Results 1 to 4 of 4
    December 2008
    USA
    TS connection problems
    For over a week or so my teamspeak will not connect to any servers. I have tried multiple servers and I keep getting a message saying "NO REPLY FROM SERVER". This keeps happening to every server I try to connect to. I have teamspeak 2, which I believe is the latest version. Do I need some sort of upgrade?
    December 2007
    Austria,Linz
    214
    I had this problem to, if you use Avia AntiVir Premium ( Firewall ) you must set the Firewall to "middle" and not to high.
    What firewall do you use ?
    And do you tried to disable your firewall for testing.
    December 2008
    USA
    Thanks, it was my firewall. It is set to allow teamspeak, but for some reason it won't. So I set it to ask me if it should be allowed, so each time I connect it will ask me and I click allow.
    January 2009
    Denmark
    76
    Well i'm in the same situation, but that was before I upgrade to TeamSpeak 2 Server (Updated Executable)
    I didn't think about my "IP Adresse", by "Right Click on the Teamspeak Server", and find (Your IP's) = Lan IP 192.168.1.2, and that is my whole problem, because my other IP doesn't show up at all.
    And yes, I can find my TS Listen on the "Web Search List", I just cant access it.
    I have checked and checked, in the "Router" Configurations, For "Forward Rules" Applications and such, and my firewall settings, has even been tryed to be shut down.
    I'm using a Linksys Router, no need for specs, because I have tryied to "Flash Upgrade"
    You guys can P.M if you wanna try, takeing a crack at it, then i'll send you a ip
    Cheers!!!
  1. Connection and connection lost problems.
    By Kalic in forum Windows
    Last Post: July 16th, 2012, 11:31 AM
  2. Replies: 3
    Last Post: February 10th, 2011, 11:26 AM
