Results 1 to 4 of 4
Thread: Noise in TS
    October 2009
    Moscow
    Noise in TS
    Hi all!!!
    Who know, what is addon i may install to the system, for create noise in speak (like in aviation radio)?
    Our team fly in the flight simulator, and we want to create this effect.
    Thank u!
    BHKai is offline -= Undercover TeamSpeak Fanatic =-
    January 2007
    LA
    4,576
    Already been ask use search. If I remember correctly there is nothing to create that.
    I have suggested once that you can put it on the lowest quality and use wireless just inside of the range your wireless signal if you want crappy voip.
    May 2006
    Europe/Czech Rep.
    1,616
    or set a bot pc-node with mp3 of that sound or whatever. neverending loop. for one channel easy to go. just create at least 1min of audio.
    November 2009
    Tampa
    There was a program called TS-Noise that did this, but for older versions of TS.. not sure if it's still around or works with later versions of TS.
  1. TS Noise
    By Sparks in forum Tools / Web Based
    Last Post: July 13th, 2010, 09:51 PM
