Results 46 to 47 of 47
  1. #46
    October 2009
    here
    Exclamation
    MYSQL Requires a password on remote connections. Try setting up an account and give it full permissions to the schema you Chreated for it.
    Quote Originally Posted by JonathanNet View Post
    Hi iam running ts3 server 64 bit, but can't get mysql to work
    I have created a file named: ts3db_mysql.ini with info:
    [config]
    host=192.168.10.100
    port=3306
    username=******
    password=******
    database=teamspeak3
    socket=mysql
    And I have created a file: ts3server.ini with info:
    machine_id=
    default_voice_port=9987
    voice_ip=0.0.0.0
    licensepath=
    filetransfer_port=30033
    filetransfer_ip=0.0.0.0
    query_port=10011
    query_ip=0.0.0.0
    dbplugin=ts3db_mysql
    dbpluginparameter=ts3db_mysql.ini
    dbsqlpath=sql/
    dbsqlcreatepath=create_mysql/
    logpath=logs
    logquerycommands=1
    Then I try to start it with command line: ts3server_win64 inifile=ts3server.ini
    I get this error:
    2009-12-19 16:55:13.073125|INFO    |ServerLibPriv |   | Server Version: 3.0.0-beta1 [Build: 9366]
    2009-12-19 16:55:13.073125|INFO    |DatabaseQuery |   | dbPlugin name:    MySQL plugin, (c)TeamSpeak Systems GmbH
    2009-12-19 16:55:13.073125|INFO    |DatabaseQuery |   | dbPlugin version: 1
    2009-12-19 16:55:13.088750|ERROR   |DatabaseQuery |   | mysql_real_connect() failed with error: Access denied for user 'root'@'localhost' (using password: NO)
    2009-12-19 16:55:13.088750|CRITICAL|ServerLibPriv |   | Server() DatabaseError
    Seems to use the root user, although I have entered the user and password, can any one help me with this problem?
    Kind regards
    Jonathan
  2. #47
    62
    Your database password is wrong, or is your database username is incorrect.
    The problem I had. I simply left out port and Soked and then it worked. Of course, that right is your database user @ (each host) must have.
    My configuration is as follows:
    [config]
    host=*.*.*.*
    username=******
    password=******
    database=teamspeak3
    And:
    machine_id=1
    voice_ip=*.*.*.*
    licensepath=
    filetransfer_ip=*.*.*.*
    query_port=10011
    query_ip=*.*.*.*
    dbsqlpath=sql/
    logpath=logs
    logquerycommands=1
  1. FreeBSD 9.0 / 9.2 and TeamSpeak3 MySQL db dont work
    By jacekg in forum Linux / FreeBSD
    Last Post: July 28th, 2014, 03:18 PM
  2. still dont work
    By Scania in forum Windows
    Last Post: January 21st, 2010, 05:33 PM
