Results 1 to 1 of 1
    September 2019
    Unknown connectivity issues
    So. im experiencing some problems running my teamspeak server, i figured i would start with diagnosing the teamspeak
    Teamspeak Server Version : 3.9.1
    Server Info Windows Server 2012R2 64 Bit - fully up-to-date
    Windows Firewall and Defender turned off.. but it is behind a hardware firewall with proper port forwarding setup.
    Im starting with diagnosing teamspeak server, because i notice other connectivity issues, however they are with Virtual Machines, with additional routing, and the Teamspeak server, runs on the main/root physical machine, on the Windows 2012 server OS...
    So, after a while i have to restart this server, and teamspeak will reconnect and work fine for an amount of time and randomly it will start to have connection issues. I have attached a screenshot with a TS Client, and WireShark showing incoming UDP packets, as well, it shows a connection/disconnection and the problem persisting...
    I would like to find out and understand what may be causing this... to me the packets are arriving at their destination and should be responded too...
  1. weird connectivity issues
    By volapiik in forum Client Support
    Last Post: May 3rd, 2017, 09:09 PM
  2. TS3ANetwork Connectivity Issues
    By amw_drizz in forum Server Support
    Last Post: March 10th, 2015, 11:43 PM
