Page 1 of 3 123 LastLast
Results 1 to 15 of 32
    houston
    Help Me Set it Up
    Ok im normally pretty good with this sort of thing... Where do i start... can someone provide a walk through for me on setting a server up on windows7 64bit?
    44
    - download 64bit server package
    - unzip/rar it somewhere
    - start ts3 server exe
    - note query user and pw
    - check the server log file for your token
    - join with client
    - "register" with token
    houston
    ok
    umm but will i use the local host address or my actual ip address....?
    houston
    liense
    will i need a license for this?
    Norwich, UK
    136
    If you fail to specify an IP address in either the ts3server.ini or on launch command line TS3 will work on 0.0.0.0 which is no good.
    So be sure to include it in the launch argument or following the instructions to get TS3 to generate your inifile on first launch.
    Norwich, UK
    136
    Quote Originally Posted by trauma View Post
    Only if you're likely to have 32 or more concurrent users on.
    Then it'd probably be an idea to get a free license for non-profit, 512 slots.
    houston
    .ini
    how do i get it to create an ini?
    Norwich, UK
    136
    machine_id=
    default_voice_port=9987
    voice_ip=YOURIP
    licensepath=
    filetransfer_port=30033
    filetransfer_ip=YOURIP
    query_port=10011
    query_ip=YOURIP
    dbplugin=ts3db_sqlite3
    dbpluginparameter=
    dbsqlpath=sql/
    logpath=logs/
    logquerycommands=0
    (assumes you're using sqlite and not mysql, if you're running by default then that's correct)
    Name it ts3server.ini and place it in your main TS3 directory.
    On your TS3 server launch shortcut or command have:
    "C:\Program Files\Teamspeak3\ts3server_win32.exe" inifile=ts3server.ini
    Obviously the location needs to be appropriate to where you have yours.
    houston
    im using heidisql.... and how do i link the command inifile=ts3server.ini
    Norwich, UK
    136
    You need to still launch the inifile on the command line as shown but you need to change the dbplugin values to represent heidisql
    Sorry that's about as far on that one as I can go...
    Florida
    6
    Quote Originally Posted by BuffBot View Post
    - join with client
    what do you mean by
    "- join with client
    - "register" with token"
    i see nothing in the client about joining anything =\
    France
    25
    join = connect to the server
    register = in TS client, Permissions > Use Token : type the token from your logs
    Florida
    6
    o.O ok then plz explain how to connect to a server thats not set up O.o (im used to TS2 but cant seem to find the download)
    France
    25
    Just run it and if the window closes after the server is launched, then there is an error.
    If it doesn't close, open the log file to take the token.
    Connect to your server with TS Client (server name : localhost, nickname : <any>, password : <nothing>).
    Then go to Permissions > Use Token and write the token that was in the log file.
    Florida
    6
    thx every thing seems to work now ill post if i have more questions
    EDIT: how do ppl connect to me? x.X lol
