Results 1 to 3 of 3
    September 2018
    Mic not starting
    Hello.
    I have installed TS3 quite a few times over the last few weeks and everytime regardless of its 64bit or 32bit the mic will not start.
    The mic works in all situations with all other applications.
    I have tried numerous different nice, Bluetooth, wired, bought a usb amp and no you but again they all work in all other apps.
    Also, I am using a HDMI cable from pc to tv
    It has something to do with direct sound and windowsaudio CREATCAPTUREBUFFER.
    I have researched it as much as possible and it seems to be a DX12 (DirectX 12) audio problem. Although I'm not 100% sure.
    I'm currently away from my computer but I can post more specific error details later.
    But for starters
    Win10 64
    Asus P7P55D pro (on-board sound works)
    I-5 670 (I think)
    8gb cosair xmr 1600mhz (4x2gb running at 1333mhz)
    C-media sound card (not sure specific type but it works with all apps)
    Xfx Radeon RX580 8gb
    750w psu
    3 hard drives (2tb, 300gb and 280gb can't remember exact spec)
    Fans and LED stuff.
    Thankyou
    September 2018
    No Mic
    Hello, I have repeatedly installed TS3 over the last few weeks 64bit and 32bit.
    unfortunately the mic will not work in any way with TS3 but will work with all other apps installed
    I have tried in all configurations and thought it was my sound card or motherboard audio not working properly, so I bought a little PnP usb amp thing and still no joy.
    I would be extremely grateful if somebody could help or point to a fix that may work/
    My Specs are
    Win 10 64bit
    Asus P7P55D Pro
    I5-670 (overclocked to 4.32ghz)
    Cosair XMR 1600mhz (4x2gb)
    XFX Radeon RX580
    C-media Sound card
    Seagate 2TB Hard Drive
    Seagate 320gb Hard Drive
    750w psu
    here is the error log for all the most recent attempts.
    I've tried it everyway, these are with compatibility settings for Win 8
    30/09/2018 19:04:02 Info TeamSpeak 3 Client 3.2.2 (2018-09-17 10:01:05)
    30/09/2018 19:04:02 Info SystemInformation: Windows 8 (9200) x64 (AMD or Intel) Binary: 32bit
    30/09/2018 19:04:02 Info Using hardware aes
    30/09/2018 19:04:02 Direct Sound Debug setting timer resolution to 1ms -
    30/09/2018 19:04:02 Info *** Time [SPAWN_EVENTCONVERTER]: 116
    30/09/2018 19:04:02 ClientUI Info OpenGL Info: LibGLES, Vendor: Google Inc., Renderer: ANGLE (Radeon RX 580 Series Direct3D11 vs_5_0 ps_5_0), Version: OpenGL ES 2.0 (ANGLE 2.1.99f075dade7c)
    30/09/2018 19:04:02 Addons Info Checking for addon updates...
    30/09/2018 19:04:02 Plugins Info Loading plugin: teamspeak_control_plugin_win32.dll
    30/09/2018 19:04:02 ControlPlugin Info Control Plugin started, accepting connections
    30/09/2018 19:04:02 Overwolf Debug Detected Overwolf start
    30/09/2018 19:04:02 Addon Info Addon up to date.
