Results 1 to 6 of 6
    July 2019
    Need help to fix permission
    For a long time I've been starting the server as root, but today after a reboot I tried to start with a simple user as suggested by the startscript.
    So I logged as "server", and tried to start the script, and there was Permission denied :
    ./ts3server_startscript.sh: line 48: ts3server.pid: Permission denied
    ERROR: openFile( file:logs/ts3server_2019-07-02__11_34_40.221012_0.log) failed
    2019-07-02 11:34:40.230116|CRITICAL|ServerLibPriv |   |Server() DatabaseError unable to open database file
    Here is my directory :
    HTML Code:
    ll
    total 53756
    drwxr-xr-x 9 root   root       4096 Jul  2 13:34 ./
    drwxr-xr-x 5 server server     4096 May 26 11:59 ../
    -rw-rw-r-- 1 server server    57370 Jul 31  2018 CHANGELOG
    drwxr-xr-x 3 root   root       4096 Aug 16  2018 doc/
    drwxr-xr-x 4 root   root       4096 May 14  2018 files/
    -rw-r--r-- 1 root   root    4521984 May 14  2018 latest.tar.gz
    -rwxr--r-- 1 server server  1000888 Jul 31  2018 libts3db_mariadb.so*
    -rwxr--r-- 1 server server  2191496 Jul 31  2018 libts3db_sqlite3.so*
    -rwxrwxr-x 1 server server   914160 Jul 31  2018 libts3_ssh.so*
    -rw-rw-r-- 1 server server    68141 Jul 31  2018 LICENSE
    -rw-r--r-- 1 root   root       1631 Mar  1 19:39 licensekey.dat
    drwxr--r-- 2 root   root       4096 Jul  2 13:28 logs/
    -rw-r--r-- 1 root   root          1 May 14  2018 query_ip_blacklist.txt
    -rw-r--r-- 1 root   root         10 May 14  2018 query_ip_whitelist.txt
    drwxr-xr-x 2 root   root       4096 Aug 16  2018 redist/
    -rw-r--r-- 1 root   root        112 May 14  2018 serverkey.dat
    drwxr-xr-x 2 root   root       4096 Aug 16  2018 serverquerydocs/
    drwxr-xr-x 5 root   root      12288 Aug 16  2018 sql/
    -rwxrwxr-x 1 server server 11278528 Jul 31  2018 ts3server*
    -rw-r--r-- 1 root   root          0 Aug 16  2018 .ts3server_license_accepted
    -rwxr--r-- 1 root   root    6102328 May 14  2018 ts3server_linux_amd64*
    -rwxr--r-- 1 server server      129 Jul 31  2018 ts3server_minimal_runscript.sh*
    -rw-r--r-- 1 root   root     850944 Jul  2 13:34 ts3server.sqlitedb
    -rwxr--r-- 1 server server     2661 Jul 31  2018 ts3server_startscript.sh*
    -rwxrwxrwx 1 root   root         64 May 14  2018 ts3server_upstart.sh*
    drwxr-xr-x 2 root   root       4096 Aug 16  2018 tsdns/
    -rw-r--r-- 1 root   root   27967432 May 14  2018 webmin_1.780_all.deb
    Thanks for the help !
    18,396
    Please do not use the root login to run the server. Doing that is not supported.
    Please create a new non root user and then install the server for that user.
    Here you can read what files you need to move/copy in case you want to get the all server settings and files back on the new location
    https://forum.teamspeak.com/threads/103745
    July 2019
    Yep,
    That's why I'm here actually : to not start the server as root.
    Is there a solution to fix permissions instead of a clean install?
    If not, I'll do a clean install in the next days...
    I could update Ubuntu too, is Ubuntu 18.04 supported?
    Thanks for you answer!
    18,396
    You don't have to do a clean install.
    Just create a new user and extract the server there. Then transfer the files mentioned in the link to this new server folder.
    Yes 18.04 is supported.
    Ps. Fixing permissions on your system is not what we are here for.
    You need to use a manual or their support to get this solved.
    July 2019
    Ok thanks!
    May 2013
    8
    You need to change the owners of the files to the server user. Use the following command as root in the server directory:
    chown -R server:server *
    That should solve the permissions error.
  1. [Resolved] Channel Admin permission overwrite group permission
    By spyder25000 in forum Permission System
    Last Post: February 22nd, 2015, 04:25 AM
  2. Replies: 1
    Last Post: September 5th, 2011, 03:03 PM
  3. Replies: 1
  4. Replies: 2
    Last Post: January 30th, 2011, 09:03 PM
  5. Replies: 9
    Last Post: February 13th, 2010, 02:08 PM
