Page 1 of 2 12 LastLast
Results 1 to 15 of 16
    December 2008
    Belgium
    10
    Exclamation Urgent help for tsserver
    hey guys,
    i have a big problem.
    i have the ts server program, i filled everyting correctly in in the settings.
    the problem is:
    i chearch in the web list of server to my server.
    he's there.
    i double klick on it.
    it is connecting.
    and then there stands:"No reply from server
    Maybe the server is offline
    or maybe teamspeak is not running on it"
    but the server is online?!
    the server ip should be: 88.197.232.216:8767
    thx in advance for the help.
    regards,
    bvagroup
    December 2007
    Austria,Linz
    214
    is the server in the same local network as your client ? , then you must use your local IP Adresse, for instance: 192.168.0.155:8767
    December 2008
    Belgium
    10
    Exclamation .
    yes, so i need to change the parts before the server port in my internal ip?
    December 2008
    Belgium
    10
    yes ok this works, I (!) can login now
    but other people need to connect to the old one or the new one ?
    December 2007
    Austria,Linz
    214
    you must connect with your local IP and oother people, outside your local network must connect to your wan IP, that is visible at whatismyip.com
    December 2008
    Belgium
    10
    ok thx
    regards
    vbagroup
    December 2008
    Belgium
    10
    Exclamation .
    so other people needs to connect with this ip: 88.197.232.216:8767 ??
    i think it isnt working
    and a problem with adding the Server IP in the teamspeak viewer.
    it says:"Connection Problem: Server Query not possible - Timeout"
    December 2008
    Belgium
    10
    people cant join the server..............
    big problem.........
    December 2007
    Austria,Linz
    214
    Do you opened the ports and route them ? ( also router 8767 to your PC at your network ? ) and do you disabled your Firewall ?
    December 2008
    Belgium
    10
    yes, all is done
    but still not working
    December 2007
    Austria,Linz
    214
    do you opened other ports and tested it with other programs?, maybe you make something wrong at this options ?
    December 2008
    Belgium
    10
    what programs do you mean?
    also if my firewall is off, people cant join
    December 2007
    Austria,Linz
    214
    you can test with "wireshark" if the port is correctly open then you should this at this program.
    I only used one times this program, but it should be very good, because we need this in 2 weeks at networktechnical ( at school ).
    But I meant, is that your first port opening with this router ?
    December 2008
    Belgium
    10
    yes .......
    December 2007
    Austria,Linz
    214
    then you should contact your provider / router company, or look at google for "port forwarding" with your routername, I cannot say you, how you make this settings, because I do not know about your router, or look at the documentation(s).
  1. tsserver
    By mikej in forum Server Support
    Last Post: April 5th, 2010, 08:16 AM
  2. Several tsserver
    By Nanakie in forum General Questions
    Last Post: January 3rd, 2010, 12:19 AM
