Page 1 of 2 12 LastLast
Results 1 to 15 of 18
    October 2013
    28
    After Update 3.7.0 users can't create temporary channels
    When I upgraded to version 3.7.0, users can not create temporary channel.
    17,809
    The easy dialog is not maintained and the server removed permissions that are still included in that outdated permission dialog.
    Please forget that easy permission dialog and activate the advanced one.
    You can do that under Tools -> Options -> Application.
    October 2013
    28
    How do I get it?
    he always remains unknown...
    No one can create a temporary room
    17,809
    Quote Originally Posted by daemoncesar View Post
    Yes and you can not change it. Please read my first reply.
    If that worked before add permission that allows user to use Opus as a codec
    b_channel_create_modify_with_codec_opusvoice
    October 2013
    28
    not work !
    17,809
    not work !
    These 2 words are not enough details.
    Give us a permission overview of the Guest group.
    October 2013
    28
    When updating to last version, all groups can not create temporary channel.
    17,809
    Yes you wrote that in first post and showed the easy permission dialog.
    And is permission b_channel_create_temporary set in these groups?
    I don't want guess your permissions.
    Please send a permissions overview.
    October 2013
    28
    I have 50 groups! Everyone is allowed wrong after upgrade
    17,809
    Telling me over and over again that user can not create temporary channels without giving me a permission overview won't help me to help you.
    We are turning in circles and i can't help you. When you give me nothing.
    So I ask one last time. Could you please give me a permission overview of at least one group?
    Activate the advanced permission system as explained in my first reply (post #2).
    Then do a right click on a user who can't create a temporary channel.
    Select Permission -> Permissions Overview.
    In that dialog select to show names (not description).
    Now press export as Text.
    Upload the file in your next post.
    October 2013
    28
ID:	17767Click image for larger version.
    3.7.1 again..
    October 2013
    28
    Server Groups
    	CONVIDADO
    		Use Privilege Keys to gain permissions 1 0 0
    		Channel Max Depth 1 0 0
    		Stop Channel Group Inheritance 1 0 0
    		Create Sub-Channels 1 0 0
    		Create Temporary Channels 1 0 0
    		Create Channels with Topic 1 0 0
    		Create Channels with Description 1 0 0
    		Create Channels with Password 1 0 0
    		Create Channels with Max Codec Quality 7 0 0
    		Create Channel with Minimum Latency Factor 1 0 0
    		Create Channels with Max Clients 1 0 0
    		Create Channels with Max Family Clients 1 0 0
    		Create Channels with Needed Talk Power 1 0 0
    		Channel Delete Power 60 0 0
    		Join Permanent Channels 1 0 0
    		Join Semi-Permanent Channels 1 0 0
    		Join Temporary Channels 1 0 0
    		Channel Subscribe Power -1 0 0
    		Icon ID 423885190 0 0
    		Group Auto Update Type 15 0 0
    		Show Group Name in Tree 1 0 0
    		Needed Group Modify Power 75 0 0
    		Group Member Add Power 75 0 0
    		Needed Group Member Add Power 75 0 0
    		Max number of additional connections per Identity 0 0 0
    		Max Channel Subscriptions -1 0 0
    		Needed ServerQuery Client View Power 75 0 0
    		Needed Client Kick From Server Power 25 0 0
    		Needed Client Kick from Channel Power 25 0 0
    		Needed Client Ban Power 25 0 0
    		Needed Client Move Power 25 0 0
    		Private Textmessage Power -1 0 0
    	All
    Client
    Channel
    	teste
    		Needed Channel Permission Modify Power 100
    		Needed Channel Delete Power 100
    Channel Groups
    	Guest
    		Group Auto Update Type 10
    Channel Client
    All
    	Needed Channel Permission Modify Power 100 0 0
    	Needed Channel Delete Power 100 0 0
    	Group Auto Update Type 10 0 0
    17,809
    Finally. That's what i asked for.
    As i did say before you need to allow Opus codec to be set from users or else no channel creation is possible.
    AAaaand please forget the easy permission dialog where Unknown is shown.
    November 2017
    Cologne, Germany
    166
    Wait... you ship the software with a permissions dialog which is known to be broken and advise people to not use it anymore? Wow. This company never stops to amaze me, in a negative way.
    17,809
    No the client was there before server was released and there was no new client release yet that could remove or fix the dialog.
    Before you mention client 3.2.5. This was a hot fix only and should not add anything else.
  1. [Not possible] Set Max Clients automatically on create Semi/Temporary Channels
    By barkbark in forum Permission System
    Last Post: June 22nd, 2016, 07:34 AM
  2. Issue with allowing users to create temporary channels
    By AmazeCPK in forum Permission System
    Last Post: December 17th, 2014, 08:00 AM
  3. How to: Channel users can create temporary sub channels only
    By Sgt.Trojan in forum Permission System
    Last Post: June 23rd, 2013, 01:39 PM
  4. Let users create temporary subchannel in one channel.
    By necrofrost in forum Permission System
    Last Post: November 11th, 2011, 03:58 PM
  5. Permission to allow clients to create temporary channels
    By specterm in forum Permission System
    Last Post: March 5th, 2010, 11:57 AM
