Results 1 to 5 of 5
    Hungary
    14
    Thumbs up Bug? Token System
    I am not sure if it is a bug or not, but maybe it is:
    The Token System is new in Teamspeak 3 and I have started using it. I found it as a possible way to give someone Channel Admin permission to a given channel. I have entered the token manager and made a new token:
    Channel Group ID | Channel Admin | Test 1
    The token has been succesfully created and the token has received it's unique ID. We give the ID to the user and he uses the token. The followings can happen:
    • Option 1:
      If he's not in the channel where he should receive the CA, nothing will happen. The token gets used and he doesn't receive anything.
    • Option 2:
      If he is in the channel, he will receive his CA, but if he leaves the channel and joins it again, he will be a guest again.
    Maybe I am just wrong and the token system can only be used for giving temporary priviliges but I don't think it would be useful then. And if yes, then how can it be that I am Server Admin all the time with using a token once :P
    The feature has been tested with SQLite 3 and MySQL too, so it's not a DB error (like it cannot save the new data in DB).
    Hungary
    14
    Well, now as I checked it, when the user receives Channel Admin - from the token -, he doesn't receive any rights. I think the user just receives a beautiful group icon after his name and that's all :P
    December 2007
    Austria,Linz
    214
    Is the Channel Admin Group a temporary group at your "system" ?
    Hungary
    14
    No it is not. I am using the default configuration of TS3. If I give a Channel Admin with right clicking on his name/set channel group/channel admin, he becomes a CA and receives all priviliges for it (and don't lose it with reconnecting etc :P )
    Hungary
    14
    Seems to be fixed in Beta 3
  1. Token System, With Permissions. Web Based
    By slowride326 in forum Server Support
    Last Post: July 14th, 2013, 06:34 AM
  2. Security issue with Token System?
    By Siedler in forum General Questions
    Last Post: March 21st, 2012, 09:54 AM
  3. Regarding the security of the token system
    By ermacignu in forum Off Topic
    Last Post: July 25th, 2011, 02:11 AM
  4. Do away with Token system?
    By Aroeseo in forum Server Support
    Last Post: February 18th, 2010, 03:24 AM
  5. Bug? Token System
    By Gubi1990 in forum Windows
    Last Post: December 21st, 2009, 10:36 PM
