Results 16 to 30 of 48
  1. #16
    June 2013
    Mic hotkey doesn't work In-game
    I always have to tab out into TS3 to speak into my mic, when I am playing a game it never lets me use the TS3 mic unless tabbing out, how can I fix this?
  2. #17
    October 2013
    Trouble with TS3.
    Im having trouble with TS3. Ive managed to get the push-to-talk button working, but it only works when Im in TS3.
    I play World of Warcraft, so TS3 would be great for raiding, it used to work on my old computer, but after I bought a MacBook Pro, I need to actually have TS3 open and the one thing Im focusing on for the pusk-to-talk button to work.
    Why is that, and is there anything I can do to change it?
  3. #18
    October 2013
    If you are running OS X Mavericks, the procedure for getting hotkeys to work globally has changed.
    Run TeamSpeak.
    Go to System Preferences > Security & Privacy > Privacy > Accessibility
    Unlock the padlock to make changes, and check TeamSpeak 3 Client.app in the list of apps that can control your computer.
    Once you have done this, you will be able to use your hotkey globally.
    Prior to Mavericks, you go to System Preferences > Accessibility and check "Enable access for assistive devices"
  4. #19
    November 2013
    Push to talk and mac OS 10.9
    So I updated my mac to OS 10.9, but after that update, my PTT don't work unless i have the TS3 window open.
    I fixed this issue before with the whole Universal Access and so on, but they removed that function in there..
    I tryed to find a solution, without any answers, so I hope you guys can help!
    - Líliith
  5. #20
    December 2013
    Push To Talk Help
    When i press my push to talk button on the TeamSpeak window open, i can hear them and they can hear me. But when I go into counterstrike GO, the hotkey docent work. I have put accessibility on TeamSpeak in the settings, but it still fails to work.
    Could anyone help?
    Last edited by dante696; December 10th, 2013 at 11:53 AM. Reason: threa merge. please red sticky threads first
  6. #21
    December 2013
    How to play games like WoT and talk on TS3 at the same time??? Mac OS X
    I've been trying to find out how to talk to my teammates on WoT without clicking on the TS3 window and having to go back when i'm done speaking. Is there a specific way that people have their TS3 configured to talk while playing other games on Mac OS X? If there is please reply.
  7. #22
    4,331
    Use push to talk with different keys in TS3 and whatever WoT is.
  8. #23
    January 2014
    Massive Problems with PTT only recently appeared.. WIll only allow PTT if TS is selected as 'active' program.
    Mac Maverick 10.9.1
    TS 3.0.13.1v v4.8.3
    System Control Granted to TS through Security and Privacy->Accessibility-> Privacy.
    Have tried ->
    Uninstall and reinstall of TS - Nothing
    Changinf Bound Hotkey- Nothing
    Manually deleting Cache and hotkey.ini - NOthing
    I have absolutely no clue what to do further ..
    Last edited by dante696; January 18th, 2014 at 08:32 PM. Reason: was in wrong thread.
  9. #24
    January 2014
    Quote Originally Posted by Troydee View Post
    Mac Maverick 10.9.1
    TS 3.0.13.1v v4.8.3
    Have tried ->
    I have the same problem here! tried everything!
    Someone have this working? its really important to me to have this working again, need a speed update i think!
  10. #25
    January 2014
    Quote Originally Posted by AndRec View Post
    For OS X 10.9.x users you will not find the required setting under Universal Access. Instead do the following:
    Go to: System preferences > Security & Privacy > tab privacy > go to 'Accessibility' > tick Teamspeak client. This does the trick
    Last edited by wesleya; February 5th, 2014 at 03:16 PM. Reason: To make it more clear
  11. #26
    March 2014
    mavericks
    just installed osx maverick and i realize my "Push to talk" button only works if the teamspeak window is active.
    any idea how to fix the problem?
    thanks
  12. #27
    March 2014
    I run OS X Mavericks
    Run TeamSpeak.
    I did everything but I can still not select Mouse Button 4 or 5 for example.
    Problem still there!
  13. #28
    17,824
    Only mouse 1 -3 are supported on Unix systems (Linux and OS X) with our current hotkey system.
    That's no bug
  14. #29
    March 2014
    OK but before the last patch mousebutton 4+5 work fine. Why did you change this?
    Is there something planed?
  15. #30
    17,824
    We did not change that and I can't add mouse 4 or 5 in client 3.0.13.1.
    This statement is from 2010
    Only normal Keyboard and mouse 1,2,3 will work under linux.
    http://forum.teamspeak.com/showpost....79&postcount=6
    It's currently not planned to overhaul the whole hotkey system. This is would be needed to add the support for UNIX systems.
  1. [Resolved] Teamspeak 3 disables my media player's global hotkeys?
    By chaosglory in forum Windows
    Last Post: April 19th, 2015, 01:41 PM
  2. [Resolved] Hotkeys not working
    By Jolle in forum General Questions
    Last Post: May 29th, 2014, 01:17 PM
  3. Hotkeys not working?
    By DanTheHumann in forum General Questions
    Last Post: December 14th, 2013, 06:10 PM
  4. None of my hotkeys are working...
    By McJamesV in forum Windows
    Last Post: February 27th, 2012, 10:14 AM
  5. Replies: 0
    Last Post: September 8th, 2010, 04:45 PM
