Results 46 to 52 of 52
  1. #46
    June 2010
    Michigan
    I had to reinstall TS3 because of HDD problems and I had the same problem as others posted above. I could not select any Hotkey at all on my keyboard. What worked for me was to unhook my Logitech G25 steering wheel and I was immediately able to program my left ALT key as PTT hotkey. I remember now that was what I had to do on the original installation awhile ago.
    Before I had done that I had tried to see if TS3 was being blocked by firewall/antivirus (which it wasnt) I also unchecked the Read Only box when I clicked on Properties for the main TS3 folder.
    If it helps here is what showed up AFTER I was able to set the hotkey. Maybe if you copy and paste to your config folder (opens with Notepad btw) under the PROFILES section and then save the file it SHOULD work for you.
    Hotkeys\Default\Bindings\1\Event\Type=1
    Hotkeys\Default\Bindings\1\Event\Mode=Down
    Hotkeys\Default\Bindings\1\Event\Key1=ALT
    Hotkeys\Default\Bindings\1\Event\KeyIdentifier1=18 64182625-54688-4559-191-199-68-69-83-84-0-056
    Hotkeys\Default\Bindings\1\Event\EventIdentifier={ 61969066-3c73-43ca-8b73-2ffec9d1ce4e}
    Hotkeys\Default\Bindings\1\Action\Type=1
    Hotkeys\Default\Bindings\1\Action\Mode=Activate
    Hotkeys\Default\Bindings\1\Action\Profile=Default
    Hotkeys\Default\Bindings\1\Action\Flag=Push-To-Talk
    Hotkeys\Default\Bindings\1\Action\Auto=true
    Hotkeys\Default\Bindings\2\Event\Type=1
    Hotkeys\Default\Bindings\2\Event\Mode=Up
    Hotkeys\Default\Bindings\2\Event\Key1=ALT
    Hotkeys\Default\Bindings\2\Event\KeyIdentifier1=18 64182625-54688-4559-191-199-68-69-83-84-0-056
    Hotkeys\Default\Bindings\2\Event\EventIdentifier={ 3747f0eb-f45a-4a41-9840-a85b73848272}
    Hotkeys\Default\Bindings\2\Action\Type=1
    Hotkeys\Default\Bindings\2\Action\Mode=Deactivate
    Hotkeys\Default\Bindings\2\Action\Profile=Default
    Hotkeys\Default\Bindings\2\Action\Flag=Push-To-Talk
    Hotkeys\Default\Bindings\2\Action\Auto=true
    Capture\Default\Push-To-Talk=ALT
    *note* I am running latest version 3.0.0 beta22 Build 11315 , on WinXP with standard keyboard (non USB) don't know if it makes a difference or not, but it shouldn't.
  2. #47
    July 2010
    australia
    Quote Originally Posted by ZeroTKA View Post
    Can you right click and run as admin?
    I have the same problem in that it simply doesn't bind a key and run as admin doesn't help.
    I've downloaded the program twice and it's the same both times.
    Any help appreciated.
    thanks
    Ibissix
  3. #48
    July 2010
    australia
    Ok, same problem.
    Disconnected Saitek X45, set key binding and bingo, all's well, reconnected, problem solved.
    thanks for the help.
    cheers,
    Ibis.
    Last edited by Ibissix; July 2nd, 2010 at 07:14 AM. Reason: to add thanks to posters who helped
  4. #49
    November 2008
    United States
    1,719
    thanks for posting your solution.
  5. #50
    March 2011
    Quote Originally Posted by GsG Knighthawk66 View Post
    Thanks, Unplugging the G25 worked and i was able to assign a hotkey!!
  6. #51
    Hotkey issue
    I think we're dealing with multiple comorbid issues here
    1: Saitek joysticks affecting hotkeys
    2: USB keyboards are unrecognized
    3: Hotkey menu isn't working with keyboard input
    I've noticed that the menu works fine with mouse input, including extra keys, at least on my Razer mouse, but it isn't working with input from my laptop keyboard, or my friend's USB keyboard, even after manually setting a hotkey with a script, or using the set-up wizard workaround if any of the TS folks are watching this thread, a hotfix would be appreciated
    EDIT:
    wow, just realized that these posts are a year or two old, this might be something different...
  7. #52
    November 2012
    hey guys i just tryed something and it seems to work,for me at least.
    go to settings>options>hotkeys>see down right "default" change it to "direct input" then apply. and your good to go.
    works for me i hope it works for you guys allso.
  1. Replies: 2
    Last Post: July 8th, 2015, 11:39 AM
  2. Replies: 3
    Last Post: June 22nd, 2010, 11:35 PM
  3. Hotkey for switch "push to talk" and "voice activated"
    By eternal-blue in forum General Questions
    Last Post: January 8th, 2010, 10:08 PM
