The client closes normally, then it comes up to 2% and then it stops with this error code.
I had the same error, but after 30 mins it worked. I didn't change anything.
The error is fixed for me
Nop, still broken for me
Could not verify the product ini file. Aborting
Great updater (y)
How to fix:
Delete this folder and restart Ts3/try again : *\AppData\Local\Temp\teamspeak_temp_0
Are you getting this error during the update?
I just updated my client without any problem.
We've identified another issue with our CDN and fixed it. The update should work fine now.
My apologies for any inconvenience!
After update i make echo noises if someone talk.
Tested remove background noises disabled/enabled and echo reduction 10db.
Fix it.
Ty
For what exactly is the "Comfort noise" ? Its just a annoying sound at the moment
That highly depends on the person actually. Some people like it if there is noise with a pattern, like waves, wind, etc..
Some may not like but, but some may.
I guess it will be configurable in the future.
I'd like to express my concerns about the fact that Automatic Voice Gain Control option from the Capture settings is gone in this beta release. My colleagues and I consider it an extremely important feature, since it allows for our mic volumes to be adjusted accordingly and automatically, especially when one of us gets louder than the others. Would someone be kind enough to tell me why this option is no more and whether this release being in BETA has anything to do with it? Thanks so much!
Why do you have to break the sound like this? With this update, all my friends have box voice, whispers, and degraded voice quality. Back We needed to get to 3.3.2.
I´m surprised you all have such sound problems. 3.5.0 runs without any problems for me and my friends (well only for those where the updater was nice and worked). What audio settings do you have in the options? Any plugins that have something to do with mic input?
