Results 1 to 9 of 9
    35
    "detected incorrectly running system clock"?
    I noticed the following warnings in my log files:
    2009-12-23 23:59:49.496595|WARNING |Accounting | | detected incorrectly running system clock
    2009-12-24 01:22:55.526153|WARNING |Accounting | | detected incorrectly running system clock
    2009-12-24 02:45:49.368187|WARNING |Accounting | | detected incorrectly running system clock
    2009-12-24 04:08:51.432043|WARNING |Accounting | | detected incorrectly running system clock
    I haven't ever touched the system clock on the box, so I'm not sure why those warnings are coming up.
    The server (win32) is running beta6.
    November 2002
    Germany / Kempen
    1,367
    maybe the bios clock and/or os clock are not working correctly. You may check this with a system tool or together with your hoster
    england
    16
    bah i get many different server errors relating to clock, ts2 never had this problem.
    35
    I am running the TS3 server on a virtual server.
    June 2002
    Krün / Germany
    1,638
    Quote Originally Posted by m4ccy View Post
    that comment really helps, thanks!
    July 2002
    2,192
    You get this error message when your time source is not stable. This can give you all sorts of problems with many different kinds of software, it is just that TeamSpeak is detecting it and warning you about it, instead of just behaving weirdly which it (and any most other applications that need to measure time for whatever reasons) certainly will. Usually this either means you have a retarded mechanism to synchronize your clock with a time server active (which in effect warps the time around), or your bios/mainboard/cpu clock is brocken, change it.
    You think my answer is stupid ? Read This:
    http://www.catb.org/~esr/faqs/smart-...ons.html#intro
    In a world without fences and walls - who needs windows and gates ?
    December 2004
    RF
    3,004
    Quote Originally Posted by aix59 View Post
    That's the issue. Don't do that.
    November 2002
    Germany / Kempen
    1,367
    In my honiest opinien that's no issue, it's a question of which kind of virtualization you are using.
    October 2008
    Alaska
    14
    I had a timer problem with recording directX games before.
    If you are using third party software that changes CPU clock or a software that controls power management, I recommend uninstalling those.
    Also, some BIOS has that kind of functions by default so you should disable it as well.
    I dont really know if this helps your issue though..just my 2 cents..
  1. [Resolved] "Detected incorrectly running system clock" log message
    By Peter in forum Linux / FreeBSD
    Last Post: February 24th, 2019, 08:54 PM
  2. [Resolved] Server 'crash', "detected incorrectly running system clock"
    By meliorus in forum Server Support
    Last Post: June 5th, 2015, 04:33 PM
  3. Replies: 7
    Last Post: June 10th, 2011, 04:33 PM
  4. "detected incorrectly running system clock"
    By meliorus in forum Bug Reports [EN/DE]
    Last Post: February 3rd, 2011, 01:10 PM
  5. detected incorrectly running system clock
    By SeToY in forum Linux / FreeBSD
    Last Post: January 3rd, 2011, 10:52 PM
