Results 1 to 9 of 9
    2,354
    Problem while setting b_client_issue_client_query_command
    Beta 2 added a new permission: b_client_issue_client_query_command
    I tried to add this permission with the Teamspeak 3 Client to the server admin group:
    insufficient permission modify power
    So I tried with the telnet server query with Putty as client and login from the first server start. After use and login command I did:
    servergroupaddperm sgid=6 permid=20624 permvalue=1 permnegated=0 permskip=0
    Response:
    error id=2570 msg=insufficient\spermission\smodify\spower
    So how should I add this permission to the server admin group?
    Vienna
    9
    I have the same problem..
    My server is hosted (by NGZ) if its relevant.
    I wanted to set the server query admin on beta2 and suddendly i've got this error.
    It happens when I try to set the level 2 admin with:
    login serveradmin [YOUR_PW]
    use sid=1
    servergroupaddclient sgid=2 cldbid=[YOUR_DB_ID]
    I've tried it with the internal ServerQuery.
    USA
    58
    I can't even login to ServerQuery using serveradmin because I get
    insufficient client permissions (failed on b_client_issue_client_query_command (20624/0x5090))
    Vienna
    9
    same problem at my server xD
    2,354
    @ Malivil: Ok, but that can't be the solution for a future final version . So I hope that this will be changed sometime in the beta .
    USA
    58
    Use this one instead. There should have been an sql script run when beta2 was first launched to give the serveradmin group these permissions, but it didn't happen for some reason.
    http://forum.teamspeak.com/showpost....70&postcount=3
    2,354
    @ Malivil: Thanks, it worked.
    California
    16
    I have tried adding those into the DB but I can't get this stupid program I am using to work...I am using SQLite3 manager LITE...i can't seem to add anything to any of the tables...rather annoying...would Navicat work with this DB or not?
    Restart Server after changing SQL
  1. Problem setting up TS3 on a VPS.
    By USD1337 in forum Linux / FreeBSD
    Last Post: August 17th, 2015, 05:19 PM
  2. Replies: 0
    Last Post: December 26th, 2009, 02:08 PM
  3. Replies: 7
    Last Post: December 21st, 2009, 11:38 AM
