Results 16 to 30 of 44
  1. #16
    April 2007
    Ger
    I get every time username/passwort.... I think there is not really a connection to mysql... I tried without pass and the same error... anybody a idea?
    Swen
  2. #17
    April 2007
    Quebec
    with Fedora Core 6 all you have to do when you get the cannot find lib ... you get
    MySQL-shared-compat-4.1.22-0.i386.rpm from mysql web site. once installed using full path it work with :
    mysql Ver 14.12 Distrib 5.0.27, for redhat-linux-gnu (i686) using readline 5.0
    [DBEXPRESS]
    sqldir=/usr/bin/tss2_rc2/mysql_sql/
    Drivername=mysql
    Database=ts_domainname_com
    Hostname=127.0.0.1
    User_name=ts_linux
    Password=long-ass-password
    GetDriverFunc=getSQLDriverMYSQL
    VendorLib=/usr/lib/libmysqlclient_r.so.10.0.0
    LibraryName=/usr/bin/tss2_rc2/libsqlmy.so
    Active=1
    no problem for now.
  3. #18
    April 2007
    33
    Quote Originally Posted by AB2314 View Post
    Swen
    1. Has your mysql server networking enabled? Check your /etc/mysql/my.cnf and comment out the line "skip-networking".
    2. You have to use old passwords, since the authentication mechanism within mysql changed. Connect to the database as root-user and type the following:
    SET PASSWORD FOR '<your-ts-db-user>'@'localhost' = OLD_PASSWORD('<your-ts-db-pass>')
    3. Does your teamspeak-server connect to "127.0.0.1" instead of "localhost"? If your database server supports sockets, you have to use the ip address of the loopback device (127.0.0.1) instead of the hostname (localhost) to prevent the teamspeak-server from using the unix socket.
    server.ini example:
    sqldir=mysql_sql/
    Drivername=mysql
    Database=teamspeak
    Hostname=127.0.0.1
    User_name=teamspeak
    Password=xxxxxx
    LibraryName=./libsqlmy.so
    Active=1
    Note: The property "User_name" is correct, don't use "Username" (without the underscore) here as told elsewhere in this forum, it won't work.
  4. #19
    October 2007
    France
    70
    Question
    I'm on debian (last version updated)
    My server don't work on mysql and i don't find why.
    Quote Originally Posted by configuration
    [DBEXPRESS]
    sqldir=home/teamspeak/serv/mysql_sql
    Drivername=mysql
    Database=teamspeak
    Hostname=127.0.0.1
    User_name=my_username
    Password=my_password
    VendorLib=/usr/lib/libmysqlclient_r.so.15.0.0
    Active=1
    Quote Originally Posted by error
    07-04-08 14:40:57,ALL,Info,server, Server init initialized
    07-04-08 14:40:57,ALL,Info,server, Server version: 2.0.24.1 Linux
    07-04-08 14:40:57,ERROR,All,SQL, Database initialization error: EDatabaseError.Unable to Load /usr/lib/libmysqlclient_r.so.15.0.0
    07-04-08 14:40:57,ERROR,All,SERVER, Start_Server: unable to open database
    I've tested with many configuration, but it don't work, here's the differently configuration i've used:
    VendorLib=/usr/lib/libmysqlclient.so.15.0.0
    VendorLib=./libmysqlclient_r.so.15.0.0
    VendorLib=./libmysqlclient.so.15.0.0
    If anybody have solution for me it's very cool, my test server on windows is on mysql and it work perfectly at the first time, i don't understand why it doesn't work on linux
    thx in advance
  5. #20
    May 2008
    Milano, Italy
    you should obtain necessary libs. you can do this in the following way:
    go to that link and download the .rpm file. so now you should open that file.
    if you are under linux (i'll hope), you should install a program called alien (available, i know, for gentoo and debian; probably also for other distros).
    by command line type
    alien -t /YOURPATH/MySQL-shared-compat-4.1.9-0.i386.rpm
    with the -t option, you will make a .tgz file from the .rpm file.
    now in your .tgz (you can open it with some archive managers) there will be the necessary libs: libmysqlclient_r.so.10 is the one who interest you
    doing that i've obtained a starting and running server on my gentoo, using a mysql 5.0 database..but now i've a problem:
    from server.log:
    when i try to use webadmin interface from superadmin managing permissions that message is shown:
    ,ERROR,All,WEBINTERFACE,       SetVariables Exception: EInvalidField.field b_sp_AdminEditServerWelcomeMessage not found
    and in the permissions sections of the webadmin, all values are shown like "%!SERVERCFG_GROUP_PERMISSIONS_SA!%" (as in their htmls).
    if i restart server, every time, it is shown that message:
    ,ERROR,All,SERVER,     VirtualServer Startup(1) Exception: EInvalidField.field b_sp_AdminEditServerWelcomeMessage not found
    so i'm unable to manage my server...
    an other user had my same problem, but the replies to his post are not useful for me..
    so can someone help me?
  6. #21
    October 2007
    France
    70
    i have the same problem :s
    if you have this error
    Edit the table and change the type tyint to int and the value 1 to 11
    for the moment my problem is solved, i work on it
    I confirm, problem solved
    Now i have a new question, how i can update my server.dbs on mysql table?
