Results 1 to 2 of 2
    July 2019
    Client kick permission and group modify permission.
    So im having this issue that if someone has the permission to modify a group, they can give that group kick permission of much higher than the group modify permission grants, or anything else I can find for that matter. Am I missing something here or is it a bug?
    Example: Admin has permission of group modify power 75, and it itself is needed 75. Server admin (meant to be above) has 100 and 76. Now Admin should not be able to kick server admin, therefore admin has 75 kick power, and server admin needs 76. But admin can change its kick permission to be 100. Why is this???
    Screenshots attached.
ID:	18115   Click image for larger version.
    18,144
    This is OK by design. For most permissions the value can have a value from -999999999 up to 999999999 as long you are allowed to modify target permission.
    To prevent that user cheat their self into groups the server will only deny when you try to raise your add power or modify powe(s) with a value above your own.
    You have to disable that your Admin can change his kick power. You need to remove their Grant value on that permission or you lower the group modify power below their own one.
    But in last case they still can assign the permission to their client.
  1. [Not possible] Group permission to modify just special group client description
    By TomberWolf in forum Permission System
    Last Post: September 30th, 2016, 10:42 AM
  2. No Group has permission to modify groups.
    By Sleipner in forum Permission System
    Last Post: September 5th, 2016, 12:44 PM
  3. Insufficient permission and group modify powers
    By andyc2d in forum Permission System
    Last Post: June 24th, 2016, 07:56 AM
  4. [Not possible] Increasing group modify and client permission modify above 75
    By Warith in forum Permission System
    Last Post: September 20th, 2015, 02:44 PM
  5. Channel permission modify - by a server group
    By Archaeopteryx in forum Permission System
    Last Post: May 11th, 2014, 06:10 AM
