Results 31 to 45 of 47
  1. #31
    April 2007
    98
    Quote Originally Posted by asd3344 View Post
    2009-12-20 21:43:06.912374|ERROR |DatabaseQuery | | mysql_real_connect() failed with error: Access denied for user 'root'@'localhost' (using password: NO)
    2009-12-20 21:43:06.912374|CRITICAL|ServerLibPriv | | Server() DatabaseError
    why ?
    my sql is not user root ..
    Try this one:
    Quote Originally Posted by NeoShadowdream View Post
    Make sure to hit enter after this last line of your ts3db_mysql.ini
    [config]
    host=******
    username=******
    password=******
    database=******
    <--empty line
    when I added this my ini the server fired right up on MySQL 5
    use only the lines above, adding otheres seemed to stop it from working.
    This fixed my problems
  2. #32
    Saudi Arabia
    22
    not work
  3. #33
    Kansas
    My only problem now is this showing up in log file with server not starting.
    2009-12-21 11:47:30.390625|CRITICAL|SQL | | db_CreateTables() unable to load instance default values
    Any clues why im getting this?
  4. #34
    December 2006
    Denmark
    25
    Are you running mySQL in strict mode?
    Quote Originally Posted by Jwalters0814 View Post
  5. #35
    June 2009
    germany
    ? what must i setup ? and where
  6. #36
    9
    Do you have all 3 options in your ts3server.ini?
    dbplugin=ts3db_mysql
    dbsqlpath=sql/
    dbsqlcreatepath=create_mysql/
  7. #37
    Home
    Exclamation
    Hello my problem is as follows ts3server_win32
    2009-12-22 18:58:24.656250|INFO    |ServerLibPriv |   | Server Version: 3.0.0-beta5 [Build: 9462]
    2009-12-22 18:58:24.656250|INFO    |DatabaseQuery |   | dbPlugin name:    MySQL plugin, (c)TeamSpeak Systems GmbH
    2009-12-22 18:58:24.656250|INFO    |DatabaseQuery |   | dbPlugin version: 1
    2009-12-22 18:58:24.828125|ERROR   |DatabaseQuery |   | db_exec() CREATE TABLE channel_properties (  server_id integer unsigned,  id     error: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'AUTOINCREMENT NOT NULL,  channel_parent_id  integer unsigned,  server_id        ' at line 1
    2009-12-22 18:58:24.828125|CRITICAL|SQL           |   | db_CreateTables() unable to create tables
    ts3server.ini
    machine_id=
    default_voice_port=9989
    voice_ip=YOURIP
    licensepath=
    filetransfer_port=30034
    filetransfer_ip=YOURIP
    query_port=10012
    query_ip=YOURIP
    dbpluginparameter=
    dbsqlpath=sql/
    logpath=logs/
    logquerycommands=1
    ts3db_mysql.ini
    [config]
    host=localhost
    port=3306
    username=teamspeak
    password=******
    database=ts3db
    socket=
    What is the problem? Thank you for your reply
  8. #38
    August 2007
    Bangkok Thailand
    44
    @ Dubik
    Change your dbsqlcreatepath value to be like this.
    To guys having problem that TS3 server doesn't read your MySQL configuration file.
    [config]
    host=localhost
    port=6661
    username=ts3
    password=blablabla
    database=xgn_ts3
    socket=
    "This line should be an empty line"
    Make sure you have an empty line after socket= like Lil-rich said.
  9. #39
    Home
    Quote Originally Posted by Dark-Master View Post
    @ Dubik
    ou me stu... here but thank you very much :-)
  10. #40
    December 2004
    RF
    3,008
    Quote Originally Posted by jwevrsn View Post
    Not necessarily, it could have been his internal network IP.
    It should work although you are correct it is advisable to use localhost.
    It is NOT advisable to use "localhost", unless TS is the only one program accessing database.
    Use 127.0.0.1 or real LAN IP. 127.0.1.1 for Linux server would be also acceptable.
  11. #41
    January 2008
    FRANCE
    25
    I have an probleme with MySQL server on another machine.
    [config]
    host=94.23.48.46
    port=3306
    username=******
    password=******
    database=******
    mysql_real_connect() failed with error: Can't connect to MySQL server on '127.0.0.1' (111)
    Why 127.0.0.1 ????
  12. #42
    December 2004
    RF
    3,008
    Where did you put that config?
  13. #43
    January 2008
    FRANCE
    25
    In ts3db_mysql.ini on TS3 Server Folder
  14. #44
    December 2004
    RF
    3,008
    Try remove "dbpluginparameter=" from ts3server.ini
  15. #45
    January 2008
    FRANCE
    25
    Same ...
    2009-12-28 02:56:09.868188|ERROR   |DatabaseQuery |   | mysql_real_connect() failed with error: Can't connect to MySQL server on '127.0.0.1' (111)
  1. FreeBSD 9.0 / 9.2 and TeamSpeak3 MySQL db dont work
    By jacekg in forum Linux / FreeBSD
    Last Post: July 28th, 2014, 03:18 PM
  2. still dont work
    By Scania in forum Windows
    Last Post: January 21st, 2010, 05:33 PM
