Results 1 to 7 of 7
    July 2014
    24
    Put 2 Themes in 1
    Hey,
    I want to use the "Dark" Theme for my Teamspeak Client, but i need the "Extended Client Info" with it together.
    Is it possible to enable both or merge them into one?
    Thanks for your help
    18,513
    https://www.myteamspeak.com/d/Brady_The
    All of his styles offer extended information (disabled by default).
    July 2014
    24
    Yes, but that are not the Themes i want to use.
    I want to use this Theme: https://www.myteamspeak.com/addons/4...d-89dfa73a9b06 Together with extended Info
    Edit: I found out how to do this myself. I just copied the content of the extended client info theme into the dark theme folder.
    June 2018
    Poland
    101
    DerRene dunno if it is actually possible to use 2 themes in the same time. Maybe in ts 5 it will be available.
    18,513
    Using 2 themes the same time is not possible. You have to decide which one or you change the templates of one you like.
    November 2017
    181
    There is a feature request to add "extended info" templates to the "Dark" theme but nobody made any efforts to get them implemented yet.
    It's not one of the things I like to add support for since I honestly think that it's a bit of information overkill but if someone creates a fork I won't stop them.
    I'd love to have a way to define theme settings so optional features can be turned on and off via the GUI. But since TeamSpeak 3 is soon to be replaced anyway, the Dark theme is probably going to die soon anyway.
    August 2019
    It is possible! And its very easy!
    This is a step by step tutorial. (Sorry for my bad english)
    1. Go to C:\Users\YOURUSER\AppData\Roaming\TS3Client\styles \dark (Replace YOURUSER with your username)
    2. Delete clientinfo.tpl
    3. Replace it with this file (http://download1499.mediafire.com/vb...clientinfo.tpl)
    4. Then restart your teamspeak
    This will add: UID, DBID, Total connections, Last connection, First connection
    This file is the original file of the dark style I just added the external info table.
    This is how it looks like:
    Your welcome
  1. All themes lost?
    By boardinwelts in forum Windows
    Last Post: October 23rd, 2015, 08:23 AM
  2. Themes messed up after update
    By sotdyeti in forum Skins / Icon & Sound Packs
    Last Post: August 20th, 2015, 12:50 AM
  3. extensions themes
    By kloze in forum Off Topic
    Last Post: July 1st, 2013, 07:15 PM
