Results 1 to 2 of 2
    September 2005
    Sweden
    26
    "Remove background noise", TTS and other things
    * First of all - where is the BIG _CONNECT_ button? Why do i have to use some small menu Connections -> Connect, why can't I have a nice big clear button instead?
    * This feature is currently turned on by default, however, it does quite significantly decrease voice quality and adds a digital "tone" to it. - It would be very appreciated if this feature was not enabled by default because every user I have has to turn it off, which is a tad annoying.
    * You should be able to select a different TTS voice from within the TS client instead of having to navigate out into windows and open up seldom used pages.
    * The sound pack volume control does not work for the TTS voice like it should.
    * The channels should be able to have a phonetic name.
    * Glance into all channels should be able to be turned on by default, either in client side or even more preferably in server side as well.
    * Why show my Platform and Version for other users? To make sure they can find out if i have an "insecure" setup?
    * Why show my Client ID, Database ID and Unique ID for other users? Perhaps only show for admin/SU etc?
    * Custom channel icons set serverside would be nice
    * Permission system - I wanna be able to copy a permission setting and clone it to a new group, or similair.
    Portugal
    492
    Quote Originally Posted by Ernesto View Post
    Yea...i guess it wouldn't hurt. Also adding the option to access the bookmarks from the connect menu would save time.
    Are you talking about the "remove background noise" option? I've seen people talking about it, but im unable to reproduce.
    I don't think we need to go that specific. That isn't a thing that you need to change all the time for sure.
    This sound more relevant, but i don't think that will be easy.
    Indifferent.
    The old Clan and Public modes are being reintroduced in BETA 3 to solve that issue.
    Point.
    Its not that they can do much with it, cause the client and database IDs are for admin management and the unique ID is the public key, but again, theres no need to show that to normal users.
    Indifferent.
    Never got really deep into permissions but that does sound like a nice feature to have.
    Regards
  1. Replies: 2
    Last Post: July 8th, 2015, 11:39 AM
  2. Background noise "Bird sounds"
    By MagmaUrf in forum Windows
    Last Post: May 21st, 2014, 10:48 PM
  3. How to remove "connect" and "disconnect" popups on overlay?
    By Floydrose in forum General Questions
    Last Post: July 30th, 2012, 03:35 PM
  4. [Resolved] remove icons "Moderated" and "Music codec
    By Desperate55 in forum Permission System
    Last Post: November 30th, 2011, 09:35 PM
