Have someone a downloadlink for the new teamspeak? I cant find it
Consider adding persistant chat for channels. This would certainly be a plus!
Just showing the mods/staff here the nature of reality - they really NEED to give Teamspeak the ability to join without download... I'm sure they know it, but they really need to act on it, it's a huge loss on gaining people to use Teamspeak I literately have to go through a few people before I find one that's willing to try it sometimes I even have to show them the TS5 Trailer just to show them that it will get better soon.
1. Beta 16 is nicht mehr releavnt. Bitte auf Beta 18 updaten und zur not dein Cache und/oder deine Config löschen, falls du noch immer nicht in den Messenger kommst.
2. Ist bekannt und dagegen kanst du im Moment nichts tun. Das müssen wir noch verbessern.
3. Auch bekannt ->> https://forum.teamspeak.com/threads/142271
Wir können im Moment nicht viel zu sagen. Evtl. liegt es aber am Fehlendes SSE 4.2 support.
Ja tatsächlich ist die Beta eine Beta.
hmm sagt jetzt nicht sehr viel aus. Siehe Oben.
This is something to consider, a web client could come in handy. Perhaps as a feature post-release of TeamSpeak "5", as the main base would still stick to the client due to a much better optimisation.
There's a good chance that a considerable part of these "why download TeamSpeak when there's Discord" already have Discord client and they don't even realise that... Kind of sad, but that gives me a thought.
The installation process of the new TeamSpeak client should be as streamlined as possible for the most convenient user experience.
Moin,
I do know that TS5 is more feature rich and probably requires more memory, and this may be a single user issue.
Leaving the client open for multiple days has the memory usage creeping up, it has gotten better since the last couple of updates (with Beta 16 I ended up with a 2GB TS5 client) while the current one seems to settle around 600MB - allthough I did see it jump from 1GB back down to 600MB.
Just wanted to leave this here.
Cheers,
Patrick
Ich habe jetzt mehreren Leuten den Vergleich zu Teamspeak 5 und Teamspeak 3 im TS3 gezeigt vom Klangbild.
Einige meinten, dass Teamspeak 5 viel lauter ist als Teamspeak 3 und teilweise sogar übersteuern würde.
Meine Einstellungen:
Mikrofon: Neumann TLM 102
Mischpult: Allen & Heath Zed 10
Kompressor: dbx 286 S
Ich hatte nebenbei Audacity auf Record laufen um auszuschließen, dass das übersteuern von mir kommt. Dies kann ich zu 100% ausschließen. Beim Wechsel auf Teamspeak 3 wäre es wieder normal gewesen. Es scheint nicht so extrem zu sein, aber ich wollte das Feedback dennoch mal loswerden. Vllt könnt ihr damit ja was anfangen.
Die Noise Reduction habe ich auf "low" gestellt, weil ich bereits eine in Geräteform im dbx 286S habe.
Und Automatic Gain Control is für mich auch Useless weil ich mit dem Setup perfekt ausgesteuert bin. Das ist mehr was für Leute die nicht wissen wie man sein Mikrofon einstellt
Es ist allerdings Möglich, dass manche Leute ihr Teamspeak nicht richtig eingestellt hatten (zum Beispiel +3 in der Overall Lautstäke) Dann ist es natürlich klar, dass es knallt und übersteuert. Ich bin kurz vor knapp bei 0 eingepegelt. Der Kompressor sorgt dafür, dass ich niemals über 0 komme. Also unmöglich, dass ich übersteuere.
Grüße,
Nikolaj
Du kannst doch einfach oben in der Suchleiste die Adresse eingeben und auf Quick Connect drauf klicken.
... und wenn du den Server abspeichern willst, dann oben auf Add To Bockmark klicken.
Mein Vorschlag wäre ein DropDown-Menü für das Bookmark-Icon, wo man zwischen "schnell abspeichern" und "einrichten" auswählen kann.
Man kann dann noch ein Remove-Button einfügen, der beim Hinzufügen evtl. dann ausgeblendet/nicht angezeigt wird.
"einrichten" soll dann einfach die vorhandene Einstellung links in der Leiste abrufen, wo man aktuell den Bookmark einstellen kann.
Also muss man da nicht mit extra Fenster etc. kämpfen.
Beispiel:
...oder man das ganze theoretisch auch in den Settings umstellen kann, ob der Button entweder schnell einträgt oder konfiguriert.
