Results 1 to 9 of 9
    Vienna
    9
    Level 2 "Server Query Admin" Problem..
    Hi!
    As i said in the title I have a problem with the "Server Query Admin".
    I have my server hosted at NGZ-Server.de and not local and so i can't do this per SQL or
    is there a way to get me as "Server Admin" (Level 6) to a "Server Query Admin" (Level 2) ?
    Greetz xoaC.
    December 2004
    US
    16
    Once you enter your token to get server admin you will need the serveradmin password and the follow the instrutions here for the server query. ignore the fist post about the ini http://forum.teamspeak.com/showthread.php?t=46779
    Vienna
    9
    I know.. but then i get the "b_client_issue_client_query_command" error..
    December 2004
    US
    16
    you will need to get you service provider to reset your database. I dont think they will let you have query rights as it is designed for the server owner only.
    i have a big problem, i have a server query admin on 1st and when i make a 2nd server i must create a new identity for the server query admin account.
    but i will make 1 identity with server query admin for all servers.
    the problem is unique id, it can´t 2x insert in the database.
    is this a bug?
    Netherlands
    9
    I get the samen error, even when i deleted the database..
    I still get this error..
    somebody knows a GOOD solution ?
    November 2007
    10
    First you have to use the token and then server query!
    Usa
    hey i also had the problem with b_client_issue_client_query_command when trying to log in the server query but i finally got it to work
    what i did was i uninstalled 'ts3beta2 client' via control pannel -> programs and features (vista) and afterwards deleted the whole folder of the server 'teamspeak3-server_win32'
    then i redownloaded both the client and server and made a fresh install
    i started the server and made a note of my serveradmin password
    started ts3 client, logged in to my server and used the token to activate server admin
    then i went to Tool -> ServerQuery and entered the following:
    login serveradmin password
    use sid=1
    servergroupaddclient sgid=2 cldbid=2
    *note* serveradmin = username and password = the password that pops up when you start your server the first time
    hit the green/red arrow and voila was logged in as serverquery admin
    so best thing is to uninstall ts3client and delete the whole server folder not just the database. but doing that you'll loose everyting you had befor
    hope this helped
    Hungary
    14
    Note for the previous post if not clear :P
    I had the same problem with the serverquery. To use the servergroupaddclient query, you must use the serveradmin "account" made by the server (the one on the console window at the first run)! There is a way to create new serverquery authentication data for yourself but that doesn't have the required permissions.
    Hope I could help for some of you
  1. [Rejected] [Suggestion] Year measurement for bans and security level increasing "a" to "y"
    By Morthawt in forum Suggestions and Feedback
    Last Post: September 23rd, 2014, 05:06 PM
  2. Server Query Admin Kicked by "Unknown from IP:PORT"
    By otdto in forum Permission System
    Last Post: March 25th, 2013, 01:24 PM
  3. Server/Channel Admin has no "S"/"C"
    By xdesirez in forum General Questions
    Last Post: April 17th, 2010, 05:39 PM
  4. Replies: 0
    Last Post: December 23rd, 2009, 08:49 PM
