Page 2 of 5 FirstFirst 1234 ... LastLast
Results 16 to 30 of 61
  1. #16
    Vancouver, BC
    89
    Quote Originally Posted by sonofdresa View Post
    Correct me if I am wrong but if I don't have a mic I am considered idle as I am not speaking right?
    if this is the case and you have someone who has no mic and is then moved to an AFK channel they will be moved every x minutes.
    Maybe an odd question... but why would you be using a voice chat program with no microphone?
    I was thinking of something along the lines of how Ventrilo does it. It monitors whether or not you're moving your mouse, or if there are keyboard actions taking place. If in x number of minutes you haven't moved your mouse or typed anything in it will automatically send you to the AFK channel. This is something that is built into the server, and in my opinion is a brilliant idea.
  2. #17
    December 2004
    RF
    3,006
    Quote Originally Posted by Arterio View Post
    Because i'm listening to orders?
    I've been flying for four months without mic. Cause usually I don't need to give out any info, only follow instructions and pick proper targets.
  3. #18
    Maryland, USA
    100
    Amen Sir... Amen.... I have a Mic and head set. Back when I was using my built in mic people said that I sounded like Kenny from South Park. Thank god I didn't die every raid.
  4. #19
    March 2009
    Netherlands
    39
    Answer to your question sonofdresa:
    If you do NOTHING in Teamspeak you will be moved if your Server Admin implents that kinda MOD. So if you would be typing IN TEAMSPEAK or w/e you aren't considered "idle" but if youre not typing or talking you would be AFK and would be moved to AFK channel
  5. #20
    November 2009
    No
    37
    I'd like this, it could be a virtual server option under the misc tab so that you could say move users that have been idle for x minutes to channel x
  6. #21
    Taiwan
    313
    for one easy and obvious reason, since some people doesn't like to be moved unwillingly.
  7. #22
    October 2008
    Alberta, Canada
    166
    Quote Originally Posted by Ceromus View Post
    Auto move if idle won't be implemented by devs.
    Any particular reason?
    Probably, but the dante never tells us why.
    Quote Originally Posted by willy_sunny View Post
    They're AFK... They're not there to care... If you're gonna be AFK you should either leave or put yourself in the AFK channel, this would be nice to have for the few times people forget. Or say they'll be right back and then they're not. Besides, if you don't want to be moved, find a server where they won't; you can't complain about the rules of a server when there are other choices.
  8. #23
    November 2009
    No
    37
    would it not also save bandwidth to move idle people to a no-speak channel?
  9. #24
    December 2004
    RF
    3,006
    Quote Originally Posted by jesepi View Post
    Once, there was a ship built.
    It was a very comfortable cruise ship, and carefully designed to be as safe as comfortable... one of the safety means projected was that in the case of fire all doors were supposed to automatically close...
    Guess why this system was scratched from final plans? This system was not able to check if there was a people in the way... and what should mean safety was turning into actual danger.
  10. #25
    October 2008
    Alberta, Canada
    166
    That's kind of ridiculous man... Completely different scenario.
  11. #26
    November 2009
    No
    37
    What does that have to do with anything I posted?
  12. #27
    December 2004
    RF
    3,006
    That would save ship from fire. But kill people trapped in the rooms.
    In your scenario, it would only get people upset, however, if they moved to other channel unexpectedly.
  13. #28
    November 2009
    No
    37
    No, it really wouldn't.
    I've had this kind of setup for many years on another similar product, with several hundred users and I have never had a complaint about the auto-afk feature.
    Why? Because they are not there when it happens.
    http://img97.imageshack.us/img97/1684/autoafk.jpg
  14. #29
    October 2008
    Alberta, Canada
    166
    Exactly, if the system was poorly designed and moved clients in error all the time, THAT would be annoying. But if it works properly and only moves people when they're AFK, it's not annoying. They aren't there to even notice, and in most cases, would probably find it helpful: "Oh, did I forget to move myself to the AFK channel? My bad, it's all good though."
  15. #30
    Vancouver, BC
    89
    My TS3 server is used by around 60 people, usually only about 20 at a time though. A lot of these people leave them selves in channels and walk away, some have been good at putting them selves in the AFK channel, but most haven't.
    The idle time is tracked by the client, I don't see why a server side script can't monitor the client idle time and after X number of minutes move the client to a desired channel. I mean they have the Kick if idle for X number of minutes, why can't that just be modified to be Move if idle instead? Then designate a channel as the "idle_channel". Same as you have a "default_channel".
  1. How to create a channel that create sup channel on join?
    By ThunderNRW in forum Server Support
    Last Post: June 1st, 2015, 11:00 PM
  2. [Not possible] Restrict server group to create sub channel in one channel only
    By MicPawnage in forum Permission System
    Last Post: August 9th, 2014, 02:43 PM
  3. Replies: 4
    Last Post: December 14th, 2013, 10:17 PM
