Results 31 to 45 of 58
  1. #31
    February 2010
    Right here!
    Moin
    Quote Originally Posted by nwerensteijn View Post
    So you have problems with the beta18 server and you don't with the beta15 server?
    precisely
    When you start beta18, does that create new virtual servers, or use the old ones?
    new ones. It creates a new database and stuff
    When you stop the beta15 server, how do you do that?
    Like this:
    ./ts3server_startscript.sh stop
    If it turns out that the answers to these questions still do not answer the problem, I'd like to communicate more directly via email to solve your problem, is that ok with you?
    Ok. IM or Email either is fine with me.
    Regards, Cloobon
  2. #32
    February 2010
    N. USA
    I'm also having the same problem, deleted my config file and started over. I hope this doesn't happen all the time.
  3. #33
    June 2002
    Netherlands
    1,049
    Quote Originally Posted by Aroeseo View Post
    Did that work? On which server version?
  4. #34
    January 2009
    16
    Too many virtualservers running, shutting down!
    Since a few days, my ts3 server is going down in regular intervals. My log file says this:
    2010-02-12 16:10:19.113056|INFO    |ServerLibPriv |   | Server Version: 3.0.0-beta18 [Build: 10190]
    2010-02-12 16:10:19.125669|INFO    |DatabaseQuery |   | dbPlugin name:    SQLite3 plugin, (c)TeamSpeak Systems GmbH
    2010-02-12 16:10:19.125802|INFO    |DatabaseQuery |   | dbPlugin version: 3.6.21
    2010-02-12 16:10:19.126400|INFO    |DatabaseQuery |   | checking database integrity (may take a while)
    2010-02-12 16:10:19.178542|INFO    |SQL           |   | pruning old database log entries where timestamp is older than 90 days
    2010-02-12 16:10:19.451954|INFO    |Accounting    |   | Licensing Information
    2010-02-12 16:10:19.453031|INFO    |Accounting    |   | type              : Non-profit
    2010-02-12 16:10:19.453935|INFO    |Accounting    |   | starting date     : Tue Dec 22 00:00:00 2009
    2010-02-12 16:10:19.454706|INFO    |Accounting    |   | ending date       : Wed Dec 22 00:00:00 2010
    2010-02-12 16:10:19.455396|INFO    |Accounting    |   | max virtualservers: 10
    2010-02-12 16:10:19.456056|INFO    |Accounting    |   | max slots         : 512
    2010-02-12 16:10:19.516213|INFO    |FileManager   |   | listening on 0.0.0.0:30033
    2010-02-12 16:10:19.567687|INFO    |VirtualServer |  1| listening on 0.0.0.0:9987
    2010-02-12 16:10:19.568293|INFO    |Query         |   | whitelist ips: 127.0.0.1,
    2010-02-12 16:10:19.569355|INFO    |Query         |   | listening on 0.0.0.0:10011
    2010-02-12 16:10:19.888941|ERROR   |Accounting    |   | too many virtualservers running, shutting down!
    2010-02-12 16:10:20.024296|INFO    |VirtualServer |  1| stopped
    I have only 1 virtual server running.
    I can start the server with the webinterface after it stopped. But then after about 40 minutes it shuts down again.
    I hope someone can help me.
  5. #35
    February 2010
    N. USA
    Worked for me, on server version beta 18 build: 10190. Hope it doesn't happen again.
  6. #36
    Secret Base in Arctic Region
    1,671
    did you restart the instance after copying the license file, as it was mentioned in the email?
  7. #37
    January 2009
    16
    Yes, i did. I have this problem since a few days. Before everything was ok
  8. #38
    2,029
    How many Slots does your VirtualServer have?
    Did you by any chance use the same license on any other PC?
    Is it possible that your license leaked to someone else beside you?
    In case you put 512 as max Slots on your VirtualServer try reducing it to 500.
    Edit: Also check out this Thread on the same Topic
  9. #39
    February 2010
    NZ
    Hey guys,
    Yep problem has been fixed for me, traced back to the kill command lol. Mine is online now no probs.
    Thanks to nwerensteijn for the info
  10. #40
    June 2002
    Netherlands
    1,049
    Quote Originally Posted by crazednz View Post
    We are here to serve
  11. #41
    January 2009
    Moscow
    29
    Same problem ((((
    I installed the server again, deleted the database, copied the license file and started giving this error
    No license is working properly. Previously, all worked with this license, and all previous versions.
