the update channel dropdown.
    Now you can open Help -> Check for Update and then you should get this version.
    Here you can discuss and leave feedback about the beta client.
    17,377
    We released our next beta.
    In this beta version:
    - We fixed the bug where the client disconnected when server slots are full and a Query client connects to the server.
    - We added a *New* & expected behavior where the client disconnects when a user sets less slots on server than currently used.
    We also plan to release a new server version where the server will interact when user did set less slots as currently used on the server. So the new behavior becomes a fallback then.
    === Client Release 3.2.2 28 Aug 2018
    ** only date has changed
    Last edited by dante696; August 28th, 2018 at 04:51 PM. Reason: updated server part to avoid confusion
    17,377
    We pushed another beta to the public. This is hopefully our last beta for client 3.2.2.
    This beta will fix some more bugs where the myTeamSpeak ID did not update.
    === Client Release 3.2.2 10 Sep 2018
    - Fixed problems with myTeamSpeak ID update.
  1. [Beta Channel] TeamSpeak 3 Client 3.2.0
    By Chris in forum Archive
    Last Post: August 9th, 2018, 10:13 AM
  2. Replies: 2
    Last Post: January 22nd, 2018, 02:37 PM
  3. [Beta Channel] TeamSpeak 3 Client 3.0.15.1
    Last Post: July 14th, 2014, 11:14 PM
  4. [beta channel] TeamSpeak 3 Client 3.0.7
    By Peter in forum Archive
    Last Post: June 21st, 2012, 08:50 AM
  5. Replies: 47
    Last Post: April 23rd, 2012, 09:27 AM
