Page 5 of 8 FirstFirst ... 34567 ... LastLast
Results 61 to 75 of 119
  1. #61
    February 2006
    Texas, USA
    4,143
    because of how the devs created TS3 it really doesn't matter because you can adjust the permissions in any way you want You could give the GUEST group the permissions that VOICE has if you wanted. It's your server to do with as you please
  2. #62
    June 2010
    Denmark
    22
    Thanks for your help...
  3. #63
    June 2010
    USA
    6
    Solved [Solved] Temporary permissions, channel groups, etc
    Is possible to grant temporary permissions to a client?
    Example:
    During an operation a user needs to be give permission, temporarily, to join a privileged channel to pass intel. This happens often, several times a day, and often once granted the permission isn't removed (simply forgotten by the permissions granter) so the grantee can access channels they normally should have access.
    I would like to be able to assign someone those permissions, by server group or channel group membership temporarily then have them removed automatically after a certain amount of time.
  4. #64
    May 2010
    6,310
    It isn't possible by the time. But it's possible by the connection.
    In the server group you uncheck the "b_group_is_permanent" permission
    By this way, when the user disconnect, he loose this server group.
  5. #65
    August 2010
    UK
    7
    Plz help me!!!!!
    hey i have a number of problems, this whole set up is so daunting
    I posted a question here before ( see below) and the person helped me so that admins couldn't join the leaders room but could joins the admins room, but my problem now is that, guests and members can join either of the rooms?
    http://forum.teamspeak.com/showthread.php?t=57510
    also, a few of my members, when they are assigned to member, when they quit and come back on they are guest again! does this have something to do with (temp) next to the server group?
  6. #66
    New England USA / Marnbach, Weilheim i.OB, Germany
    425
    Check it for your 2nd problem.
  7. #67
    August 2010
    UK
    7
    thanks!!!!! any help on the first one??
  8. #68
    Catalunya
    2,350
    Please read the documentation :
    TeamSpeak 3 Permissions Guide.txt
  9. #69
    September 2010
    Switzerland
    Losing SA privileges on reconnect
    Hi everyone
    I'm hosting TS3 servers on my Ubuntu 10.04 vServer and one of the users contacted me some days ago, that he lost his SA privileges. I created a token for him and after he used it his permissions were restored.
    One day later he emailed me again, telling me that he lost his permissions again after he logged out and back in again. Also this wasn't just his problem but a problem with all other serveradmins on this virtual server.
    Everytime one of them reconnects they lose their SA status.
    I checked the logfiles but there was absolutely no sign that one of this users lost any privileges or something like that.
    I don't think it's a general server-bug, because on the other virtual servers this problem doesn't exist.
    Can somebody help me with this?
    Cheers
    Margash
    Excuse the mistakes, my English isn't perfect at all
  10. #70
    17,936
    Make sure, that your group has permission b_group_is_permanent set and also maek sure, that this group isn' the default server group.
  11. #71
    December 2010
    earth
    35
    Channel Group Permissions do NOT hold
    I created a channel group for regular members so that they have full access to channels. It seems like the permissions hold for about a day. After than everyone is a guest.
    I know there are multiple ways to change a users group.
    • I have right clicked their name and selected the appropriate group from there.
    • I have added them to the Sever Groups tab via their client id, but not database id.
    Do I need a mysql database for this? I thought for small servers that things like this would be called from txt files or w/e.
    Please help. Getting out of control.
  12. #72
    May 2007
    Eastern NC
    1,794
    Did you put a check in the b_group_is_permanent permission for that group? If you forgot that permission the group is only temporary and removed when they log off.
  13. #73
    January 2011
    Channel Group not Permanent?
    I have to setup a small TS3 server, for a small Guild in some Online game. So, i have sort of 3 areas.
    1. A Lobby, where everyone gets into upon joining the server.
    2. A Members area, where suposedly only members should be able to join.
    3. A Leaders channel, only for Leaders.
    So, after watching florian_fr40 sticky tutorial, i did set up 3 "Server Groups", Guest, Member and Leader.
    Everything works, apart from the fact that if i "Set Channel Group" for someone, it only says "Member[Temp]" or "Leader[Temp]. If i set this, then the Member or Leader can move beween the channels hes suposed to be able(Members only in Lobby and the Members Area, and Leaders in all 3 areas). But upon closing of TS3 and then reconecting he(naturely) lost the Temp Channel Rights.
    In Florians Video Tutorial, he could set the Channel Rights to Perm, like i set already the Server Groups to. I just cannot set the Channel Group to Perm.
    greetings
  14. #74
    May 2010
    6,310
    Just check b_group_is_permanent permission on each groups
  15. #75
    January 2011
    Hi Florian ^^
    Much thanks, i thought that i was missing one small option.
    thanks again ^^ > Solved
  1. Replies: 5
    Last Post: March 22nd, 2016, 10:28 AM
  2. [Not possible] Assign Template Groups & make default group permanent?
    By RickyB98 in forum Server Support
    Last Post: November 12th, 2014, 03:55 PM
  3. [Resolved] Channel Groups are always permanent
    By qwermnbv in forum Permission System
    Last Post: September 19th, 2014, 08:13 AM
  4. Replies: 1
    Last Post: November 24th, 2010, 06:49 AM
  5. Server Groups/Channel Groups overwriting other groups
    By Slicky456 in forum Permission System
    Last Post: June 8th, 2010, 06:25 AM
