Results 1 to 6 of 6
    February 2016
    7
    Teamspeak work 5 min and Crash..
    [[email protected]]# 2019-07-08 19:06:41.184708|CRITICAL|Client        |1  |Assertion "m_ClientDBID != 0" failed at ../../../../deps/teamspeak_common_lib/src/chanclients/client.cpp:256;
    ts3server has crashed. A crashdump has been generated at "/home/ts3/crashdumps/ts3server_3_9_1_linux_amd64_2d02-c178-4839-9dc1.dmp"
    I am asking for help what to do in this matter. Teamspeak has been updated to the new version, it worked 5 min and got a crash.
    Thanks for help!
    18,119
    There aren't more errors in the log? I saw several such errors before when database had errors. And i don't think this is a coincidence when your other topic on same day is about mariaDB.
    Just Posting the name of the crashdump isn't enough. With a URL to download it we can't say anything.
    February 2016
    7
    mysqldump: Error 1194: Table 'client_properties' is marked as crashed and should be repaired when dumping table `client_properties` at row: 327524
    2019-07-08 19:05:36.671080|ERROR |DatabaseQuery | |failed asynchronously executing 'update clients set client_lastconnected=1562612736, client_totalconnections=client_totalconnections+1, client_lastip='xxx.24.xxx.66' where client_id=401347 and server_id=1;': database error
    2019-07-08 19:05:39.092901|ERROR |DatabaseQuery | |db_exec() update clients set client_lastconnected=1562612738, client_totalconnec error: Incorrect key file for table './ts3/clients.MYI'; try to repair it
    2019-07-08 19:05:39.092975|ERROR |DatabaseQuery | |failed asynchronously executing 'update clients set client_lastconnected=1562612738, client_totalconnections=client_totalconnections+1, client_lastip='xx.191.xxx.134' where client_id=403977 and server_id=1;': database error
    2019-07-08 19:05:42.915596|ERROR |DatabaseQuery | |db_exec() update clients set client_lastconnected=1562612742, client_totalconnec error: Incorrect key file for table './ts3/clients.MYI'; try to repair it
    2019-07-08 19:05:42.915678|ERROR |DatabaseQuery | |failed asynchronously executing 'update clients set client_lastconnected=1562612742, client_totalconnections=client_totalconnections+1, client_lastip='xxx.181.xx.2' where client_id=401187 and server_id=1;': database error
    2019-07-08 19:06:41.184118|ERROR |DatabaseQuery | |db_exec() insert into clients( server_id, client_unique_id, client_nickname, error: Duplicate entry '408813' for key 'PRIMARY'
    File crash.dmp no cant open ;/ i send you via pw.
    Best Regards
    18,119
    That explains the crash. Your database is messed up.
    February 2016
    7
    Thanks for your help!
    btw:
    Is it possible to convert a mysql database to a standard teamspeak database? Of course, I will pay for the database conversion. So what can be fixed? how?
    Best Regards
    July 2019
    Do you need help with conversation or cleaing the database?
    Best regards from suisse
    neolium
  1. [Resolved] teamspeak 3 application android crash crash crash
    By hycksou in forum Android
    Last Post: July 5th, 2017, 06:05 PM
  2. Does my Teamspeak work?
    By StuffedTurtle in forum Server Support
    Last Post: January 2nd, 2014, 07:35 PM
