Page 1 of 2 12 LastLast
Results 1 to 15 of 18
    October 2008
    Alaska
    14
    File Transfering Speed Control Command
    Command that controls Upload speed from client is working pretty well but
    the download side seems to be not working.
    is this known bug/prob?
    69
    we are experiencing speed issues with file transfers... I am on a 20mbit connection and my download speed jumps up and down between 150 and 350 kbyte/sec, I never get full speed. This only happens with downloads, uploads have full speed... And since I have 5mbit upstream bandwidth, I can upload faster than I can download!! The TS server has set bandwidth limit to "-1". When I do http or ftp transfers from the same machine, I get full 2.5mbyte/sec. So it is not a problem with my connection or the server.
    Tennessee
    15
    the server admin needs to set up your permission the -1 i seen that and change it to 100which is the highest
    October 2008
    Alaska
    14
    Quote Originally Posted by Failure View Post
    I'm having exactly same issue as yours. Only download speed is unstable and slow.
    October 2008
    Alaska
    14
    Quote Originally Posted by Kratos View Post
    Did you solve this issue with that?
    Which permission do I have to change to 100?
    I'm testing this with server admin account but max granted UP/DL power was 75 and was not change-able
    Quota size seems to be max file size that user can download so I dont think this is relating to the up speed problem.
    If linux/mac user is not having this issue then this is windows only prob?
    Last edited by verana_ss; December 27th, 2009 at 04:50 AM. Reason: resolve -> solve
    69
    I doubt that it has to do with permissions...
    People's permissions and server's settings are both the same for upload and download, but only the download part has problems.
    12
    I'm running my server with the default filetransfer settings and I'm getting around 40-50 MB/s with the server in my Gigabit network. Then the CPU limits the speed because TS3 needs lots of CPU power for data transfers.
    69
    Quote Originally Posted by The_bad_Frag View Post
    Wich OS on server and client side?
    12
    Both running Windows XP SP2. Also works with VHP as client.
    October 2006
    64
    Did anyone work this one out?
    On our server we never download much higher then 100k, sometimes around 40kish. The server is on a 100meg connection so of course we have more speed then we're getting.
    October 2008
    Alaska
    14
    Quote Originally Posted by ciarlo View Post
    afaik not yet.
    I cant even tell whether this issue is coming from settings or a bug(compatibility?)
    I would like to see official comment about this...
    69
    I am able to maximize transfer speed by running several downloads at the same time, but a single download usually runs very unstable at 100-300 kybte/sec.
    This really needs to be fixed...
    18,025
    This is a know bug, with slow upload settings. The client use the cache so it seems that the client uploads much faster.
    Is on todo list with low priority.
    October 2006
    64
    I worked out a solution until they fix it.
    http://forum.teamspeak.com/showthread.php?t=49692
    69
    Why low priority? The filetransfer feature is one of the things wich distinguishes TS3 from all the other voice chat apps out there...
    Downloading with very unstable speeds between 40 - 400 kbyte/sec renders the filetransfer feature useless for me.
    But I'll try to be patient :-)
  1. File-Transfer speed much too low...
    By Chillfaktor in forum Server Support
    Last Post: July 27th, 2015, 04:15 PM
  2. Replies: 1
    Last Post: April 8th, 2013, 12:49 PM
  3. Can i speed up the file transfer rate speed in TS3?
    By KEVN38 in forum General Questions
    Last Post: April 5th, 2011, 12:04 AM
  4. How To Speed Up File Transfer Speeds!
    By ciarlo in forum Server Support
    Last Post: January 11th, 2010, 04:07 PM
  5. Setting File Transfer Speed
    By verana_ss in forum Windows
    Last Post: December 21st, 2009, 09:05 AM
