Page 11 of 20 FirstFirst ... 910111213 ... LastLast
Results 151 to 165 of 298
Thread: TS Admin-Client
  1. #151
    July 2006
    22
    Hi all!
    I found a small error.
    If i log me in,
    and do a right click on the server name and click "Clear Password" then is the new server password
    "#clear#" not cleared and this error comes:
    [04:00:32] Bad Login (name and/or password wrong)
    How to fix:
    if Edit1.Text = '' then WriteLn('serverset server_password #CLEAR#')
    else WriteLn('serverset server_password ' + Edit1.Text);
    MfG: sprite
  2. #152
    September 2005
    Germany / Dortmund
    1,376
    How to fix:
    Jetzt kommen wieder die 1337-Kenntnisse, die man ja schon aus dem Pastebin bei Planetteamspeak kennt!
    Stell dir vor, genau das tut es (in etwa). Ich kann mir selber nicht erklären, warum es bei einigen Servern nicht klappt.
    ******adam: No, the Admin-Client has no problem with Linux-Servers, the TCP Query Interface is the same.
    Please, post the error! "Boom - crash" isn't a very helpful error-message.
  3. #153
    December 2005
    England
    32
    Well there isnt an error, as i said, the log doesnt have any error
    when the admin client connects, all voice stops, and about 5 seconds later everyone is kicked off teamspeak
    The program doesnt shut down cleanly though, as when you try to start it, it says that the tcp port is in use
    When you try to stop it, it says its not running
    killall -9 server_linux
    Kills the teamspeak server, and all the connections, allowing it to be started again
  4. #154
    October 2003
    2,527
    Quote Originally Posted by Forum Rules
    Try to write down at least the following information in your thread:
    • TeamSpeak version (complete string: 2.0.xx.xx)
    • Operation System (including Service Packs / Kernel Version, Kernel Patchset)
    Please provide us with this information.
  5. #155
    September 2006
    Deutschland /NRW
    Ich will das auch ALs SA können das mit dem Sticky gibt es da ne möglichkeit oder ein anderer Tool oder ne erweiterung
  6. #156
    September 2005
    Germany / Dortmund
    1,376
    The TeamSpeak 2 command interface this program uses does not support that. Most commands do not work without superadmin, even when the servers permissions system is configured to allow them.
    Da gibt es ganz einfach KEINE Möglichkeit! Das Rechtesystem des TCP-Servers ist unabhängig von jeglichen Rechten, die man bspw. im Webinterface setzt!
  7. #157
    December 2005
    England
    32
    hmm email notification seems to have stopped working
    anyway
    Teamspeak client
    2.0.32.60
    OS
    XP SP2
    Teamspeak server
    2.0.21.1 (according to the teamspeak client)
    OS
    Linux Fedora Core 5
  8. #158
    September 2006
    deutschland nürnberg
    nach einloogen keine channels und server
    Hallo
    Ich hab den TS admin client vers. 1.1
    Habe meine daten eingetragen
    es wird in commandline fester angezeigt connect zo server ....
    Leider werden keinerlei server angezeigt und keine user
    Muss ich seiten servers noch etwas einstellen damit die comunikation klappt ...
    habe schon viel gutes von dem programm gehört und wollte es jetzt auch testen
    schade das es nicht auf anhieb funktioniert
    würde mich freun wenn mir jemand helfen kann ...
    ciaoo diskman stefan ...
  9. #159
    September 2005
    Germany / Dortmund
    1,376
    Das passiert meistens, wenn man nicht den TCP Query Port des TeamSpeak-Servers angibt, sondern einen anderen offenen Port des Servers, bspw. dem HTTP-Port des Servers.
    Als TCP Query Port muss (jedenfalls wenn er nicht in der server.ini geändert wurde) 51234 angegeben werden.
    Bitte überprüf das noch einmal!
  10. #160
    September 2006
    Hallo
    Der ist eingetragen ich poste hier mal meine server.ini vieleicht könnt ihr mir dann weiter helfen
    [Main Config]
    BoundToIp1=
    ExternalIPDectection=1
    HTTPServer Port=5000
    HTTPServer Enabled=1
    DateTimeFormat=dd-mm-yyyy hh:nn:ss
    TCPQueryPort=51234
    AllowedClientNameChars=
    DisAllowedClientNameChars=()[]{}
    [debug]
    MessageTypes=LMTALL
    MessageDepths=LMDALL
    [WebPost]
    AdminEmail=na
    ISPLinkURL=na
    ISPName=Private
    ISPCountryNumber=0
    Enabled=1
    PostURL=
    ListPublic=1
    UserAgent=teamspeak
    [log]
    access_r=0
    access_u=0
    channel_registerred=0
    channel_unregisterred=0
    sa=0
    chat=0
    kick_server=0
    kick_channel=0
    [Spam]
    max_commands=2
    in_seconds=1
    ich habe eben TCPQueryPort 51234 angegeben und und HTTP port 5000
    sollte doch eigentlich so funktionieren !!?!?
  11. #161
    September 2006
    ahh jetzt habe ich meinen fehler gefunden ich muss genau wie im TS2 client iport angeben habe dort nur die ip angegeben
    aber dann habe ich ja nur zugriff auf einen server
    dachte ich kann damit mein kompletten TS server mit meinen einzellnen unterserver conf.
    naja nich schlimm habe ja bis jetzt nur 2 und dann muss ich halt schnell switchen
    sieht nett aus ^^^
    trotzdem danke ...
  12. #162
    November 2006
    Walnut, California
    ummm can u add more options like granting/revoking CA Op and V. also what does channel sticky do?
  13. #163
    November 2006
    Hi ich bin z.zt dabei ein gaming tool für ts und bf2142 zu schreiben deshalb suche ich eine referenz fur die tcp commands.
    und kann mir vllt hier jemand sagen wie ich in c#, VB, C oder C++ eine verbindung herstellen kann. sowas hab ich bisher noch nicht gemacht und ich will mich nicht di nächsten tage durch die msdn quälen
    Edit
    @Chimp A channelsticky user can't switch to any other cahnnel
  14. #164
    September 2005
    Germany / Dortmund
    1,376
    That is not possible with the tcp query interface.
    @GrEEnEyE: Was hat das mit diesem Thread zu tun?
    Der Command "help" sollte dir genug "Referenz" geben.
    Da gibt es bei jeder Sprache verschiedene Möglichkeiten.
    C#: keine Ahnung
    VB: da gibt es (glaube ich jedenfalls) extra gekapselte Socket-Klassen
    C: wenn nur Windows: Winsock
    C++: siehe C, Borland bringt selber Klassen mit, die SolarSockets, Qt bringt auch Socket-Klassen mit
  15. #165
    November 2006
    ich entwickle z.zt einen eigenen admin client und suche nach technischen infos die mir helfen können
    ich weiss net wie ich nen server auswählen soll
    hier n putty auszug
    [TS]
    help
    error
    login
    ERROR, no server selected
    select
    error
    error
    /h
    error
    Ich hab mehrere klassen gefunden und weiss nicht genau welche ich benutzen soll:
    system.net.sockets.socket
    system.net.sockets.TCPClient
    habs mit der TCPclient klasse probiert konnte aber nichts aus dem stream lesen