    2010-02-19 00:33:15.514250|INFO |ServerLibPriv | | Server Version: 3.0.0-beta18 [Build: 10190]
    2010-02-19 00:33:15.514250|INFO |DatabaseQuery | | dbPlugin name: MySQL plugin, (c)TeamSpeak Systems GmbH
    2010-02-19 00:33:15.514250|INFO |DatabaseQuery | | dbPlugin version: 1
    2010-02-19 00:33:15.514250|INFO |SQL | | pruning old database log entries where timestamp is older than 90 days
    2010-02-19 00:33:16.061125|INFO |Accounting | | Licensing Information
    2010-02-19 00:33:16.076750|INFO |Accounting | | type : Non-profit
    2010-02-19 00:33:16.123625|INFO |Accounting | | starting date : Tue Dec 22 02:00:00 2009
    2010-02-19 00:33:16.139250|INFO |Accounting | | ending date : Wed Dec 22 02:00:00 2010
    2010-02-19 00:33:16.170500|INFO |Accounting | | max virtualservers: 10
    2010-02-19 00:33:16.186125|INFO |Accounting | | max slots : 512
    2010-02-19 00:33:16.576750|INFO |FileManager | | listening on 0.0.0.0:30033
    2010-02-19 00:33:17.858000|INFO |VirtualServer | 1| listening on 0.0.0.0:9987
    2010-02-19 00:33:17.904875|INFO |Query | | whitelist ips: 127.0.0.1,
    2010-02-19 00:33:17.920500|INFO |Query | | listening on 0.0.0.0:10011
    2010-02-19 00:33:18.170500|ERROR |Accounting | | too many slots hosted, shutting down!
    2010-02-19 00:33:18.342375|INFO |VirtualServer | 1| stopped
  12. #42
    January 2009
    Moscow
    29
    I remembered the main thing. When I upgrade to 18 betta then everyone else has worked, but had only installed on the same PC clean version (deleted files and database server other than the license and configuration files INI) as the top issue this error when the server starts. That's when you start the server!
    What is the problem??
    I would like to hear from the creators of TS3 - Is it possible that someone had stolen the license file and run your server and therefore the collision occurs.
  13. #43
    September 2009
    I got the same error after I wanted to setup the a new ts3 server (beta18)
     ./ts3server_minimal_runscript.sh
    TeamSpeak Server 3.0.0-beta18 [Build: 10190]
    Logging started
    2010-02-19 17:16:16.819186|INFO    |ServerLibPriv |   | Server Version: 3.0.0-beta18 [Build: 10190]
    2010-02-19 17:16:16.822160|INFO    |DatabaseQuery |   | dbPlugin name:    MySQL plugin, (c)TeamSpeak Systems GmbH
    2010-02-19 17:16:16.822241|INFO    |DatabaseQuery |   | dbPlugin version: 1
    2010-02-19 17:16:17.165864|INFO    |SQL           |   | db_CreateTables() tables created
                          I M P O R T A N T
                  Server Query Admin Acccount created
             loginname= "serveradmin", password= "********"
    2010-02-19 17:16:17.688143|INFO    |Accounting    |   | Licensing Information
    2010-02-19 17:16:17.689191|INFO    |Accounting    |   | type              : Non-profit
    2010-02-19 17:16:17.690008|INFO    |Accounting    |   | starting date     : Fri Dec 25 00:00:00 2009
    2010-02-19 17:16:17.690803|INFO    |Accounting    |   | ending date       : Sat Dec 25 00:00:00 2010
    2010-02-19 17:16:17.691033|INFO    |Accounting    |   | max virtualservers: 10
    2010-02-19 17:16:17.691797|INFO    |Accounting    |   | max slots         : 512
    2010-02-19 17:16:17.733830|INFO    |FileManager   |   | listening on 85.214.68.149:30030
    2010-02-19 17:16:17.985122|INFO    |VirtualServer |  1| listening on 85.214.68.149:9987
    2010-02-19 17:16:17.986964|INFO    |VirtualServer |  1| client 'server'(id:0) added token for servergroup 'Server Admin'(id:6)
    2010-02-19 17:16:17.987769|WARNING |VirtualServer |  1| --------------------------------------------------------
    2010-02-19 17:16:17.987996|WARNING |VirtualServer |  1| ServerAdmin token created, please use the line below
    2010-02-19 17:16:17.988766|WARNING |VirtualServer |  1| token=*************************
    2010-02-19 17:16:17.988986|WARNING |VirtualServer |  1| --------------------------------------------------------
                          I M P O R T A N T
          ServerAdmin token created, please use it to gain
          serveradmin rights for your virtualserver. please
          also check the doc/token_guide.txt for details.
