Results 16 to 30 of 47
  1. #16
    France
    25
    I don't think it reads the ini file at all :
    On Linux 64, it worked. (using password : YES was on my screen) I just had to create my database, and then the server would have started completely.
    But on Windows 64, it doesn't. It is the same ini file at the same place...
    I think the Alpha team has already made it work, but we are maybe using the wrong parameters... so we have to wait an answer from the Alpha team or the TS team... because the documentation about using TS with MySQL is (still) unprecise... (I say "still" because with TS2 it was worse).
  2. #17
    United States
    23
    Make sure to hit enter after this last line of your ts3db_mysql.ini
    [config]
    host=******
    username=******
    password=******
    database=******
    <--empty line
    when I added this my ini the server fired right up on MySQL 5
    use only the lines above, adding otheres seemed to stop it from working.
  3. #18
    Kansas
    That worked for me but now its saying ts3db is an unknown database even though its created and i can see it through navicat
  4. #19
    France
    25
    It works also here... could they have tried to do something less... strict than that ?
  5. #20
    Reno
    can somone please link me a good site to get sqlite that isnt just source code.
  6. #21
    Kansas
    any clues as to my problem? its not finding the database i created with navicat, its only finding the data created by mysql server.
  7. #22
    June 2009
    Washington
    10
    You might try checking your ts3db_mysql.ini file and verify the host name is correct. (I used Navicat to create the DB as well, and it's working for me now thanks to NeoShadowdream's tip.)
    Don't forget to give the user permissions for the new database as well, or TS can't create the tables.
  8. #23
    Kansas
    still get the whole error i reported
  9. #24
    December 2006
    Denmark
    25
    Yes thats right. Iam running Windows 64 bit server and the ts3server 64 bit just ignore the settings
    Quote Originally Posted by Sharpe49 View Post
  10. #25
    March 2003
    London UK
    66
    For those of you for which is seems to be using the wrong mysql details ensure you have a carriage return on the end of the last setting of the ts3db_mysql.ini and that said file is using native line endings.
    Failure to do either one of the above will result in none of the settings being used.
    Note: I already raised this with the developers as a bug.
  11. #26
    December 2006
    Denmark
    25
    nice it works now with mySQL with the new ts3server 64bit beta2 :P
  12. #27
    Saudi Arabia
    22
    2009-12-20 21:43:06.912374|ERROR |DatabaseQuery | | mysql_real_connect() failed with error: Access denied for user 'root'@'localhost' (using password: NO)
    2009-12-20 21:43:06.912374|CRITICAL|ServerLibPriv | | Server() DatabaseError
    why ?
    my sql is not user root ..
  13. #28
    December 2006
    Denmark
    25
    are you running the last ts2server beta 2 ?
  14. #29
    Saudi Arabia
    22
    yes . . . . .
  15. #30
    May 2009
    canada
    21
    can you post your mysql ini file?
  1. FreeBSD 9.0 / 9.2 and TeamSpeak3 MySQL db dont work
    By jacekg in forum Linux / FreeBSD
    Last Post: July 28th, 2014, 04:18 PM
  2. still dont work
    By Scania in forum Windows
    Last Post: January 21st, 2010, 06:33 PM
