Results 1 to 4 of 4
    August 2019
    Correct ID of Identity
    Hello, i notice that the ID that i can copy from the permissions list is most short than the file i export from identity list for make the backup, i mean when i open the .ini file with block notes.
    Well there i have very long ID but in ts permission list i got only short "version".
    Its some way there for have the long ID by the short ID?
    18,507
    ID & the Identity are 2 different things.
    The Client ID is used for current connection.
    The Client Database ID (the one you see in permissions) is the one where your client is stored under in your database. It depends on how many other such DB Ids did exist when user joined the first time.
    The Identity is used to identify the client on your server and to assign him right permissions again as an example.
    August 2019
    I need this for help a friend that have accidentally delete the main identity used for connect in any ts. I have his unique ID that i got by permissions list on my teamspeak, with this one i can got the ID that i need for paste it on .ini file for then import it on Identities window?
    18,507
    The ID or UID you see in the server won't help.
    Only when you friend has a local backup or exported his identity in the past will get it back.
  1. Replies: 1
    Last Post: March 14th, 2017, 10:28 AM
  2. Replies: 6
    Last Post: July 8th, 2014, 04:09 AM
  3. I don't have the correct permissions
    By MissSadPanda in forum Android
    Last Post: April 17th, 2014, 09:14 AM
  4. PTT donīt work correct
    By FroschBT81 in forum Windows
    Last Post: July 28th, 2011, 09:20 AM