    2010-02-19 17:16:17.990946|INFO    |Query         |   | whitelist ips: 127.0.0.1,
    2010-02-19 17:16:17.992106|INFO    |Query         |   | listening on 85.214.68.149:10010
    2010-02-19 17:16:18.363629|ERROR   |Accounting    |   | too many slots hosted, shutting down!
    2010-02-19 17:16:18.496742|INFO    |VirtualServer |  1| stopped
    btw my englisch ist very bad ^^
    Edit:
    i got it
    i deleted the serverkey.dat then the error go away
  14. #44
    January 2009
    Moscow
    29
    Quote Originally Posted by chi110r View Post
    Edit:
    i got it
    Strange! I removed serverkey.dat not help, but today it helped)))
    Server starts up again with the license!
  15. #45
    February 2010
    tx
    You can add me to the list of people with this error. I set up a server yesterday and it was working fine. Today I put in the license and it worked ok for a while. Then I couldn't connect to it and neither could anyone else. Reinstalled everything and it's still not working. I tried the things that others mentioned that worked for them and I haven't been able to get it to work for me. Any helpful info would be greatly appreciated.
    2010-02-28 01:25:59.464652|INFO    |ServerLibPriv |   | Server Version: 3.0.0-beta18 [Build: 10190]
    2010-02-28 01:25:59.464652|INFO    |DatabaseQuery |   | dbPlugin name:    SQLite3 plugin, (c)TeamSpeak Systems GmbH
    2010-02-28 01:25:59.464652|INFO    |DatabaseQuery |   | dbPlugin version: 3.6.10
    2010-02-28 01:25:59.464652|INFO    |DatabaseQuery |   | checking database integrity (may take a while)
    2010-02-28 01:25:59.474652|INFO    |SQL           |   | pruning old database log entries where timestamp is older than 90 days
    2010-02-28 01:26:00.164653|INFO    |Accounting    |   | Licensing Information
    2010-02-28 01:26:00.164653|INFO    |Accounting    |   | type              : Non-profit
    2010-02-28 01:26:00.174653|INFO    |Accounting    |   | starting date     : Fri Feb 26 18:00:00 2010
    2010-02-28 01:26:00.174653|INFO    |Accounting    |   | ending date       : Sat Feb 26 18:00:00 2011
    2010-02-28 01:26:00.174653|INFO    |Accounting    |   | max virtualservers: 10
    2010-02-28 01:26:00.184653|INFO    |Accounting    |   | max slots         : 512
    2010-02-28 01:26:00.224653|INFO    |FileManager   |   | listening on 0.0.0.0:30033
    2010-02-28 01:26:00.324653|INFO    |VirtualServer |  1| listening on 0.0.0.0:9987
    2010-02-28 01:26:00.324653|INFO    |Query         |   | whitelist ips: 127.0.0.1,
    2010-02-28 01:26:00.334653|INFO    |Query         |   | listening on 0.0.0.0:10011
    2010-02-28 01:26:01.154654|ERROR   |Accounting    |   | too many slots hosted, shutting down!
    2010-02-28 01:26:01.284654|INFO    |VirtualServer |  1| stopped
  1. [Resolved] too many slots hosted, shutting down!
    By dante696 in forum Server Support
    Last Post: July 12th, 2019, 02:07 AM
  2. too many slots hosted, shutting down
    By GerrardLFC in forum Server Support
    Last Post: September 26th, 2014, 08:41 AM
  3. too many slots hosted, shutting down! - problem
    By Mareczin in forum Server Support
    Last Post: March 13th, 2014, 03:01 PM
  4. too many slots hosted, shutting down
    By asd3344 in forum Server Support
    Last Post: June 21st, 2010, 04:50 PM
