Page 12 of 17 FirstFirst ... 21011121314 ... LastLast
Results 166 to 180 of 251
  1. #166
    March 2010
    NH
    As someone else mentioned a while ago PunkBuster is kicking players who use your app. I was just on one of our Bad Company 2 servers and was kicked for running multiple directx or something. I've used other overlays with BC2 and this did not happen...though that was some time ago. Don't know if you can do anything or not, but wanted to mention it.
  2. #167
    April 2010
    Neverland
    8
    Quote Originally Posted by [CF]Stoner View Post
    I can confirm this. ARMA2 just hangs at start-up if it's added to the whitelist.
    For now I've reverted back to TS3 Build 10406 and TSNotifier 1.1.4
    Yours is the best TS overlay I have tried so far, and would love for this issue to be resolved so I can use the latest TS3 Beta.
    Great job with the program, but in the new version Arma2 is still freezing . Could be posible to release a version compatible with TS3 beta20 and the old overlay metod for games?
  3. #168
    14
    showing incoming whispers would be awesome
  4. #169
    May 2010
    portugal
    im still having some problems with the overlay.
    am using windows 7 ultimate 32 bit, downloaded the latest versions of TSNotifier and helper plugin and reinstalled it.
    what is happening to me is that on the channel description shows me chinese caracters, and when someone speaks (even myself) i dont get any overlay about the speaker at all. i also dont get any notifications about teamspeak logins and logouts on the TSNotifier log.
    have also tryed to run both TSNotifier and TeamSpeak with admin rights, no sucess, still shows the chinese caracters and no warnings about speakers/logs.
    i am running it mostly in the mmo Aion, but tryed over other games and hapens the same. any idea or possible solution? directX was recently updated also.
  5. #170
    91
    Quote Originally Posted by night_lover View Post
    Seems like you got some fileversion mixups. Please uninstall tsnotifier and delete its installation-folder. Then reinstall both TSNotifier and HelperPlugin.
  6. #171
    May 2010
    portugal
    that was the error, i installed the latest version over the old one but didnt updated, windows was still assuming the old one was present, confirmed this because both versions were present in the add/remove programs of windows.
    uninstalled both, deleted TSN folder, installed again latest version and copyed once again helper plugin into TS\plugins folder.
    all seems to work fine now, thanks for the great tool and help, hope you have the time to improove it even more.
  7. #172
    January 2009
    Denmark
    Quote Originally Posted by cfxxl View Post
    Hey all
    I would so much like to get this to work ... but i really do NOT understand what is required.
    1. download ts3, installing it
    2. downloading ts notifier and helper
    3. installing ts notifier
    4. extracting helper and overwriting similar files found in ts notifier folder
    5. run ts3
    then what?
    because when I look in TS3, Settings, Plugins i see nothing.
  8. #173
    December 2004
    18
    The helper files needs to be in the TS3 plugin folder. (The right one 32 or 64 bit).
    After installing start your game first. Then rightclick on TSNotifier and edit the config file (enable your game).
    cu...
  9. #174
    27
    I tried to do the same (revert back), so I installed the beta17 client (Build 10406) and downloaded the old version of tsnotifier. Unfortunatelly, the plugin won't show up in TeamSpeak3 (yes, I downloaded the old plugins aswell). Any ideas?
  10. #175
    April 2010
    7
    Quote Originally Posted by Juleulven View Post
    Hey all
    1. Download and install TS3
    2. Download TSNotifier and helper-plugin
    3. Install TSNotifer
    4. Copy Helper-plugin into "plugins" in TS3-folder - 32bit or 64bit depending on version of TS you use (not Windows!).
    5. Run TS3 -> Settings -> Plugins -> activate the Helper-Plugin
    6. Run TSNotifier and add the game-EXE to whitelist
    7. Run your game
  11. #176
    91
    Quote Originally Posted by Teamspeakeuser View Post
    Just copy both versions, ts3 will select the correct one.
  12. #177
    May 2010
    Ok I got it to work with WoW and Battlefield 2
    Bad Company 2 is in Dx11 so this is the problem.
    But as I know 1942 are in DX9 so these should work shouldn´t it? Or if they are right now DX10 could this also be the problem?
    I added them into the list:
    I have Win 7 32.
    BF1942 is running in admin mode, and all the addons I have also. I would like to get the overlay to work becuase I need it.
    The mods I am using are:
    FH0,7 and 1918... all in admin mode.
    EDIT::
    Ok BC2 in DX9 does work =) great =)
    I only have to get 1942 to work and I am the happiest boy in the world for the moment
    A reqzest/question:
    Is it already possible to change the size of the text? becuase it is really big right now and if not is it possible to implent it ino the Notifier?
  13. #178
    May 2010
    Norway
    TSNotifier doesn't work with Battlefield Heroes
  14. #179
    May 2010
    France
    Mac Version
    Hello.
    Somebody know if TSO for MacOS exist?
    OS: Mac OS 10.5
    Soft : TS3
    Game : WoW
  15. #180
    June 2010
    France
    Question Tso ?
    Hi everybody,
    I use TS2 actually and will strat with TS3.
    On TS2 i have TSO (Teamspeakoverlay), which let me se the talking person in game (WoW).
    I want to know if this kind of software is existing for TS3.
    Thanks in adwance for your answers.
    Perry
    P.S.: I have searched on the forum but could not faund anything.
  1. Plugin overlay
    By papagrizzlybear in forum Client Plugins / Lua Scripts
    Last Post: August 15th, 2013, 01:00 AM
  2. [Rejected] TS3 Overlay Plugin
    By Gluecksbaerli in forum Suggestions and Feedback
    Last Post: March 25th, 2013, 08:17 AM
  3. Ts 3 overlay plugin 3.5.6
    By geordieriddle in forum Client Plugins / Lua Scripts
    Last Post: August 6th, 2012, 10:36 AM
  4. Rc1: DX Overlay Plugin WOW
    By WoFNuLL in forum Bug Reports [EN/DE]
    Last Post: May 22nd, 2011, 05:28 PM
  5. ts3 overlay plugin (Failed to open plugin)
    By netmario in forum Windows
    Last Post: September 22nd, 2010, 09:29 AM
