Results 1 to 12 of 12
    April 2019
    Ts3 Client won't open
    windows 10 64 bit
    Ts3 won't launch whatever i do, i've tried everything i found online but nothing helped.
    Whenever i try to launch Ts it just doesnt pop up, it shows up in the Task manager but won't open up.
    I've tried closing it using the Task manager, i reinstalled ~ 10times, I manually put all the .dll files into the folder, i reinstalled after deleting Teamspeak in %Appdata%, I legit tried everything.
    Please help.
    planing
    May 2007
    Eastern NC
    1,800
    Have you used TS3 on this computer before. If so, did the problem start following an update? If so, have you tried to reinstall the older client version to see if it then starts.
    What is the client version that is failing?
    Have you reviewed the client log for any errors or warnings?
    Could also use the -console parameter with the start command to see if the console shows and gives any additional details.
    May 2018
    Czech Republic
    43
    Try to start TeamSpeak in safe mode.
    Like this: https://bit.ly/2GFydBz
    May 2007
    Eastern NC
    1,800
    Quote Originally Posted by Ondra3211 View Post
    Yeah, forgot that was added a few years ago. But, if his uninstall was thorough should not be an issue of some random plugin messing with the client.
    May 2018
    Czech Republic
    43
    But when he has enabled plugin sync...
    May 2007
    Eastern NC
    1,800
    If the client never shows to sign into a myTeamSpeak account...
    April 2019
    I've used Ts in the past and I've never had problems while using it.
    Starting Ts in safemode didn't make it open.
    I've tried installing old versions before but that didn't work aswell.
    18,414
    Then it's a problem with your graphics driver or a VPN software hijacking the process. Yes this can crash the client....
    May 2007
    Eastern NC
    1,800
    Did you ever review the client log and see anything that could help, maybe note about graphics error or such?
    April 2019
    Where can i find that?
    April 2019
    Fixed
    I somehow fixed the issue. Thank you for your help, i appreciate it.
    May 2007
    Eastern NC
    1,800
    Quote Originally Posted by planing View Post
    I think with a default install it should be in ( %appdata%\TS3Client\logs ). But I think there are some install options that can change that. Been many years since I've done a clean install.
  1. Can't open teamspeak client
    By Huzzuni in forum Windows
    Last Post: April 4th, 2017, 05:46 PM
  2. When i install the client 64-bit, it won't open
    By The_GooD_OL_1-2 in forum Windows
    Last Post: May 16th, 2011, 09:32 AM
  3. Replies: 9
    Last Post: September 17th, 2010, 01:22 AM
