Results 1 to 2 of 2
    6,080
    [Pre-Release] TeamSpeak 3 Client 3.5.0
    We have released a new beta version of the TeamSpeak 3 Client.
    This update enables you to connect to the free servers created within the TS5 client. Additionally we have backported some of the audio improvements from the TS5 client for you to enjoy while you're waiting to get access to the all new client.
    Please see the full changelog below:
    === Client Release 3.5.0 - 31 Oct 2019
    + Added automatic voice volume leveling option in playback settings.
    + Added comfort noise feature to add synthetic background noise to fill the
      artificial silence while being connected to a TeamSpeak Server.
    + Added support for upcoming TeamSpeak Server releases using a PostgreSQL
      database backend.
    * Improved echo cancellation and noise reduction systems.
    - Fixed crashes reported by crashdumps.
    To enable beta updates, simply go to Tools -> Options -> Application and select "Beta" from the update channel dropdown.
    Once done you can check for updates using Help -> Check for Updates to receive the update.
    If you have any comments or experience issues feel free to drop us a line here.
    18,264
    We released a new beta.
    - That one does fix a memory leak (from old 3.5.0 beta) when other users did speak.
    - And the release adds new settings for capture when using VAD.
    When updating old capture profiles the client will select Volume Gate.
    Automatic is selected for users without old config or when a new profile was created.
    (A short explanation for these modes will be added in stable client update.)
    What is new in change log (full change log can be found in post #1)
    === Client Release 3.5.0 - 18 Nov 2019
    + Added new voice activity detection modes (Automatic, Volume Gate, Hybrid)
    Last edited by dante696; November 4th, 2019 at 12:16 PM. Reason: changed details about memory leak
  1. [Release] TeamSpeak Client 3.3.2
    By ScP in forum Latest News
    Last Post: August 24th, 2019, 11:46 PM
  2. [Release] TeamSpeak Client 3.3.0
    By ScP in forum Archive
    Last Post: June 18th, 2019, 03:02 PM
  3. [Pre-Release] TeamSpeak Client 3.3.0
    Last Post: May 30th, 2019, 01:54 PM
  4. [Release] TeamSpeak Client 3.2.5
    Last Post: April 17th, 2019, 07:58 PM
  5. [Discussion] TeamSpeak 3 Client Release 3.1.2
    Last Post: March 20th, 2017, 02:26 PM