    30/09/2018 19:04:02 Windows Audio Session Devel DeviceDeleteList::wait_for_deletes - enter - DeviceDeleteList
    30/09/2018 19:04:02 Windows Audio Session Devel DeviceDeleteList::wait_for_deletes - leave - DeviceDeleteList
    30/09/2018 19:04:03 Info *** Time [SERVERVIEWMANAGER]: 150
    30/09/2018 19:04:03 Info *** Time [MAINWINDOW]: 729
    30/09/2018 19:04:03 Info *** Time [INIT]: 729
    30/09/2018 19:04:03 ClientUI Devel Notifications init: Soundpack path: C:/Program Files (x86)/TeamSpeak 3 Client/sound\default
    30/09/2018 19:04:03 ClientUI Info Qt version: 5.6.2
    30/09/2018 19:04:03 ClientUI Info Using configuration location: C:\Users\Jim\AppData\Roaming\TS3Client\settings.db
    30/09/2018 19:04:03 ClientUI Info Last update check was: Sun Sep 30 20:01:53 2018
    30/09/2018 19:04:03 Info Statistics report: Not yet, next report on Tue Oct 30 20:01:59 2018
    30/09/2018 19:04:03 Bookmarks Info Collecting autoconnect bookmarks
    30/09/2018 19:04:04 Newsticker Info Newsticker next check: Mon Oct 1 20:01:55 2018
    30/09/2018 19:04:18 Addons Debug Couldn't find addon info for ClientQuery
    30/09/2018 19:04:18 Addons Debug Couldn't find addon info for Gamepad and Joystick Hotkey Support
    30/09/2018 19:04:30 Windows Audio Session Devel DeviceDeleteList::wait_for_deletes - enter - DeviceDeleteList
    30/09/2018 19:04:30 Windows Audio Session Devel DeviceDeleteList::wait_for_deletes - leave - DeviceDeleteList
    30/09/2018 19:04:30 Windows Audio Session Debug WAS:penDevice-enter - {0.0.1.00000000}.{462eae7b-7c8d-4966-bd6f-adcedac56e89}
    30/09/2018 19:04:30 Windows Audio Session Devel Mix Format: SRate:44100 Bitrate: 32 Channels: 1 - Microphone (USB PnP Sound Device)
    30/09/2018 19:04:30 Windows Audio Session Devel Initializing with mix format. - Microphone (USB PnP Sound Device)
    30/09/2018 19:04:30 Windows Audio Session Devel Couldn't initialize AudioClient with given format: Access is denied. - Microphone (USB PnP Sound Device)
    30/09/2018 19:04:30 Windows Audio Session Devel Format detected: Multichannel capable Float - Microphone (USB PnP Sound Device)
    30/09/2018 19:04:30 Windows Audio Session Devel Format is not supported, but a closest match exists. - Microphone (USB PnP Sound Device)
    30/09/2018 19:04:30 Windows Audio Session Error DEVICE_INITIALIZE: Access is denied. - Microphone (USB PnP Sound Device)
    30/09/2018 19:04:30 SoundBckndIntf Error C:/Program Files (x86)/TeamSpeak 3 Client/soundbackends/windowsaudiosession_win32.dll error: DEVICE_INITIALIZE
    30/09/2018 19:04:30 CapSoundSet Error Failed to open capture device when updating capture system: 2310
    30/09/2018 19:04:30 CapSoundSet Error Error setting PreProcessorConfigValues onPTTActivated: 2304
    30/09/2018 19:04:31 Windows Audio Session Devel DeviceDeleteList::wait_for_deletes - enter - DeviceDeleteList
    30/09/2018 19:04:31 Windows Audio Session Devel DeviceDeleteList::wait_for_deletes - leave - DeviceDeleteList
    30/09/2018 19:04:34 Windows Audio Session Devel DeviceDeleteList::wait_for_deletes - enter - DeviceDeleteList
    30/09/2018 19:04:34 Windows Audio Session Devel DeviceDeleteList::wait_for_deletes - leave - DeviceDeleteList
    30/09/2018 19:04:34 Windows Audio Session Debug WAS:penDevice-enter - {0.0.1.00000000}.{462eae7b-7c8d-4966-bd6f-adcedac56e89}
    30/09/2018 19:04:34 Windows Audio Session Devel Mix Format: SRate:44100 Bitrate: 32 Channels: 1 - Microphone (USB PnP Sound Device)
    30/09/2018 19:04:34 Windows Audio Session Devel Initializing with mix format. - Microphone (USB PnP Sound Device)
