Results 1 to 4 of 4
    August 2019
    My Microphone volume seems to reset every time I open Teamspeak
    Okay, so this has just started happening recently, but every time I open Teamspeak, my microphone becomes extremely quiet and my guild-mates can no longer hear me. I have checked every setting possible that might be affecting this, but I simply cannot find an answer.
    I have windows set to not do anything when communications happens, my microphone is boosted (which seems to be what TS is changing), I haven't allowed applications to take exclusive control of my mic and automatic voice game control isn't enabled in TS.
    What I think is happening is that TS is somehow messing with my microphone boost level in sound settings, without changing the slider value, because to fix the issue, I generally just move the slider for boost up to 30 dB then back down to 20 dB and it works until I close TS.
    Does anyone have any suggestions for a permanent fix?
    18,112
    My guess -> Your microphone is quiet in general and it always takes a while for AGC till volume got corrected.
    Quote Originally Posted by Sintry View Post
    No, we do not touch any microphone settings.
    August 2018
    DE
    17
    If you're using the Windows 10 1903 update, it could be their mixer feature that gives you some trouble. Try to set your mic as default for TeamSpeak und check if the levels are correct there...
    August 2019
    So why is it only happening when Teamspeak starts? the volume is absolutely fine before I open TS and I listen to the microphone, then as soon as I open TS and listen again, it drops considerably and then I have to mess with the boost levels to fix it. It suppresses when TS starts.
  1. Microphone not working in Steam and Teamspeak at the same time
    By Fandens_oldemor in forum Client Support
    Last Post: May 17th, 2016, 02:11 PM
  2. Teamspeak 3 client takes long time to open
    By w24ts in forum Windows
    Last Post: May 3rd, 2015, 10:52 AM
  3. Replies: 2
    Last Post: December 27th, 2012, 02:30 PM
  4. Reset other program volume
    By seth0351 in forum Windows
    Last Post: April 19th, 2011, 07:32 AM
