Results 1 to 4 of 4
    April 2019
    Port Conflict between Minecraft and Teamspeak 3
    Hey, I'm having an issue with port-forwarding a minecraft server while having a TS server running. Im pretty sure it's a port conflict. TS ports are 10011-30033 while minecraft is 19132-25565. Router said to check IP and Ports, now its just saying something went wrong.
    17,829
    Then please check your router manual.
    The mentioned ports are not the same so there is no conflict between them.
    Please do not check the ports from a website or with any tool. UDP will not reply a success.
    Check them by using the port with desired application instead.
    6,077
    Quote Originally Posted by Danohz View Post
    Those are not ranges (at least not for TS3), but individual ports instead. Not sure about Minecraft, but I think that would be a lot of ports for it, so you might want to check their manual for the ports used again as well.
    TS3 uses 10011 and 30033 for Query and Filetransfer respectively. Newer TS3 versions also use 10022 for SSH query. Of course all those can be changed to other ports.
    December 2004
    RF
    3,000
    Default MC server port is 25565/tcp. Only.
  1. Replies: 0
    Last Post: June 22nd, 2017, 07:28 PM
  2. Replies: 1
    Last Post: September 12th, 2014, 12:03 AM
  3. [request] minecraft teamspeak skin
    By Siegel2750 in forum Off Topic
    Last Post: July 25th, 2011, 03:36 PM
  4. [request] minecraft teamspeak skin
    By Siegel2750 in forum Skins / Icon & Sound Packs
