Results 31 to 45 of 59
  1. #31
    February 2017
    Australia
    103
    Quote Originally Posted by presenceofmind View Post
    I've notice new TS5 features been added to server version 3.7 and 3.8.
    For a development point of view this is a very bad idea.
    Let v3 continue getting updates without meshing of features with v5.
    And v5 development should be on it's own branch.
    Once TS5 is out, release a new server v5 with all the new features.
    I'm keeping my server on v3.6 until you guys sort this out.
    Cheers
    Wouldn't make any sense. Since both clients are going to operate on the same server systems, and a active beta test within reach (given to 100 random users), it makes sense that these users, and anyone else that would be in the programme down the line to be able to connect with stable versions of the server application, otherwise the beta test is next to useless due to dramatically low support rates.
    No one cares if you don't update, that's on you
  2. #32
    January 2018
    Quote Originally Posted by Scratch. View Post
    It does make sense. Users that decide use only v3 will be affected by the work done on v5 including all the overhead needed.
    The fact v5 is back compatible is not a reason to keep together.
    If you need to test, deploy v5 somewhere else and update the url. A Dev would understand.
    BTW are you from dev team?
  3. #33
    18,020
    User with a TS3 client are not effected by the TS5 features in the server.
    And it's like Scratch said having this in one server is the best way or we would have to split TS3 from TS5 users.
    We understand your sorrows but there is no reason to have these
  4. #34
    January 2018
    I 'm pretty sure they will. The new releases will require new libraries and more hardware to support v5.
    It will happen sooner or later. The fact that devs are changing v3 with v5 mindset is a recipe for disaster.
    Also compatibility issues with the different client apps. And all the extra work testing required for v3 and v5 per release.
    Sooner you split, easier will be to manage this in the future.
    And from what you said, if at this stage, v5 is not affecting v3, it should be easy to release a new clean v3.
    Once v5 beta is ready, have a new link to v5 in the download page with proper installation guides.
    It's really quite straight forward.
  5. #35
    June 2019
    No query information and privilege key on installation
    Hello there
    I've just bought a new VPS Server with Debian 9 Stretch and wanted to install my Teamspeak 3 Server on it and load my Snapshot.
    I tried to install the server for 4 times and I always had the same problem. After I used
    ./ts3server_startscript.sh start
    the Server started but I dind't got the privilege key and the query login. I also looked trough the logs and even found a privilage key but that one didn't even worked. I always got the pop up in Putty with all the informations before, but now it just doesn't show up anything
    I hope someone can help me.
    Best Regards
    Luca
  6. #36
    April 2014
    [QUOTE=Ragyal;470114]
    ./ts3server
    does not do anything...
    same problem for me on Ubuntu 16.04.2
    ldd --version
    ldd (Ubuntu GLIBC 2.23-0ubuntu11) 2.23
    ldd ts3server
    	linux-vdso.so.1 =>  (0x00007fff0c597000)
    	libts3_ssh.so => /home/gameserver/ts3update/teamspeak3-server_linux_amd64/./libts3_ssh.so (0x00007f9d59fd9000)
    	libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f9d59dc9000)
    	librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f9d59bc1000)
    	libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f9d598b7000)
    	libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f9d5969a000)
    	libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f9d59318000)
    	libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f9d58f4d000)
    	/lib64/ld-linux-x86-64.so.2 (0x000055e1eab91000)
    	libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f9d58d37000)
  7. #37
    August 2014
    111
    Hello, I reinstalled my Linux server 18.04 and noticed a big problem during the installation of TeamSpeak server, starting the server no information Query password.
    cordially
  8. #38
    June 2019
    Not able to start server
    i have the same problem like Ragyal. Any solution?
    Quote Originally Posted by Ragyal View Post
    ./ts3server
    [email protected]:/usr/local/teamspeak3/dev/teamspeak3-server_linux_amd64$ ldd ts3server
            linux-vdso.so.1 =>  (0x00007ffe47fe4000)
            libts3_ssh.so => /usr/local/teamspeak3/dev/teamspeak3-server_linux_amd64/./libts3_ssh.so (0x00007f68bf91a000)
            libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f68bf70f000)
            librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f68bf507000)
            libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f68bf1fd000)
            libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f68befe0000)
            libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f68bec5e000)
            libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f68be893000)
            /lib64/ld-linux-x86-64.so.2 (0x00005637b2a1f000)
            libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f68be67d000)
  9. #39
    January 2018
    Good Morning,
    Teamspeak Server 3.8.0
    Debian 9
    I can endless start the Teamspeak Session
    [email protected] teamspeak $ ./ts3server_startscript.sh start
    Starting the TeamSpeak 3 server
    TeamSpeak 3 server started, for details please view the log file
    ts3server.pid found, but no server running. Possibly your previously started server crashed
    Please view the logfile for details.
