Results 1 to 12 of 12
    April 2015
    132
    IPv6 not resolving
    If I connect my windows to a vpn server via ipv4, windows thinks that there is no ipv6 connection
    (I guess) TeamSpeak somehow checks the ipv6 connectivity by looking at what windows says -> TeamSpeak thinks there is no working ipv6 connection. Because of that, teamspeak refuses to look up AAAA-Records of domains
    I need to manually enter the ipv6 address to connect to a server that actually has a working domain
    Please implement other checks to see if IPv6 works instead of looking at what windows says. Windows is buggy regarding this and should not be considered as reliable source of information.
    My proposal:
    Prefer IPv6, no matter what windows says and if it doesnt work, use ipv4 OR TRY ipv6 if the domain has no A-Record although windows says ipv6 is not operational.
    April 2015
    132
    Why was this moved to client support? It is clearly a bug.
    17,718
    Can you offer us a client log?
    Quote Originally Posted by florian2833z View Post
    Not everything that user expect to work but result differs is automatically a bug.
    April 2015
    132
    This is what teamspeak says. Don't worry about the date. I was too lazy to create a thread back then, but it is the same problem.
    4,319
    I hereby certify this as a bug.
    April 2015
    132
    @dante696 can you forward this to the devs?
    6,061
    1/23/2019 12:15:20	ClientUI	Info	Connect to server: florian2833z.de
    1/23/2019 12:15:20	ClientUI	Info	Trying to resolve florian2833z.de
    1/23/2019 12:15:20	TSDNS	Info	A/AAAA DNS resolve for possible TSDNS successful, "florian2833z.de" =(h: 2a03:4000:29:1f1::1 p:0)
    1/23/2019 12:15:20	TSDNS	Info	A/AAAA DNS resolve successful, "florian2833z.de" =(h: 2a03:4000:29:1f1::1 p:0)
    1/23/2019 12:15:20	TSDNS	Info	SRV DNS resolve unsuccessful, "_tsdns._tcp.florian2833z.de" Domain name not found
    1/23/2019 12:15:20	TSDNS	Info	SRV DNS resolve unsuccessful, "_ts3._udp.florian2833z.de" Domain name not found
    1/23/2019 12:15:22	TSDNS	Info	TSDNS queried unsuccessfully 2a03:4000:29:1f1::1:41144
    1/23/2019 12:15:22	TSDNS	Info	No TSDNS found
    1/23/2019 12:15:22	ClientUI	Info	Lookup finished: ip=2a03:4000:29:1f1::1 port=9987 query=florian2833z.de error=0
    1/23/2019 12:15:22	ClientUI	Info	Resolve successful: [2a03:4000:29:1f1::1]:9987
    1/23/2019 12:15:22	ClientUI	Info	Initiating connection: [2a03:4000:29:1f1::1]:9987
    resolves just fine when connected to an IPv4 VPN since the domain seems to be IPv6 only.
    Are DNS lookups working for you using nslookup, without explicitly specifying the DNS server to use? Maybe the DNS server you're using only checks for IPv4 addresses on the domain.
    17,718
    We re-re-checked this and yes you are right.
    We use our own check and in this check we only ask A/AAAA for the detected network and do not ask for both protocols in that case.
    I create a ticket for this.
    Edit
    Moved ticket to new location. (Not directly a bug. More an important improvement).
    April 2015
    132
    Nice to hear, thank you.
    April 2015
    132
    When will this be changed?
    April 2015
    132
    Any updates ??
    17,718
    At this moment nobody can promise any date or client version for this.
  1. [No Bug] TS name resolving issue
    By cat24max in forum Bug Reports [EN/DE]
    Last Post: February 8th, 2017, 08:09 PM
  2. SRV does not seem to be resolving
    By hibird1 in forum Linux / FreeBSD
    Last Post: June 18th, 2016, 01:57 PM
  3. Resolving, but not connecting.
    By Wisbits in forum Windows
    Last Post: October 9th, 2014, 02:47 PM
  4. [Resolved] Resolving UNICODE Hostnames, 3 RC1
    By Letters in forum Windows
    Last Post: June 9th, 2011, 11:15 AM