    30/09/2018 19:04:34 Windows Audio Session Devel Couldn't initialize AudioClient with given format: Access is denied. - Microphone (USB PnP Sound Device)
    30/09/2018 19:04:34 Windows Audio Session Devel Format detected: Multichannel capable Float - Microphone (USB PnP Sound Device)
    30/09/2018 19:04:34 Windows Audio Session Devel Format is not supported, but a closest match exists. - Microphone (USB PnP Sound Device)
    30/09/2018 19:04:34 Windows Audio Session Error DEVICE_INITIALIZE: Access is denied. - Microphone (USB PnP Sound Device)
    30/09/2018 19:04:34 SoundBckndIntf Error C:/Program Files (x86)/TeamSpeak 3 Client/soundbackends/windowsaudiosession_win32.dll error: DEVICE_INITIALIZE
    30/09/2018 19:04:34 CapSoundSet Error Failed to open capture device when updating capture system: 2310
    30/09/2018 19:04:34 CapSoundSet Error Error setting PreProcessorConfigValues onPTTActivated: 2304
    30/09/2018 19:04:35 Windows Audio Session Devel DeviceDeleteList::wait_for_deletes - enter - DeviceDeleteList
    30/09/2018 19:04:35 Windows Audio Session Devel DeviceDeleteList::wait_for_deletes - leave - DeviceDeleteList
    30/09/2018 19:19:03 Info Memory usage: 128.93 MiB
    30/09/2018 19:23:27 Info tried to request user integration info without valid session
    30/09/2018 19:23:27 Addons Debug Couldn't find addon info for ClientQuery
    30/09/2018 19:23:27 Addons Debug Couldn't find addon info for Gamepad and Joystick Hotkey Support
    30/09/2018 19:23:58 CapSoundSet Info Invalid captureDevice in Config File, (profile, captureDevice) = (Default, Microphone (USB PnP Sound Device))
    30/09/2018 19:24:10 Windows Audio Session Devel DeviceDeleteList::wait_for_deletes - enter - DeviceDeleteList
    30/09/2018 19:24:10 Windows Audio Session Devel DeviceDeleteList::wait_for_deletes - leave - DeviceDeleteList
    30/09/2018 19:24:10 Direct Sound Error CREATECAPTUREBUFFER: Unspecified error - {51D8120E-D80E-4517-8B46-29DC2BF97764}
    30/09/2018 19:24:10 SoundBckndIntf Error C:/Program Files (x86)/TeamSpeak 3 Client/soundbackends/directsound_win32.dll error: CREATECAPTUREBUFFER
    30/09/2018 19:24:10 CapSoundSet Error Failed to open capture device when updating capture system: 2310
    30/09/2018 19:24:11 CapSoundSet Error Error setting PreProcessorConfigValues onPTTActivated: 2304
    30/09/2018 19:24:12 Windows Audio Session Devel DeviceDeleteList::wait_for_deletes - enter - DeviceDeleteList
    30/09/2018 19:24:12 Windows Audio Session Devel DeviceDeleteList::wait_for_deletes - leave - DeviceDeleteList
    30/09/2018 19:24:16 CapSoundSet Info Invalid captureDevice in Config File, (profile, captureDevice) = (Default, Microphone (C-Media PCI Audio Device))
    30/09/2018 19:24:28 Windows Audio Session Devel DeviceDeleteList::wait_for_deletes - enter - DeviceDeleteList
    30/09/2018 19:24:28 Windows Audio Session Devel DeviceDeleteList::wait_for_deletes - leave - DeviceDeleteList
    30/09/2018 19:24:28 Windows Audio Session Debug WAS:penDevice-enter - {0.0.1.00000000}.{51d8120e-d80e-4517-8b46-29dc2bf97764}
    30/09/2018 19:24:28 Windows Audio Session Devel Mix Format: SRate:48000 Bitrate: 32 Channels: 2 - Microphone (C-Media PCI Audio Device)
    30/09/2018 19:24:28 Windows Audio Session Devel Initializing with mix format. - Microphone (C-Media PCI Audio Device)
    30/09/2018 19:24:28 Windows Audio Session Devel Couldn't initialize AudioClient with given format: Access is denied. - Microphone (C-Media PCI Audio Device)
    30/09/2018 19:24:28 Windows Audio Session Devel Format detected: Multichannel capable Float - Microphone (C-Media PCI Audio Device)
