Results 1 to 5 of 5
    August 2019
    Santa Rita / Paraíba
    Icon do not appear
    I have this problem in ts will be 3 months ago, I emailed support for ts android said it was my phone but I'm not the only one having this problem, some friends of mine using the same platform are having the same problem , since you updated it in April / June, it's like this.
    My phone version: Motorola Moto G2 XT1068
    GPU Adreno 305
    Chipset Snapdragon 400 Qualcomm MSM8226
    Android 6.0 Marshmallow
    18,513
    Could be anything with that description.
    Server has SVG type that the client does not support or server has no port opened or files got deleted from server.
    Or something on your phone blocks the download or deletes them from cache.
    You should try with a PC client (with empty cache) and check the errors in case you do not get icons there.
    June 2018
    Poland
    101
    I think it's a android bug. I also cannot see 1 icon on my own server which is visible on PC without any problems.
    18,513
    As said when that icon is a SVG then there is a change the the type isn't supported.
    September 2018
    Not showing server icons on TS Android
    Hello, I dont know if this is normal, but I think it wasnt always like this. The problem is that my Server Icons are not showed on my mobile (Android TS), but I can see them normal on PC (Windows TS). Any ideas how to change it so I could see them also on mobile ? I attach screen from both devices
ID:	18686   Click image for larger version.
  1. Use Icon pack icon as plugin menu icon
    By Bluscream in forum Client Plugins / Lua Scripts
    Last Post: March 19th, 2017, 04:04 PM
  2. [Not possible] Overwolf icon next to users doesn't change in icon pack
    By Davvos11 in forum Skins / Icon & Sound Packs
    Last Post: February 24th, 2016, 08:49 AM
  3. Replies: 2
    Last Post: December 30th, 2015, 02:11 PM
  4. [Resolved] Overriding default group icon with user icon
    By Quantax in forum Permission System
    Last Post: January 28th, 2012, 11:21 AM
  5. [Resolved] Overriding default group icon with user icon
    By Quantax in forum Client Support
