Results 31 to 45 of 51
  1. #31
    August 2007
    USA
    25
    This is strange. I stopped and then restarted the TS server.
    Now, http://xxx.xxx.xxx.xxx:14534 is showing login prompt but when I input admin / default password (found in README) it just hangs there.
    If I try again, it shows page not found.
  2. #32
    August 2006
    Hawai'i
    Angry
    Quote Originally Posted by mokum View Post
    When using a mysql version > 4.0 you might expirience problems with starting the tss deamon. The server.log file will contain the errors.
    meisenst solved the initial problem [EDatabaseError: dbExpress Error: Operation Not Supported] by changing the query in mysql_sql/read_servers.sql to read:
    select * from ts2_servers WHERE i_server_id > 0;
    Then there is a second problem with the changing of ChannelAttribs. Changes made to users rights [like CA etc] would be LOST after disconnection.
    siepel fixed the second problem [GetChannelAttribs Exception: EDatabaseError.dbExpress Error: Operation Not Supported]
    select * from ts2_channel_privileges where i_cp_server_id = :iServerID and i_cp_channel_id = :iChannelID and i_cp_client_id = :iClientID
    put that in mysql_sql/read_channel_privilege.sql just on one single line exactly as above..
    Please sticky this.
    Cheers,
    mokum
    This is all well and good but my problem (haven't seen this covered anywhere in these forums) is that when starting the Linux server (any version) it just doesn't create any MySQL tables .. which would by itself explain the "Invalid Username/Password" errors I keep getting ... WHY isn't it creating any tables? I'm running tss2_rc2_20201 on a RedHat 9 server, I am now running MySQL 5.0.xx and am willing to try earlier versions although some people here say it doesn't matter what version or whatever. Yes, I've added the [DBEXPRESS] section to the bottom of my server.ini file:
    [DBEXPRESS]
    sqldir=mysql_sql/
    Drivername=mysql
    Database=mydatabase
    Hostname=127.0.0.1
    User_name=databaseuserwithfullprivileges
    Password=databaseuserpasswordforsameuser
    GetDriverFunc=getSQLDriverMYSQL
    VendorLib=./libmysqlclient_r.so.10.0.0
    LibraryName=./libsqlmy.so
    Active=1
    and Yes, the above-named libmysql v.3 libraries are installed in the same directory (tss2_rc2) as all the other files. I've modified my.cnf per someone's instructions, to enable this 'old_passwords' format. I've stopped and started the mysql server. Nothing seems to create that MySQL database!
    WHY don't Teamspeak developers just put all the libmysql libraries (v. 3, along with the modified read_servers.sql and read_channel_privilege.sql in mysql_sql folder, plus full and tested instructions for installation? I can't believe they want to charge people for slots for commercial use of a program that doesn't even install right and comes with basically zero tech support. Please help!!!
  3. #33
    May 2007
    Czech
    Thumbs down
    My SW:
    Server version: 5.0.32-Debian_7etch1-log Debian etch distribution
    Linux debianpc 2.6.18-5-amd64 #1 SMP Thu May 31 23:51:05 UTC 2007 x86_64 GNU/Linux
    ts2_server_rc2_20319
    end of server.ini:
    [DBEXPRESS]
    sqldir=mysql_sql
    Drivername=mysql
    Database=teamspeak
    Hostname=localhost
    User_name=teamspeak
    #Password=fweruvfsa7f3hjsjcvh9
    Password=password
    Active=1
    i try this:
    mysql> USE mysql
    Reading table information for completion of table and column names
    You can turn off this feature to get a quicker startup with -A
    Database changed
    mysql> update user set password = old_password('password') where user = 'teamspeak'; flush privileges;
    Query OK, 2 rows affected (0.01 sec)
    Rows matched: 2  Changed: 2  Warnings: 0
    Query OK, 0 rows affected (0.00 sec)
    i find and download on this forum libmysqlclient_r.so.10.0.0 and copy to dir of TS
    on phpmyadmin a can login with user "teamspeak" with pass "password" and i see
     * Projít ts2_bans
        * Projít ts2_channels
        * Projít ts2_channel_privileges
        * Projít ts2_clients
        * Projít ts2_servers
        * Projít ts2_server_privileges
    on log still :
    15-01-08 11:12:22,ALL,Info,server,      Server init initialized
    15-01-08 11:12:22,ALL,Info,server,      Server version: 2.0.23.19 Linux
    15-01-08 11:12:22,ERROR,All,SQL,        Database initialization error: EDatabaseError.dbExpress Error: Invalid Username/Password
    15-01-08 11:12:22,ERROR,All,SERVER,     Start_Server: unable to open database
    Where is problem pls?
