Results 1 to 2 of 2
    December 2018
    Port Issue (error codesystem:22 Invalid argument)
    I've decided to try and start a free license Teamspeak server on linux using PuTTY. I started it up with a simple command line after installing it:
    ./ts3server_startscript.sh start license_accepted=1
    Then, I connected and it worked fine. I asked for my friend to test it, and he couldn't connect to it. I assumed it was because I didn't have the 9987 port forwarded. Because I didn't want to open that port, I decided to try and change the port (and I reinstalled the server as that is what the internet told me to do). Then, I put in this command line (as my first starting line):
    ./ts3server_startscript.sh start license_accepted=1 default_voice_port=25567
    That seemed to not want to work, and gave this error message:
    2018-12-31 04:29:44.241967|ERROR |UDPServers | |could not bind * port 9987 error codesystem:22 Invalid argument
    2018-12-31 04:29:44.242112|ERROR |VirtualServer |1 |bind failed on *:9987
    2018-12-31 04:29:44.242394|CRITICAL|VirtualServerBase|1 |Could not bind virtual server address/port: 257 unable to bind network port
    That confused me, as it seemed like it was trying to connect to 9987 port still, when I was trying to change it to 25567 (a port I had open). So, I tried a view other command lines such as:
    ./ts3server_startscript.sh start license_accepted=1 default_voice_port=25567 voice_ip=*
    ./ts3server_startscript.sh start license_accepted=1 default_voice_port=25567 filetransfer_port=25566 filetransfer_ip=* query_ip=* query_port=25565 voice_ip=*
    And I also tried using ./ts3server_minimal_runscript.sh instead of ./ts3server_startscript.sh, and still received the same problem.
    So my question is, what is the problem, and how can I solve it? Thank you.
    18,151
    You did set * as IP, but is not a valid address.
    0.0.0.0 for IPv4 and :: for Ipv6 are valid addresses if you plan to assign all available addresses.