  7. #22
    May 2008
    Hungary
    i have a problem
    dear helpers!
    [DBEXPRESS]
    sqldir=mysql_sql\
    Drivername=mysql
    Database=test
    Hostname=localhost
    User_name=team
    Password=****
    VendorLib=libmysql.dll
    LibraryName=dbexpmysql.dll
    Active=1
    29-05-08 22:49:37,ALL,Info,server, Server init initialized
    29-05-08 22:49:37,ALL,Info,server, Server version: 2.0.24.1 Win32
    29-05-08 22:49:37,ERROR,All,SQL, Database initialization error: EDatabaseError.Unable to Load libmysql.dll
    29-05-08 22:49:37,ERROR,All,SERVER, Start_Server: unable to open database
    29-05-08 22:49:37,ERROR,All,GENERAL, critical error, shutdown initiated
    mysql ver: 5.0.45
    what is the problem(s)?
  8. #23
    May 2008
    Hungary
    17
    mysql 5 problema
    TS server is not working with mysql 5 library, because libsqlmy.so want a function (called mysql_connect) which isnt exists in 5.x library:
    # grep mysql_connect /usr/lib/libmysqlclient_r.so.10
    Binary file /usr/lib/libmysqlclient_r.so.10 matches
    # grep mysql_connect /usr/lib/libmysqlclient_r.so.15
    I added the missing function to mysql 5 source:
    MYSQL*  STDCALL mysql_connect(MYSQL *mysql, const char *host, const char *user, const char *passwd)
        return NULL;
    After recompile and install:
    Binary file /usr/lib/libmysqlclient_r.so.15 matches
    I write a little mysql wrapper. With this, i can "monitor" the mysql calls.
    Run ts2 server with mysql 3.x library working good:
    http://pastebin.com/f4004fa0a
    Run ts2 server with mysql 5.x library still not working:
    http://pastebin.com/f6872c01e
    Watch out to: own_mysql_real_query called:SHOW TABLES.
    TS dont call own_mysql_fetch_row to get the showtable result! Why?
    (Ubuntu Hardy)
  9. #24
    April 2007
    Ger
    03-06-08 19:00:06,ALL,Info,server, Server init initialized
    03-06-08 19:00:06,ALL,Info,server, Server version: 2.0.20.1 Linux
    03-06-08 19:00:06,ERROR,All,SQL, Database initialization error: EDatabaseError.Unable to Load /usr/lib/libmysqlclient_r.so.10.0.0
    03-06-08 19:00:06,ERROR,All,SERVER, Start_Server: unable to open database
    But the file is exist in folder... Any ideas?
  10. #25
    November 2006
    US
    8
    Thumbs down
    all I can say is:
    Please document this better.
    edit: after reflection, I can also say:
    Linux isn't that hard to understand, and developing for it is almost as hard. So please, help a "brotha" out and begin the love for mysql on linux!!!
  11. #26
    November 2006
    US
    8
    further elaboration:
    if one searches for "libmysqlclient_r.so.10.0.0" with google.com, the first result is:
    libmysqlclient_r.so.10.0.0 - TeamSpeak Community Forums
    within the thread there's a statement further explaining the lack of regard for this demand for "support":
    Quote Originally Posted by ozman View Post
    Why wont people give these things away as a comunity
    It's hard to see a leg snap on a titanium-alloy reinforced bench, wtf is going on here??????
  12. #27
    November 2006
    US
    8
    some MAJOR problems with the release of both the binary and "non existant" documentation:
    1) wont work if you use relative path names in the settings file
    2) binary distribution does not contain REQUIRED sql files in the mysql_sql folder
    3) Not sure, but I belive if you try to use (any) release other than 10.0.0 of the client library, then you're in a world of hurt.
    4) SET PASSWORD FOR '%%%%%%%%%%'@'%%%%%%%%' = OLD_PASSWORD( '%%%%%%%%%%%%%%%%%%' ) OR DIEEEEEEEE
    5) Impossible to administer server unless stock sql files edited before install: http://forum.teamspeak.com/showthrea...849#post179849
    WTF people!!!!!!!!
  13. #28
    February 2005
    679
    It seems that most of the scripts in the mysql_sql directory are missing. We supposed to rewrite those for MySQL? Anyone else written them? No sense in reinventing the wheel.
  14. #29
    February 2005
    679
    Ok, so they are all on the FTP: ftp://ftp.freenet.de/pub/4players/te...2401/mysql_sql For some reason, they were left out of Windows and Linux server downloads.
    Rather than you having to copy all the text and save it to individual files, I thought I'd zip and tar them for you. See attached files.
    EDIT:
    delete_channel_privileges.sql
    in my zip and tar should be
    delete_channel_privilege.sql
  15. #30
    June 2006
    England, Hertfordshire
    249
    Anyone know where I can get libmysqlclient_r.so.10.0.0 as the server won't allow libmysqlclient_r.so.15.0.0?
  1. Ts3+Mysql tutorial (windows) ?
    By deviss in forum General Questions
    Last Post: October 11th, 2010, 07:49 AM
  2. [Mini-Tutorial] Fix ServerAdmin Lost Password (MYSQL)
    By Appleboy in forum Server Support
    Last Post: December 24th, 2009, 01:32 PM