  4. #34
    February 2007
    Marly-le-Roi
    I have the same problem, can anyone help us plz ?
  5. #35
    January 2008
    Sofia,Bulgaria
    I Want to give some hints to people with problems with MySQL 4/5 and the following error:
    27-01-08 17:42:51,ALL,Info,server, Server init initialized
    27-01-08 17:42:51,ALL,Info,server, Server version: 2.0.23.19 Linux
    27-01-08 17:42:51,ERROR,All,SQL, Database initialization error: EDatabaseError.DLL/Shared Library Name not Set
    27-01-08 17:42:51,ERROR,All,SERVER, Start_Server: unable to open database
    This is what I get when I tried to run it with MySQL instead of SQLite support. I'm using the current debian testing package (2.0.23.19-1: amd64) This error was so persistent. I tried downgrading the mysql libs to 3.23.56-3: amd64 package from old sarge distro. I copied&pasted the additional MySQL config (the [DBEXPRESS] part of config) from some thread in this forum. After that I tried everything here, changing localhost, short passwords, putting libraries to different dirs. And finaly found my problem. The example config that I've got had a hard to spot typo:
    [DBEXPRESS]
    LibaryName=/usr/lib/teamspeak-server/libsqlmy.so
    Missing 'r' in name "LibraryName". This take me hours to find out. So, please if you have similar problems
    with MySQL please check syntax very carefully. Don't just copy and paste other configs and change right part. Hope this helps someone ....
  6. #36
    February 2008
    USA
    Quote Originally Posted by Roman777 View Post
    My SW:
    end of server.ini:
    [DBEXPRESS]
    sqldir=mysql_sql
    Drivername=mysql
    Database=teamspeak
    Hostname=localhost
    User_name=teamspeak
    Password=password
    Active=1
    i try this:
    mysql> USE mysql
    Database changed
     * Projít ts2_bans
    on log still :
    I am having an identical problem on the exact same OS
  7. #37
    February 2008
    France
    Same error here and i try with lib mysql:
    • libmysqlclient.so.10
    • libmysqlclient.so.12
    • libmysqlclient.so.14
    • libmysqlclient.so.15
    Resume :
    OS : uname -r
    Linux *************** 2.6.18-xenU #3 SMP Thu Jan 10 15:56:11 CET 2008 i686 GNU/Linux
    MYSQL version : mysql --version
    mysql Ver 14.12 Distrib 5.0.32, for pc-linux-gnu (i486) using readline 5.2
    Conf server : server.ini
    [DBEXPRESS]
    sqldir=mysql_sql
    Drivername=mysql
    Database=teamspeak
    Hostname=localhost
    User_name=teamspeak
    Password=toto
    VendorLib=/usr/lib/libmysqlclient.so.10.0.0
    Active=1
    Connection mysql : sudo -u teamspeak mysql -u teamspeak -h localhost teamspeak -p
    Enter password: toto
    Welcome to the MySQL monitor. Commands end with ; or \g.
    Your MySQL connection id is 266
    Server version: 5.0.32-Debian_7etch4-log Debian etch distribution
    Type 'help;' or '\h' for help. Type '\c' to clear the buffer.
    mysql>
    Launching teamspeak : sudo -u teamspeak /home/teamspeak/tss2_rc2/teamspeak2-server_startscript start
    starting the teamspeak2 server
    Error starting daemon. Aborted
    ***in server.log ***
    -------------- log started at 20-02-08 14:27 -------------
    20-02-08 14:27:27,ALL,Info,server, Server init initialized
    20-02-08 14:27:27,ALL,Info,server, Server version: 2.0.23.19 Linux
    20-02-08 14:27:27,ERROR,All,SQL, Database initialization error: EDatabaseError.dbExpress Error: Invalid Username/Password
    20-02-08 14:27:27,ERROR,All,SERVER, Start_Server: unable to open database
    --------------- log ended at 20-02-08 14:27 --------------
  8. #38
    February 2008
    France
    Ok i resolved issue by changing password hash
    SET PASSWORD FOR '<mysqluser>'@'<host>' = OLD_PASSWORD('<password>');
    thanks to IceMatrix
  9. #39
    June 2007
    germany
    i've got it working so far too,
    but changes in the config for virtual servers get lost. No matter if i set them in the webinterface or directly in the database. as soon as i restart the server or start the virtual-server (id2) it is set to the settings of id1 and of corse won't start.
    any solutions?