    30/09/2018 19:24:28 Windows Audio Session Devel Format is supported. - Microphone (C-Media PCI Audio Device)
    30/09/2018 19:24:28 Windows Audio Session Error DEVICE_INITIALIZE: Access is denied. - Microphone (C-Media PCI Audio Device)
    30/09/2018 19:24:28 SoundBckndIntf Error C:/Program Files (x86)/TeamSpeak 3 Client/soundbackends/windowsaudiosession_win32.dll error: DEVICE_INITIALIZE
    30/09/2018 19:24:28 CapSoundSet Error Failed to open capture device when updating capture system: 2310
    30/09/2018 19:24:28 CapSoundSet Error Error setting PreProcessorConfigValues onPTTActivated: 2304
    30/09/2018 19:24:29 Windows Audio Session Devel DeviceDeleteList::wait_for_deletes - enter - DeviceDeleteList
    30/09/2018 19:24:29 Windows Audio Session Devel DeviceDeleteList::wait_for_deletes - leave - DeviceDeleteList
    30/09/2018 19:24:33 CapSoundSet Info Invalid captureDevice in Config File, (profile, captureDevice) = (Default, Microphone (C-Media PCI Audio Device))
    30/09/2018 19:24:44 Windows Audio Session Devel DeviceDeleteList::wait_for_deletes - enter - DeviceDeleteList
    30/09/2018 19:24:44 Windows Audio Session Devel DeviceDeleteList::wait_for_deletes - leave - DeviceDeleteList
    30/09/2018 19:24:44 Direct Sound Error CREATECAPTUREBUFFER: Unspecified error - {2023CB55-322D-4966-8BED-6F50E96318D7}
    30/09/2018 19:24:44 SoundBckndIntf Error C:/Program Files (x86)/TeamSpeak 3 Client/soundbackends/directsound_win32.dll error: CREATECAPTUREBUFFER
    30/09/2018 19:24:44 CapSoundSet Error Failed to open capture device when updating capture system: 2310
    30/09/2018 19:24:44 CapSoundSet Error Error setting PreProcessorConfigValues onPTTActivated: 2304
    30/09/2018 19:24:46 Windows Audio Session Devel DeviceDeleteList::wait_for_deletes - enter - DeviceDeleteList
    30/09/2018 19:24:46 Windows Audio Session Devel DeviceDeleteList::wait_for_deletes - leave - DeviceDeleteList
    30/09/2018 19:24:51 CapSoundSet Info Invalid captureDevice in Config File, (profile, captureDevice) = (Default, Microphone (VIA HD Audio))
    30/09/2018 19:24:54 Windows Audio Session Devel DeviceDeleteList::wait_for_deletes - enter - DeviceDeleteList
    30/09/2018 19:24:54 Windows Audio Session Devel DeviceDeleteList::wait_for_deletes - leave - DeviceDeleteList
    30/09/2018 19:24:54 Windows Audio Session Debug WAS:penDevice-enter - {0.0.1.00000000}.{2023cb55-322d-4966-8bed-6f50e96318d7}
    30/09/2018 19:24:54 Windows Audio Session Devel Mix Format: SRate:48000 Bitrate: 32 Channels: 2 - Microphone (VIA HD Audio)
    30/09/2018 19:24:54 Windows Audio Session Devel Initializing with mix format. - Microphone (VIA HD Audio)
    30/09/2018 19:24:54 Windows Audio Session Devel Couldn't initialize AudioClient with given format: Access is denied. - Microphone (VIA HD Audio)
    30/09/2018 19:24:54 Windows Audio Session Devel Format detected: Multichannel capable Float - Microphone (VIA HD Audio)
    30/09/2018 19:24:54 Windows Audio Session Devel Format is supported. - Microphone (VIA HD Audio)
    30/09/2018 19:24:54 Windows Audio Session Error DEVICE_INITIALIZE: Access is denied. - Microphone (VIA HD Audio)
    30/09/2018 19:24:54 SoundBckndIntf Error C:/Program Files (x86)/TeamSpeak 3 Client/soundbackends/windowsaudiosession_win32.dll error: DEVICE_INITIALIZE
    30/09/2018 19:24:54 CapSoundSet Error Failed to open capture device when updating capture system: 2310
    30/09/2018 19:24:54 CapSoundSet Error Error setting PreProcessorConfigValues onPTTActivated: 2304
    30/09/2018 19:24:56 Windows Audio Session Devel DeviceDeleteList::wait_for_deletes - enter - DeviceDeleteList
