Page 1 of 4 123 ... LastLast
Results 1 to 15 of 52
    July 2009
    6
    Hotkeys do not work
    Hey guys,
    just installed TS3 Beta 2 on my MacBook (OSX 10.6.2) and noticed that my hotkeys:
    OPTION + V = Toggle Microphone
    OPTION + B = Toggle Speaker
    only work if I have TS3 in front (activated). So if I have another application in front such as Safari, iTunes or even Finder my hotkeys aren't working.
    I already tested another modifying key like COMMAND but the problem still persists.
    Thanks in advance - Horst33
    Krün, Germany
    510
    For global hotkeys, you need to enable a setting in the Mac system preferences.
    Mac OS X 10.5.8
    - Open System Preferences
    - Universal Access
    - "Enable access for assistive devices" (on bottom)
    Mac OS 10.9.x
    - Open System preferences
    - Security & Privacy
    - Privacy tab
    - Accessibility
    - Enable TeamSpeak 3 or 5 Client
    Mac OS 10.15.x
    - Privacy tab
    - Input Monitoring
    (when list does not offer the + button then try to start the app from application folder.)
    The reason for this is, on Mac by default you cannot catch keypresses from one application if another application has the focus for security reasons as a protection mechanism against malware trying to log keyboard input. In order to catch TeamSpeak 3 hotkeys when another application is running, this option must be explicitly enabled, otherwise OS X would not pass the keypresses to TS3.
    Admittedly, this should have been in the FAQ.
    January 2009
    Kamloops BC Canada
    9
    Yeah this probably didn't come up in alpha because I also run vent and mumble on my Mac, which requires this change in the system prefs for them to pick up the key presses as well.
    Mike
    July 2009
    6
    Thanks a lot PeterS - now it works. I tested it successfully with every modifier-key (shift; ctrl; alt; cmd) having Finder or Safari in front.
    A tiny problem for me was to find "Universal Access" in System Preferences in my German version of OS X - there it is called "Bedienungshilfen".
    October 2004
    129
    You have to do this on Snow Leopard too... There has to be a hint in the Hotkeydialog like we sayed before Peter.
    Berlin, Germany
    Just for your info:
    After "Enable access for assistive devices" / "Zugriff für Hilfsgeräte aktivieren" it works under Tiger (4.11) too.
    Cu
    TuxB12
    foo
    7
    Side note: With TeamSpeex, the inofficial TS2 client for Mac, Hotkeys used to work without "Enable access for assistive devices". I don't know why, but one might take a look at their source code ;-)
    August 2010
    ohio usa
    Universal Access Selected Still Cannot Change Mute Keys
    15" macbook pro 2.4 ghz core duo 2gb mem os x 10.6.4
    cannot change hotkeys for muting mic and sound!
    assistive devices always has been selected!
    please help me have checked library for applic support no file there
    how do i change these keys have done setup wizard does not work
    have uninstalled reinstalled does not work
    please help guys
    August 2012
    Push-to-talk doesn't work outside the actual TeamSpeak Client
    This is the first time I've experienced this problem.
    The PTT button (v in my cas) work perfectly when I am "focused" on the TS client. So whenever I'm browsing, playing or working, using TS with PTT doesn't work. It doesn't seem to have anything to do with the client version since I've taken my broher's version (older one) and put it on my computer. It didn't work ; so it must have something to do with the computer itself. I used SoundFlower that day on TeamSpeak (it made it crash). I don't know if the problem happend after that or not.
    Thanks in advance
    This thread was merged.
    July 2006
    1,600
    In general: always use the newest version!
    For your problem: try running as administrator.
    August 2012
    I am administrator. Tried with Pseudo too, but didn't work. AGAIN I always use the latest version. I just tested with an older one to see
    I can confirm the phenomena reported by Wolfunov.
    The same is happen with my MAC (OS X 10.7.4).
    If the TS Window is in the back, Push to Talk is not working.
    6,079
    This is due to security settings in Mac OSX which does not forward keypresses to the TeamSpeak 3 Client and is already explained in both stickies in this forum.
    August 2012
    Resetting Permissions seem to have resolved the problem
    November 2012
    Hotkey does no longer work outside TS application.
    Recently my hotkey has stopped working if I don't have teamspeak as the active application.
    Once i switch over to teamspeak it works perfectly.
    I have read the stickies about this, i have enable access for assistive devices enabled, it actually worked a few weeks ago. I'm totally out of idea's now, any help would be appreciated.
There are currently 5 users browsing this thread. (0 members and 5 guests)
  1. [No Bug] My hotkeys do not work on OS X with client 3.1.1
    By gilroykilroy in forum Bug Reports [EN/DE]
    Last Post: February 25th, 2017, 08:14 PM
  2. Hotkeys don't work
    By Szczaff in forum Windows
    Last Post: November 27th, 2016, 05:03 PM
  3. Hotkeys sometimes work sometimes not
    By Gamecube in forum Windows
    Last Post: June 28th, 2015, 06:32 PM
  4. Hotkeys don't work at all
    By Nextelracer in forum Client Support
    Last Post: February 5th, 2014, 02:23 PM
  5. My Hotkeys Will not Work at All
    By NAHNEN in forum Bug Reports [EN/DE]
    Last Post: January 26th, 2014, 09:03 AM