    [email protected] teamspeak $ ./ts3server_startscript.sh stop
    No server running
    ts3server.pid found, but no server running. -----> but Server is running
    Logs after start are the same:
    2019-06-12 07:51:16.990391|INFO    |ServerLibPriv |   |TeamSpeak 3 Server 3.8.0-beta2 (2019-05-14 10:49:31)
    2019-06-12 07:51:16.990486|INFO    |ServerLibPriv |   |SystemInformation: Linux 4.9.0-9-amd64 #1 SMP Debian 4.9.168-1+deb9u2 (2019-05-13) x86_64 Binary: 64bit
    2019-06-12 07:51:16.990510|INFO    |ServerLibPriv |   |Using hardware aes
    2019-06-12 07:51:16.991098|INFO    |DatabaseQuery |   |dbPlugin name:    SQLite3 plugin, Version 3, (c)TeamSpeak Systems GmbH
    2019-06-12 07:51:16.991124|INFO    |DatabaseQuery |   |dbPlugin version: 3.11.1
    2019-06-12 07:51:16.991459|INFO    |DatabaseQuery |   |checking database integrity (may take a while)
    2019-06-12 07:51:17.015885|WARNING |Accounting    |   |Unable to open licensekey.dat, falling back to limited functionality
    2019-06-12 07:51:17.016014|INFO    |Accounting    |   |Licensing Information
    2019-06-12 07:51:17.016034|INFO    |Accounting    |   |licensed to       : Anonymous
    2019-06-12 07:51:17.016045|INFO    |Accounting    |   |type              : No License
    2019-06-12 07:51:17.016061|INFO    |Accounting    |   |starting date     : Tue Jan  1 00:00:00 2019
    2019-06-12 07:51:17.016073|INFO    |Accounting    |   |ending date       : Fri Jan 31 00:00:00 2020
    2019-06-12 07:51:17.016084|INFO    |Accounting    |   |max virtualservers: 1
    2019-06-12 07:51:17.016093|INFO    |Accounting    |   |max slots         : 32
    2019-06-12 07:51:17.184027|INFO    |              |   |myTeamSpeak identifier revocation list was downloaded successfully - all related features are activated
    2019-06-12 07:51:17.516119|ERROR   |Accounting    |   |local accounting reports an already running instance, instance will shutdown
    2019-06-12 07:51:18.393420|INFO    |              |   |Puzzle precompute time: 1347
    2019-06-12 07:51:18.393755|ERROR   |FileManager   |   |bind failed on 0.0.0.0:30033; reason: Die Adresse wird bereits verwendet
    2019-06-12 07:51:18.393793|CRITICAL|VirtualSvrMgr |   |Could not start file manager 258 no network port available
    I test it with 3.8.0-beta2 and 3.8.0
    I run this Script against "crashes"
    #!/bin/bash
    TEAMSPEAK=`ps ax | grep ts3server_linux_amd64 | grep -v grep | wc -l`
    if [ $TEAMSPEAK -eq 1 ]
    then
    exit
    else
    cd /home/ts3/teamspeak/ ; ./ts3server_startscript.sh start
    fi
    I only noticed it today now i have over 1900 LogFiles ;D
    I hope you can reproduce the Problem
    Greetings
  10. #40
    18,020
    We can reproduce this and we will fix this in server 3.9.0
    Original report -> https://forum.teamspeak.com/threads/140141
    for those who reported that the server does not start
    Please post the output from
    ldd --version
    u name -a    (remove the space between u and name before you use the command. and add it again when you try to post the result.)
  11. #41
    January 2018
    ldd --version
    u name -a    (remove the space between u and name)
    Ok Thank you, i fix it.
    Sorry i read only this Thread here
  12. #42
    February 2017
    14
    ldd --version
    After some trouble with Cloudflare (doesn´t like u name without space):
    [email protected]:/usr/local/teamspeak3$ ldd --version
    Copyright (C) 2016 Free Software Foundation, Inc.
    This is free software; see the source for copying conditions.  There is NO
    warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
    Written by Roland McGrath and Ulrich Drepper.
    [email protected]:/usr/local/teamspeak3$ u name -a
    Linux h1234567.stratoserver.net 4.4.0-042stab138.1 #1 SMP Wed May 15 09:33:10 MSK 2019 x86_64 x86_64 x86_64 GNU/Linux
  13. #43
    18,020
    Thanks. Everything looks fine :/
    Can you try following?
    Download the server again and overwrite the old installation.
    Install a fresh server on a new location (do not add anything else and do not use an existing database).
  14. #44
    February 2017
    14
    Like that?
    Attached Files Attached Files
  15. #45
    18,020
    On fresh install please try to start the server without the startscript
    ./ts3server license_accepted=1
  1. [Discussion] TeamSpeak Server 3.6.x
    By dante696 in forum Suggestions and Feedback
    Last Post: March 19th, 2019, 01:58 PM
  2. [Discussion] TeamSpeak 3 Server 3.3.0 & 3.3.1
    Last Post: September 6th, 2018, 07:58 PM
  3. [Discussion] TeamSpeak 3 Server 3.2.0
    Last Post: July 19th, 2018, 09:34 AM
  4. [Discussion] TeamSpeak 3.1.1 Beta Discussion
    Last Post: February 10th, 2017, 05:02 PM
  5. [Discussion] TeamSpeak 3 Server 3.0.12.*
    By Dream in forum Suggestions and Feedback
    Last Post: April 5th, 2016, 10:18 PM
