Results 1 to 2 of 2
    June 2019
    Require help with group permissions: not allowing to add groups to user
    I am unable to setup permissions where group X can give group Y.
    Here's what is currently setup:
    - Group X has the following permissions set:
    - i_group_modify_power [75] [] [] [75]
    - i_group_member_add_power [70] [] [] []
    - i_client_permission_modify_power [70] [] [] [75]
    - Group Y has the following permissions set:
    - i_group_needed_modify_power [68] [] [] []
    - i_group_needed_member_add_power [68] [] [] []
    - i_client_needed_permission_modify_power [68] [] [] []
    But whenever I try adding group X to a member with no roles I get:
    - <15:19:09> insufficient client permissions (failed on i_client_needed_permission_modify_power)
    Any help would be appreciated.
    August 2015
    55
    That should help you further:
    https://forum.teamspeak.com/threads/...274#post412274
    What is your i_permission_modify_power? That could cause the problem if I should be awake enough. Otherwise the link helps you to figure it out for yourself hopefully. Just let me know please since I am looking after one or two actions of TS3 which don't make much sense in their error response.
    Cheers
    Last edited by lightpsycho; June 24th, 2019 at 06:53 PM. Reason: minor change, forgot something
  1. [Not possible] Possible that members of a group can't assign groups to another user but themselves?
    By FatalBulletHit in forum Permission System
    Last Post: April 6th, 2016, 02:35 PM
  2. Replies: 4
    Last Post: December 10th, 2015, 02:44 AM
  3. Replies: 2
    Last Post: February 11th, 2012, 11:11 PM
  4. [Resolved] Allowing certain groups to issue specific group privileges
    By Boby360 in forum Permission System
    Last Post: September 11th, 2011, 06:09 AM
  5. Allowing only server admins to change user's groups
    By numbers1thru9 in forum Permission System
    Last Post: March 13th, 2010, 03:35 PM
