Results 1 to 12 of 12
    Belgium
    18
    Solved Problem starting the server. License port
    the first time i started the server everything went smooth, after ive upgraded it it was still working.
    but the server randomly crashed and now when i try to restart it it gives me the following output:
    2009-12-23 04:00:43.668200|ERROR   |Accounting    |   | Unable to connect to accounting server
    2009-12-23 04:00:43.668690|ERROR   |ServerLibPriv |   | Server() error while starting servermanager, error: unable to connect to accounting server
    whats the ip of this "accounting server"? because it might have ended up in my iptables...
    Also this happened right after i added the "license.dat" file to get a valid license key.
    Iowa
    10
    I can confirm this. After uploading our newly acquired license key. I rebooted the server and got the same error. After updating to the numerous new betas, this problem still isn't fixed.
    Logging started
    2009-12-23 20:35:14.814814|INFO    |ServerLibPriv |   | Server Version: 3.0.0-beta6 [Build: 9494]
    2009-12-23 20:35:14.815535|INFO    |DatabaseQuery |   | dbPlugin name:    MySQL plugin, (c)TeamSpeak Systems GmbH
    2009-12-23 20:35:14.815570|INFO    |DatabaseQuery |   | dbPlugin version: 1
    2009-12-23 20:38:27.287932|DEVELOP |              |   | TS3ANetwork::Connect failed error: 110
    2009-12-23 20:38:27.288117|ERROR   |Accounting    |   | Unable to connect to accounting server
    2009-12-23 20:38:27.288607|ERROR   |ServerLibPriv |   | Server() error while starting servermanager, error: unable to connect to accounting server
    Segmentation fault
    After deleting the license key, the server boots up no problem.
    December 2007
    Austria,Linz
    214
    The port 2008 must be open.
    Or you mean, that the license "worked" fine, at beta5 as beta6 ?
    Iowa
    10
    Thanks for the reply. I sent a ticket to get the port opened on our firewall. I wasn't aware that there was more than 3 ports that you needed access to.
    I will reply back if it works.
    also, "Or you mean, that the license "worked" fine, at beta5 as beta6 ?"
    After uploading the licence and rebooting the server wouldnt start. Even at the latest beta.
    December 2007
    Austria,Linz
    214
    ah, this is your first start with the license, right?
    Iowa
    10
    yeah
    12345678910 "why have a stupid minimum character length?"
    December 2007
    Austria,Linz
    214
    OK, so it is sure, that you must open the 2008 port.
    You can make an except for the IP address: 62.146.63.84
    So you don't have to open the port.
    And, the port 2008 is tcp.
    Iowa
    10
    That worked. Thank you :P
    Belgium
    18
    i already figured out that i needed to open port 2008 TCP after looking at my packets in wireshark,
    i think information like this should be provided with the license key.
    July 2014
    Russia, Moscow
    Quote Originally Posted by ethoxyethaan View Post
    Good day!
    Is the information about port for veryfing accounting registration is up to date?
    If it no, what number of potrs must be opened in firewall with non-profit license for stable working of servers?
    Now i have opened 9987 (udp), 10011 (tcp) and 30033 (tcp) ports.
    Best regards, Sergey
    ------ Added later -----------
    I have found information about ports in knowledgebase:
    https://support.teamspeakusa.com/ind...k-3-server-use
    December 2004
    RF
    3,006
    Accounting connection is outgoing, normally does not need any special-casing, unless you have a very-very stupid router.
    But it seems the accounting server have not the best days in it's life right now.
    August 2015
    My teamspeak server is getting the same issue. Does anyone have a fix for this?
  1. I can no longer license despite starting the server
    By Biese1983 in forum Linux / FreeBSD
    Last Post: May 6th, 2013, 03:40 PM
  2. Replies: 3
    Last Post: October 15th, 2012, 01:47 PM
