Page 3 of 3 FirstFirst 123
Results 31 to 32 of 32
  1. #31
    florida
    263
    Quote Originally Posted by hoser1970 View Post
    I've tried the .ini route and get the following errors (unable to bind bla bla bla):
    I have the actual IP address in, just x'd it out for here. I'm on FIOS with their mode/router combo and believe I've forwarded the ports correctly, however there interface for forwarding is a lot different then I'm used to with my Netgears.
    i also have a fios modem/router
    is that 173.x.x.x ip your external ip ?
    my internal ips are 192.168.x.x
    login your modem and check what ip it assigns to your TS3 server machine.
    my internal ip from router is 192.168.1.4
    so my command line is ..
    \\ts3server_win32.exe" voice_ip=192.168.1.4 query_ip=192.168.1.4 filetransfer_ip=192.168.1.4
    for an .ini file
    machine_id=
    default_voice_port=9987
    licensepath=
    filetransfer_port=30033
    query_port=10011
    dbplugin=ts3db_sqlite3
    dbpluginparameter=
    dbsqlpath=sql/
    logpath=logs
    logquerycommands=0
    be sure you of your port forwarding
    udp 9987
    tcp 10011
    tcp 30033
  2. #32
    December 2004
    RF
    3,008
    Oh, dear God!
    Why you making your life harder than it is? What the hell you're doing?
    Just leave default settings - they are sufficient and much more useful than what you cracking here.
