Results 1 to 6 of 6
    October 2008
    USA
    14
    [BUG] TS3 Beta 5 Permission Mange Tokens Issue
    The manage Tokens isn't working for all of us that tries to make the token on the Client or it could be a server bug not sure. I'm sure it's a small bug.
    June 2002
    Krün / Germany
    1,638
    what is not working? i just checked it and it does work...
    so please give more feedback...
    KY, USA
    13
    I think we are experiencing the same problem since upgrading to beta5.
    Basically normal procedure for granting permissions via token
    but then the client disconnects and reconnects and theyre not a part of the server group, even when using the add button in the server group window the effect only stays untill they disconnect.
    KY, USA
    13
    This also only seems to apply to adding members to an extra servergroup that we created for sub-admins, tried with the same clients sub-admin vs serveradmin and it works fine for the server admin group.
    Also we are using mysql but haven't had any issues there
    October 2008
    USA
    14
    Quote Originally Posted by R. Ludwig View Post
    Went to Permissions->Token Manager->Add Token->Create
    Than Error
    <03:21:08> insufficient client permissions (failed on i_group_member_add_power (17282/0x4382))
    <03:21:09> insufficient client permissions (failed on i_group_member_add_power (17282/0x4382))
    <03:21:32> database empty result set
    Bug maybe?
    We are using SQLite default all the way back from beta1 do we need to do anything extra to make this issue go away?
    When I do update i just copy and replace the files with the server offline than start it back up.
    I'm a server admin and have channel Admin as well when I go to a channel where I have no Channel Admin than it works but when I have both it doesn't work.
    October 2008
    USA
    14
    Also I can't revoke channel admin by right clicking their name and select channel admin it has a check by it but I can't get the check to go away any ideas?
  1. [Resolved] Issue with tokens containing + when using http://www.teamspeak.com/invite/
    By PotaBlava in forum Bug Reports [EN/DE]
    Last Post: March 1st, 2012, 08:27 AM
  2. Permission problems Beta 29
    By Mindwalker in forum Server Support
    Last Post: October 11th, 2010, 04:18 AM
  3. Beta 18 Issue!
    By homerS__ in forum Windows
    Last Post: February 12th, 2010, 02:35 PM
  4. Old Tokens on Beta 17 Update not working
    By Mindwalker in forum Windows
    Last Post: February 7th, 2010, 07:42 AM
  5. Beta-9 serious issue
    By Polarhannes in forum Linux / FreeBSD
    Last Post: December 27th, 2009, 07:04 PM