  10. #40
    March 2008
    Ukraine, Kiev
    6
    Question sql files missing
    My problem is:
    -------------- log started at 24-03-08 22:33 -------------
    24-03-08 22:33:20,ALL,Info,server, Server init initialized
    24-03-08 22:33:20,ALL,Info,server, Server version: 2.0.24.1 Linux
    24-03-08 22:33:20,ERROR,All,SQL, SQL file not found mysql_sql/read_servers.sql
    24-03-08 22:33:20,ERROR,All,SQL, SQL file not found mysql_sql/new_server.sql
    24-03-08 22:33:20,ERROR,All,SQL, SQL file not found mysql_sql/read_server_privilege.sql
    24-03-08 22:33:20,ERROR,All,SQL, SQL file not found mysql_sql/new_server_privilege.sql
    (log cutted, there are more files missing)
    Why are these files missing? I've downloaded latest archive from this site and I don't see them in mysql_sql dir, that's very odd
    Here are contents of mysql_sql:
    -rw-r--r-- 1 teamspeak root 396 2007-08-02 14:25 create_bans.sql
    -rw-r--r-- 1 teamspeak root 520 2007-08-02 14:25 create_channel_privileges.sql
    -rw-r--r-- 1 teamspeak root 835 2007-08-02 14:25 create_channels.sql
    -rw-r--r-- 1 teamspeak root 588 2007-08-02 14:25 create_clients.sql
    -rw-r--r-- 1 teamspeak root 3706 2007-08-02 14:25 create_server_privileges.sql
    -rw-r--r-- 1 teamspeak root 1504 2007-08-02 14:25 create_servers.sql
    EDIT
    Found possible solution here: http://forum.teamspeak.com/showthread.php?t=40814
    and here: http://forum.goteamspeak.com/showthread.php?t=33504
    Some notes to everybody:
    1. Don't try to use mysql client libraries newer then mysql distribution version 3.x. Native dbExpress library (libsqlmy.so) supports ONLY 3.x (libmysqlclient.so.10)
    2. You can use newer versions (even up to 5.x - libmysqlclient.so.15) with dbExpress linux driver 4.20 (http://www.crlab.com/dbx/download.html). Use it instead of libsqlmy.so.
    Now I have a lot of strange problems with queries :|
    OMG:
    http://forum.teamspeak.com/showthread.php?t=24654
    This is so freaking stupid
    So far I can say, there is NO possible FREE solution to use latest mysql client/server with ts2...
  11. #41
    August 2003
    NJ
    32
    Yup, i've tried everything as well. Is there not a free alternative to the dbexpress? I dont feel like paying $100 to use TSS
  12. #42
    July 2007
    France
    30
    I use mysql 5.0.32 with TSS + lib libmysqlclient_r.so.10.0.0 and it work just fine, put the lib in the TS home directory / fill the config file and it's done, you just have to watch out for the password because TSS need old_password encryption. For infos there is plenty of tutorial explaining this method in the forum look @ "TeamSpeak 2.x with MySQL 5.x (Tutorial)" in sticky
  13. #43
    April 2007
    Ger
    wrong topic
  14. #44
    italy
    same problem..
    -------------- log started at 27-06-08 23:12 -------------
    27-06-08 23:12:28,ALL,Info,server, Server init initialized
    27-06-08 23:12:28,ALL,Info,server, Server version: 2.0.24.1 Linux
    27-06-08 23:12:28,WARNING,Info,SQL, created table ts2_servers
    27-06-08 23:12:28,WARNING,Info,SQL, created table ts2_server_privileges
    27-06-08 23:12:28,WARNING,Info,SQL, created table ts2_channels
    27-06-08 23:12:28,WARNING,Info,SQL, created table ts2_channel_privileges
    27-06-08 23:12:28,WARNING,Info,SQL, created table ts2_clients
    27-06-08 23:12:28,WARNING,Info,SQL, created table ts2_bans
    27-06-08 23:12:28,ERROR,Info,server, EDatabaseError: dbExpress Error: Operation Not Supported
    Running on debian.. with mysql 4.1.10.
    Please help me.
  15. #45
    September 2008
    Hey guys,
    got the same problems what most of u have.
    Still get this error nvm if i changed read_servers.sql too
    It sux. Got Suse
    EDIT:
    OMG. Crazy. After 10 times tries its working. I dont know why. I have often changed read_servers.sql.. and now.. no errors.
  1. [Resolved] Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock'
    By Svenskunganka in forum Server Support
    Last Post: September 12th, 2013, 10:59 PM
  2. Teamspeak goes MySql
    By Forces in forum Linux / FreeBSD
    Last Post: August 19th, 2011, 12:28 PM
  3. Teamspeak 3 <> MySQL
    By DeadHunter in forum Linux / FreeBSD
    Last Post: November 25th, 2010, 03:16 PM