    30/09/2018 19:24:56 Windows Audio Session Devel DeviceDeleteList::wait_for_deletes - leave - DeviceDeleteList
    30/09/2018 19:24:59 Windows Audio Session Devel DeviceDeleteList::wait_for_deletes - enter - DeviceDeleteList
    30/09/2018 19:24:59 Windows Audio Session Devel DeviceDeleteList::wait_for_deletes - leave - DeviceDeleteList
    30/09/2018 19:24:59 Windows Audio Session Debug WAS:penDevice-enter - {0.0.1.00000000}.{2023cb55-322d-4966-8bed-6f50e96318d7}
    30/09/2018 19:24:59 Windows Audio Session Devel Mix Format: SRate:48000 Bitrate: 32 Channels: 2 - Microphone (VIA HD Audio)
    30/09/2018 19:24:59 Windows Audio Session Devel Initializing with mix format. - Microphone (VIA HD Audio)
    30/09/2018 19:24:59 Windows Audio Session Devel Couldn't initialize AudioClient with given format: Access is denied. - Microphone (VIA HD Audio)
    30/09/2018 19:24:59 Windows Audio Session Devel Format detected: Multichannel capable Float - Microphone (VIA HD Audio)
    30/09/2018 19:24:59 Windows Audio Session Devel Format is supported. - Microphone (VIA HD Audio)
    30/09/2018 19:24:59 Windows Audio Session Error DEVICE_INITIALIZE: Access is denied. - Microphone (VIA HD Audio)
    30/09/2018 19:24:59 SoundBckndIntf Error C:/Program Files (x86)/TeamSpeak 3 Client/soundbackends/windowsaudiosession_win32.dll error: DEVICE_INITIALIZE
    30/09/2018 19:24:59 CapSoundSet Error Failed to open capture device when updating capture system: 2310
    30/09/2018 19:24:59 CapSoundSet Error Error setting PreProcessorConfigValues onPTTActivated: 2304
    30/09/2018 19:25:00 Windows Audio Session Devel DeviceDeleteList::wait_for_deletes - enter - DeviceDeleteList
    30/09/2018 19:25:00 Windows Audio Session Devel DeviceDeleteList::wait_for_deletes - leave - DeviceDeleteList
    30/09/2018 19:25:08 CapSoundSet Info Invalid captureDevice in Config File, (profile, captureDevice) = (Default, Microphone (VIA HD Audio))
    30/09/2018 19:25:17 Windows Audio Session Devel DeviceDeleteList::wait_for_deletes - enter - DeviceDeleteList
    30/09/2018 19:25:17 Windows Audio Session Devel DeviceDeleteList::wait_for_deletes - leave - DeviceDeleteList
    30/09/2018 19:25:17 Direct Sound Error CREATECAPTUREBUFFER: Unspecified error - {462EAE7B-7C8D-4966-BD6F-ADCEDAC56E89}
    30/09/2018 19:25:17 SoundBckndIntf Error C:/Program Files (x86)/TeamSpeak 3 Client/soundbackends/directsound_win32.dll error: CREATECAPTUREBUFFER
    30/09/2018 19:25:17 CapSoundSet Error Failed to open capture device when updating capture system: 2310
    30/09/2018 19:25:17 CapSoundSet Error Error setting PreProcessorConfigValues onPTTActivated: 2304
    30/09/2018 19:25:19 Windows Audio Session Devel DeviceDeleteList::wait_for_deletes - enter - DeviceDeleteList
    30/09/2018 19:25:19 Windows Audio Session Devel DeviceDeleteList::wait_for_deletes - leave - DeviceDeleteList
    6,079
    There is your reason.
    Microsoft, in their infinite wisdom, decided that they don't like people disabling microphone access to their shiny new app stuff. So, out of the blue, they also made that slider apply to all the regular applications with an update.
    You need to enable Microphone access in Privacy Settings. Just search for Privacy, click "Microphone Privacy Settings" and enable the "Allow apps to access your microphone" option. You can still leave all their fancy apps disabled in the list below if you prefer, just the main option needs to be enabled nowadays.
  1. What next? Starting over.
    By Avaryan in forum Linux / FreeBSD
    Last Post: February 24th, 2012, 09:19 AM
