Results 1 to 10 of 10
    December 2018
    Problems with login / Sync
    I am not able to log in to the teamspeak application, there is always a failure and I get the message that you can see in the image https://i.imgur.com/zqCUjQu.png... this has been happening a long time since the last upgrade. this error only happens in version 3.2.3, when I download an earlier version of teamspeak I can log in without problems. many friends of mine are also with this problem ... I do not know if it is a problem of region because I am located in Brazil, can someone explain to me what is happening?
    ps.Sorry for the quality of the text, I used google translate.
    17,363
    Please read or show your client log.
    December 2018
    log copied when I started teamspeak and tried to login
    https://i.imgur.com/EJxvhfh.png
    17,363
    Looks like you can not reach our myTeamSpeak services. Possibly blocked by your host or a firewall.
    For my interest:
    Does this website https://www.myteamspeak.com/ work for you?
    December 2018
    I can't sync!
    Hello.
    I have a problem with ts3 client synchronization. The reinstallation of teamspeak and the system has no effect. Here are the logs:
    2018-12-07 16:49:38.650835|INFO    |              |   |TeamSpeak 3 Client 3.2.3 (2018-10-02 07:57:10)
    2018-12-07 16:49:38.650901|INFO    |              |   |SystemInformation: Linux 4.15.0-29-generic #31-Ubuntu SMP Tue Jul 17 15:39:52 UTC 2018 x86_64 Binary: 64bit
    2018-12-07 16:49:38.650927|INFO    |              |   |Using hardware aes
    2018-12-07 16:49:38.682071|DEBUG   |PulseAudio    |   |connected to pulse audio server -
    2018-12-07 16:49:38.699463|INFO    |ClientUI      |   |OpenGL Info: LibGL, Vendor: nouveau, Renderer: NV137, Version: 3.0 Mesa 18.0.5
    2018-12-07 16:49:38.699990|ERROR   |RevocationListCache|   |Failed to import revocation list from cache
    2018-12-07 16:49:38.728864|INFO    |Addons        |   |Checking for addon updates...
    2018-12-07 16:49:38.763956|INFO    |Plugins       |   |Loading plugin: libclientquery_plugin_linux_amd64.so
    2018-12-07 16:49:38.764803|INFO    |Query         |   |listening on 127.0.0.1:25639
    ClientQueryPlugin: currentServerConnectionChanged 1 (0)
    2018-12-07 16:49:39.060569|INFO    |              |   |*** Time [MAINWINDOW]: 258
    2018-12-07 16:49:39.060658|INFO    |              |   |*** Time [INIT]: 259
    2018-12-07 16:49:39.060844|DEVELOP |ClientUI      |   |Notifications init: Soundpack path: /home/webx/TeamSpeak3-Client-linux_amd64/sound/default
    2018-12-07 16:49:39.062660|INFO    |ClientUI      |   |Failed to init text to speech engine
    2018-12-07 16:49:39.062705|INFO    |ClientUI      |   |Qt version: 5.6.1
    2018-12-07 16:49:39.062735|INFO    |ClientUI      |   |Using configuration location: /home/webx/.ts3client/settings.db
    2018-12-07 16:49:39.529730|INFO    |Bookmarks     |   |Collecting autoconnect bookmarks
    2018-12-07 16:49:39.530194|INFO    |ClientUI      |   |Last update check was: pt. gru 7 17:46:38 2018
    2018-12-07 16:49:39.530495|INFO    |              |   |Statistics report: First run, report later in 1-30 days
    2018-12-07 16:49:39.530633|INFO    |              |   |Statistics report: Setting next report date to: sob. gru 22 17:49:39 2018
    2018-12-07 16:49:40.029887|INFO    |Newsticker    |   |Newsticker next check: sob. gru 8 17:46:54 2018
    2018-12-07 16:49:42.391919|INFO    |Addon         |   |Addon up to date.
    2018-12-07 16:49:48.373399|INFO    |              |   |successfully downloaded revocation list for myteamspeak id
    2018-12-07 16:49:48.377633|INFO    |              |   |successfully downloaded revocation list for accounting
    2018-12-07 16:49:49.142055|INFO    |Integrations  |   |Requesting integration icon download from https://ts3services.teamspeak.com/integration_icons/twitch/twitch.svg
    2018-12-07 16:49:52.123749|WARNING |ProtobufRPC   |   |Error contacting URL https://clientapi.myteamspeak.com/authentication: TIMEOUT
    QMetaObject::connectSlotsByName: No matching signal for on_queued_open_dialog()
    QMetaObject::connectSlotsByName: No matching signal for on_account_created(QString,QString)
    QLayout: Attempting to add QLayout "" to ProfileManager "", which already has a layout
    Installed Qt WebEngine locales directory not found at location /home/webx/TeamSpeak3-Client-linux_amd64/translations/qtwebengine_locales. Trying application directory...
    js: Unexpected number of download buttons in addon element.
    2018-12-07 16:50:22.133243|WARNING |ProtobufRPC   |   |Error contacting URL https://clientapi.myteamspeak.com/authentication: CANCELED
    2018-12-07 16:51:20.368740|ERROR   |SyncImpl      |   |Failed to resume syncing: not_initialized
    2018-12-07 16:51:24.442759|WARNING |Copy&Paste    |   |HTML parsing error: Opening and ending tag mismatch.
    2018-12-07 16:52:16.708673|WARNING |Copy&Paste    |   |HTML parsing error: Start tag expected.
    Last edited by dante696; December 10th, 2018 at 08:45 AM. Reason: merged. answer above this post also counts for you
    December 2018
    not working
    my sync doesn't work,please help me
    January 2019
    Can't Log In
    I'm trying to log in onto my teamspeak account but I keep getting the same error over and over:
    Failed to sign in. Try again later. It suddently happened, as I had used my teamspeak without any problem before. I've tried downloading a new version and it didn't work either. I'm on a Windows 10 OS.
    January 2019
    Canada
    Problem
    Had the same problem...
    January 2019
    For my interest:
    I have Similar problems and i can reach the Site but im always getting asked for Captchas.
    What really confuses me is that even my Rocket League servers are not Responding since then...cant connect same as with Teamspeak
    17,363
    So the issue is not Sync.
    It's something going on with your network or firewall.
